DSM 6.x und darunter DSM 5.2 (5565) - Erfahrungen, Probleme, Bugs
goetz
Super-Moderator
Teammitglied
18. März 2009
Release Notes:
(2015/05/12)
Compatibility and Installation
  1. DSM 5.2 beta can only be installed on Synology products running DSM 5.0. Before starting, please log in to DSM and go to DSM Update to install the latest DSM.
  2. Some features have specific hardware requirements and are only available on certain Synology NAS products.
Important Notes
  1. DSM 5.2 is the last supported major DSM version for all 10-series models.
  2. An issue of data consistency caused by SSD TRIM is not resolved yet; as a result, SSD TRIM is currently disabled in DSM 5.2.
  3. DSM 5.2 is the last DSM version to support Time Backup as an add-on application in Package Center. Time Backup features will be fully merged into the built-in Backup package in future releases. Existing Time Backup users will not be affected.
  4. Sharing via Facebook and Google+ will no longer be supported starting from DSM 5.2.
What’s New in DSM 5.2
  1. Single Sign-On
    • You can register multiple DSM and access them using one set of credentials. After initial login, linked DSM accounts will automatically log in to avoid credential re-authentication.
  2. Windows File Sharing
    • Added SMB3 and end-to end data encryption support.
  3. Backup and Replication
    • Added support for file-level restoration with File Version Browser in multi-version backup tasks.
    • You can set up backup rotation to recycle old backup versions automatically in multi-version backup tasks.
    • Added data transfer encryption support for multi-version backup.
    • Added support for Amazon S3 China Region as a backup destination.
  1. iSCSI LUN Snapshots
    • You can take iSCSI snapshots more frequently, up to every five minutes.
    • You can set the snapshot retention policy to retain a specific number of versions for hourly, daily, weekly, monthly, and yearly snapshots.
  2. Link Aggregation
    • Added support for two new modes when creating a bond interface: Adaptive Load Balancing and Balance XOR.
  3. SSD Cache
    • SSD cache now has a smaller memory footprint, consuming 90% less memory than DSM 5.1 for newly created SSD caches.
  4. File Station
    • You can manage and transfer files to popular public cloud services such as Dropbox, Box, Google Drive, and OneDrive.
    • The built-in photo viewer now supports full-screen mode.
    • You can drag and drop files between two browsers.
    • You can set the number of times a shared link can be accessed.
    • Added playlist support for the built-in audio player.
    • You can use the built-in mail client to send shared links.
  5. QuickConnect
    • Enhanced stability.
    • DSM will automatically add port forwarding rules required by QuickConnect services on your compatible UPnP router, saving your time on network configuration.
  6. DSM log-in page
  • You can add welcome messages to deliver information to users before they log in to the system.
  1. DSM Help
    • You can reach online resources such as FAQ and compatibility lists in DSM Help now.
    • One more tutorial about how to back up data from your computer is added in the section of Get started with DSM.
  2. Misc
    • You can customize the security level of SSH connections by selecting which encryption algorithm(s) to use.
    • Added more flexible port forwarding rules, including assigning random port numbers, and customized port settings.
    • You can set usage quotas for different groups. The group usage quota is automatically applied when a user is added to the group.
What’s New in Packages
  1. Single Sign-On Package
    • Based on the OAuth2 standard, SSO Server package turns Synology NAS into a SSO server that allows developers to register their web applications to the server and utilize the single sign-on feature. This increases daily productivity by saving time spent on re-authentication.
  1. Docker
    • Docker is a lightweight virtualization application that gives you the ability to run thousands of containers created by developers from all over the world on DSM. The hugely popular built-in image repository, Docker Hub, allows you to find shared applications from other talented developers.
    • A step-by-step tutorial is introduced to guide you through the basic container creation.
  2. Note Station
    • Added to-do list feature. You can add tasks to notes or add them independently to the to-do list.
    • Manage tasks by specifying a priority, due date, and reminder.
    • Synology Web Clipper is now available on the Chrome Web Store. You can clip web content directly to Note Station.
    • Export notebooks to a nsx file for backup or for importing to another Synology NAS.
    • Export individual notes as HTML files so that users without Note Station can read them.
    • You can archive seldomly used notebooks so that they will not be displayed in the notebook section or in search results.
    • Enhanced Note Station file structure. A three-tier structure (Shelf, Notebook, and Note) provides greater flexibility for organizing Note Station.
    • You can display notes in presentation mode.
    • You can create new notes in a joined notebook if you were given modify permissions.
    • You can share notes via the built-in DSM email application.
    • You can change the default notebook.
    • You can adjust the default note font size.
    • Import notes from YinXiangBiJi.
    • Better note version conflict handling.
    • Todo badge number on Desktop icon.
  3. Cloud Station
    • Added support for low-latency smart polling.
    • You can assign different historic version numbers for each shared folder.
    • Enhanced general performance.
    • Added support for native renaming operation.
    • Administrators can enable/disable Cloud Station directly from Package Center.
    • Added support for File Station Recycle Bin.
    • Files greater than 10GB can be synced.
    • Updated PC client for Windows, Mac and Linux:
      1. Added a quick setup wizard.
      2. Added a search feature to automatically find all Synology NAS in the local area network.
      3. Added a system tray menu in graphic user interface.
      4. You can right-click to stop or resume syncing for specific subfolders.
      5. You can right-click a synced folder to generate a folder sharing link.
      6. You can right-click any file on your computer to copy it to the Cloud Station folder.
      7. Added a client-side sync log.
  4. Cloud Sync
    • Added unidirectional sync from NAS to public cloud and from public cloud to NAS.
    • You can encrypt and compress data sent to public cloud storage.
    • Added support for Amazon S3 compatible public cloud service providers.
    • Added support for WebDAV public cloud service providers.
    • Added support for Amazon Cloud Drive.
    • Added support for Megafon Disk.
    • Added support for native renaming operation (support level differs with public cloud storage API).
    • You can customize both task name and polling period.
    • You can sync files as large as 10GB with OneDrive.
  5. Mail Server
    • Added attachment filter to block specific file extensions.
    • You can receive real-time notifications regarding daily quota status.
    • Added support for SPF/DKIM and DMARC sender validation.
    • Added customized auto-reply and content setting features.
    • Daily quotas can be set by user.
  6. Glacier Backup
    • Enhanced to handle Amazon server-side speed limit.
  7. Video Station
    • You can use hotkeys to fast forward, rewind, and adjust the volume during video playback.
    • Subtitle files can now be located anywhere on your Synology NAS and no longer need to match the filename of your video files. Simply select them using the built-in chooser in Video Station during playback.
    • More code-pages supported to correctly recognize subtitles in different languages.
    • You can set a timing offset to sync subtitles with video playback.
    • You can customize video posters by selecting an image from your Synology NAS.
    • Use the shortcut on the library to quickly add video folders.
    • You can delete videos directly from Video Station
    • Supported right-click context menu to access useful functions more quickly.
  8. Audio Station
  • Added support for indexing CUE sheet files to display all indexed audio tracks, and the song information of an undivided album file for management (requires DSM 5.2).
  • Added support of transcoding FLAC/APE, ALAC/AAC, OGG, AIFF formats for DLNA players.
Teil 2
  1. Photo Station
    • A brand-new design that gives Photo Station mobile a refreshed look-and-feel. The update includes two major improvements: watching videos and linking directly to details page of a photo.
    • You can select specific albums when creating a smart album.
    • More EXIF information is displayed in the lightbox page, and can also be added as conditions when creating smart albums.
  2. Download Station
    • Previews for photos and videos are available for torrent downloads.
    • Added support for HTTP downloads with multiple connections.
  3. Media Server
    • Resumed video transcoding support (This feature is supported by select models. Please go here for detailed information).
  4. Redmine
    • Redmine is a flexible project management web application. It has numerous features and can be run on Synology NAS via Docker.
  5. GitLab
    • GitLab is a web-based Git repository manager with wiki and issue tracking features. It has numerous features and can be run on Synology NAS via Docker.
  6. LXQt
    • LXQt is a desktop utility built on QT with partial Razor-qt and LXDE components. It comes with a basic graphical user interface which gives users the ability to leverage certain operating system features, such as web browsing. It has numerous features and can be run on Synology NAS via Docker.
  7. SpreeCommerce
    • SpreeCommerce is a full-featured storefront tool built on common standards so you do not have to compromise speed to market, efficiency, or innovation. You can also easily leverage the advantages of modular design to configure, supplement, or replace the functionalities you need. It has numerous features and can be run on Synology NAS via Docker.
  8. Discource
    • Discourse is a forum application software with a focus on user experience by introducing infinite scrolling, live updates, drag and drop attachments and more. It has numerous features and can be run on Synology NAS via Docker.
  9. MantisBT
    • MantisBT is an open source, web-based issue tracker and project management tool with a focus on simplicity and flexibility. Users are able to get started quickly and manage their projects effectively, making collaboration with team members and clients easy and professional.
  10. LimeSurvey
    • LimeSurvey is a powerful survey creation tool that help you easily create and publish intuitive and question-and-answer surveys and collect responses without the requirement of technical background. LimeSurvey also provides graphical analysis of the result for you to quickly find the information from the statistics. You also have the full control of whom to access the survey, either publish the survey publicly or limit only the users with the "once-only" token.
  11. CMS
    • Bug fixes and usability enhancements.
[*] DSM 5.2 beta can only be installed on Synology products running DSM 5.0.
Na, da war es für die Jungs wohl 'ne stressige Nacht bis zum online-schalten, dass sie das kleine Wörtchen vergessen haben zu löschen... :) (oder sind da dann doch noch so viele Fehler drin?! :D)
Update auf die DS414 und DS115 ohne Probleme.
Alle Pakete sind neu und bis jetzt funktioniert alles wie gehabt.
Mit der DS214 warte ich noch bzgl. des MailServer Pakets.
update auf DS1513+ und DS411+II ohne Probleme.
Cloudstation von der DS1513+ auf iPhone / iPad läuft auch einwandfrei.
Die vorhandenen Backups von der 1513 auf die 411 liefen auch ohne Probleme durch.
MAC service wurde activiert, war vor update nicht so.
Hi bei meiner DS415+ blinkt die Blaue LED ständig. Wenn ich die Festplatten entferne fährt die DS hoch die Blaue LED leuchtet und die DS ist mit dem Assistenten erreichbar.
Was kann ich machen. Während dem update lief ein Backup Job von HiDrive. Ich hatte mal das Problem das wenn dieser Job läuft die DS nicht rebootet.
Welchen Reset muss ich machen das die Systempartition gelöscht wird? Ohne Festplatten wird im Assistenten die DSM 5.2-5565 angezeigt.
Nach dem Update der Firmware auf DSM 5.2-5565 meldet sich meine Cloud-Station auf dem PC als veraltet (3.2-3423) und synct nicht mehr. Es wird aber auch keine neue Version (3.2-????) von selber runtergeladen und auf der Webseite steht auch nur die alte Version. Hat jemand Infos dazu? Besten Dank im Voraus!
mein Client hat gerade eine neue Version gemeldet und installiert (3475).
War vorher nicht bei mir so und ist auch nach dem Update bei mir nicht aktiviert.
Update der DS212+ lief wunderbar durch.
Bei mir lief das Update auch reibungslos durch. Allerdings bekomme ich jetzt dauern beim Hoch und Runderfahren der DS die Meldungen:
DS214 wurde mit UPS verbunden oder DS214 ist nicht mehr mit UPS verbunden.
Update lief auf meiner DS 214+ einwandfrei durch. Anschließend noch 10 Pakete aktualisieren; fertig ist. Momentan alles ok.
Update auf DS215j und DS213j ohne Probleme.
Mir ist eine RS10613xs+ beim Neustart hängen geblieben. Danach lief sie aber sauber und ohne erkennbare Probleme. Hat schon jemand den auf der CeBIT 2015 angekündigten Synology Mail Client als Paket entdecken können?
cloud sync ist nicht mehr zu finden - auch im paketmanager nicht... normal?
Bei mir lief dieses neueste Update auf einer DS111 problemlos durch, benötigt ca. 7 Minuten inkl. Neustart.
Danach mussten noch 6 Pakete "manuell" aktualisiert werden. Heisst, auf "Alle aktualisieren" klicken :o, das dauert nochmal gleich lang.
Soweit alles in Ordnung.
Was diese Neuerungen in der Praxis wirklich bringen, kann ich natürlich noch nicht beurteilen.
@columbo1979: Bei mir sind "Cloud Station", "Cloud Station Client" und "Cloud Sync" im Paket-Zentrum vorhanden.
