DSM 5.0 Beta (4418) - Erfahrungen, Probleme, Bugs
Im OpenVPN-Dialog kommt nach klicken auf Übernehmen die Meldung: "OpenVPN konnte nicht aktiviert werden. Prüfen Sie die Konfigurationsdatei" in roter Schift.
Kennt jemand um welche Datei das ist, und wo???
/usr/syno/etc/packages/VPNCenter/openvpn/openvpn.conf
Gruß Frank
Fixed Issues in Update 1
1.Data volumes would maybe become degraded or crashed on certain models, including DS413j, RS812, RS411, DS411, DS411j, DS411slim, DS410j.
2.LAN (Ethernet) interface would disappear when Wi-Fi hotspot was turned on and Wi-Fi adapter was unplugged.
3.Personal Web Station did not work.
Fixed Issues in Cloud Sync 1.0-0037
1.Stability becomes an issue when syncing files with Google Drive.
2.Compatibility issue with Personal Photo Station.
Fixed Issues in Cloud Station 3.0-3005
1.Connection over SSL did not work.
Fixed Issues in Antivirus by McAfee 1.3-2320
1.McAfee subscription renew did not work.
Fixed Issues in DS video for Samsung TV 1.0-017
1.Default language was not English.
Limitations
1.Shortcuts that were created previously will be cleared after upgrading to DSM 5.0.
Known Issues
1.Logitech Media Server
•The album and movie covers might not display correctly
•Media formats that require transcoding might not work
2.Windows File Services
•SMB2 does not support the extended attributes for Mac OS X 10.9.1 in DSM 5.0 beta. For files and folders with certain types of extended attributes named "resource fork", such as custom icon and default application settings, the main file/folder context will be saved without any resource fork data.
3.Cloud Station
•Cloud Station computer client version 2.0-2391 and 2.0-2402 will not be automatically upgraded.
4.Photo Station
•Photos or videos stored in shared folders which have converted to Windows ACL or created in DSM 5.0 may not be copied to Photo Station from the web uploading interface. To solve this, please go to Control Panel > Shared Folders, and assign Read permission to the http group on the shared folder in question.
5.Central Management System
•Cannot add Synology NAS servers with passwords that include these characters +, ?, %, &.
•The URL is incorrect when launching apps from a remote server over an HTTPS connection.
6.DSM Desktop
•The network traffic section of the Resource Monitor widget shows “0 KB/s” when it is minimized to the taskbar.
7.Backup & Replication
•To backup system configurations, a backup task must be created in Backup & Replication.
8.Antivirus Essential & McAfee
•The button to update virus definitions is not hidden when using certain display languages. To find the button, please change the display language to English.
Die Video station selbst erkennt den Stick, findet Programme und epg, aber kein livestream/aufnahme. Tvheadend wiederum kann alles außer livestream, meint: ich kann aufnehmen, aber kein live tv sehen...
Mal eine Frage, da für mich absolut wichtig. Zur Zeit verwende ich den Stream meiner Videostation, um in meiner Zweitwohnung unter der Woche TV zu haben. Klappt bislang ganz gut. Geht das unter 5.0 noch? Bin mir da nach der Aussage nun nicht ganz sicher...
Nach dem Update 1 funktioniert auch auf meiner DS212+ endlich die CloudSync App. Aber entweder bin ich zu blöd, die entsprechende Einstellung zu finden, oder aber die DS synchronisiert nun den kompletten Inhalt aus Google Drive in meinen angegebenen, lokalen Ordner.
Meiner Meinung nach ist das totaler Schwachsinn. Ich will nur einen Ordner mit Inhalt mit meinem lokalen synchronisieren...
Bei Dropbox ist mit CloudSync auch keine selektive Synchronisierung möglich.
Was mich darüber hinaus nervt ist, dass HDD Hibernation mit aktiviertem CloudSync nicht mehr geht. Da wird ca. alle 6 Sekunden auf /etc/resolv.conf zugegriffen. Wenn die Synchronisierung pausiert wird, funktioniert auch wieder der Ruhezustand.
Hab denen heute per Bug Report den Vorschlag gemacht, entweder den ständigen Zugriff zu fixen und wenn das nicht möglich sein sollte, den Nutzer entscheiden zu lassen ob er dauerhaften Sync möchte oder Stündliche/Tägliche (cronjob) bzw manuelle Synchronisation reichen würde.
Deswegen läuft meine mittlerweile den ganzen Tag (auf die 2€ Strom im Monat kommt es mir dann auch nicht an).
Ich wollte eben den Vorschlag mit der selektiven Synchronisierung machen, aber das Formblatt ist mal wieder abgeschmiert :-/
Ich hoffe wirklich, dass das noch kommt, denn so kann ich das überhaupt nicht gebrauchen.
kurzes Feedback zum meinem Test:
1. DSM 5 lässt sich problemlos auf 4.3 downgraden
2. Die Video Station zickt bei mir unverändert, aber:
3. Workaround gefunden: TVHeadend kann auch den livestream, sofern unter TVHeadend ein Nutzer ohne Name und Passwort erstellt wird.
Sofern dein stick unter 4.3 unter der aktuellen Version der Video Station läuft, sollte es keine Probleme geben.
4. Ich dokumentiere das die Tage noch ausführlicher
Bei mir läuft die DSM 5 Beta einigermassen gut, aber der Firefox crasht/hängt von Zeit zu Zeit einfach, wenn man im DSM eingeloggt bleibt in irgendeinem Tab (erst so nach 10, 20, 30 Stunden). Generell scheint das DSM GUI im Browser etwas öfters zu hängen als bei der 4.3.
Das Crashen liegt glaub ich am Timeout. Ist im Chrome auch so. Wenn der Timeout zu schlägt hilft nur Tab schliessen ansonsten beruhigt sich das Ding nicht und es wird auch das Anmelde Fenster nicht neu Aufgebaut. Mit IE oder Firefox hab ich es jetzt noch nicht getestet. Hab einfach den Timeout auf 24 Std. gesetzt.
Frank
Hat hier schon jemand die neue MailStation/MailServer getestet und kann dazu was sagen?
@PuttpetMaster:
Keine Probleme hier mit dem MailServer, die Änderungen scheinen aber auch eher unter der Haube zu liegen. Anstelle der MailStation verwende ich eh eine eigene RC Instanz...
Danke!
Ist ja schonmal gut zu hören, dass das stabil läuft.
Die augenscheinlichsten Änderungen gab es allerdings wohl bei der MailStation, denn die hat jetzt auch das Outfit (GUI) des aktuellen Roundcubes bekommen.
fetchmail ist weiterhin vorhanden (bei roundcube selber nicht dabei).
Wäre halt interessant, ob das alles noch stabil läuft. Bei MailServer/Station ist's immer blöd, wenn's Probleme gibt.
Kurzes Feedback.
Die Beta läuft bei mir absolut stabil!
- GUI ist meiner Meinung nach ein bisschen flotter, flüssiger geworden.
- Audio Station: damit habe ich weniger Probleme als unter 4.3. z.B. hatte ich das Problem das ein Internetradiosender immer mal unterbrochen wurde.
Ist bei einer 16er Leitung eher unwahrscheinlich das es an der Übertragung liegt, vor allem wenn zu dem Zeitpunkt sonst nichts über die Leitung geht.
Und selbst wenn es der Datenstrom gewesen sein mag, sollte doch die Wiedergabe wieder loslegen, wenn die Daten wieder vorhanden sind.
Das war sehr oft nicht der Fall. Ich musste die Wiedergabe stoppen und neu starten.
- Video Station: läuft alles. Wiedergabe, Stream, Aufnahme mit USB-S2 Stick. Einzig die Samsung App läuft bei mir leider nicht (TV zu "alt") aber vielleicht mach Synology da noch was dran. Würde mich freuen
- Photostation: keine Probleme. Ich hatte aber gehofft das ich mit der Anbindung an G+ in der Lage sein würde meine Bilder automatisch hochladen zu können.
Das scheint ja leider nicht vorgesehen zu sein. Oder ich habs noch nicht gefunden.
- Cloudsync: naja, es scheint zu funktionieren. Ich synce mit GDrive. Hm... ich werde das Gefühl nicht los, als wenn das sooooo langsam ist.
Seit 5 Tage wird bei schon synchronisiert und er ist immer noch nicht fertig, für 12GB. Allerdings muss ich dazu sagen das ich die Synchonisierung hin und wieder unterbreche, um mehr Bandbreite zur Verfügung zu haben
Wäre super wenn man das einstellen könnte.
Cloudsync scheint bei mir den Ruhezustand zu verhindern. Wie ist das denn seit dem "Update 1"?
Eine Funktion zur Einstellung der Bandbreite wäre schön. Gibt es eine Funktion bei der man einstellen kann wann die Synchronisierung ausgeführt werden soll? Mir würde gefallen wenn das immer x.xxUhr wäre, oder eben flexibel einstellbar... Gibt es dazu eine Einstellung die ich noch nicht gefunden habe?
Ich hab da ein Problem mit dem externen Zugriff. Nachdem es unter 4.3 einigermassen sauber funktionierte, wollte ich nun auch unter DSM 5 von extern mich anmelden. Ich komme auch auf die Seite (meistens, aber bleibt auch gerne mal weiß) und nach der Anmeldung kommt nix mehr. Es steht dann dort "Wird geladen..." und es geht nicht mehr weiter. Es sei erwähnt, dass ich hier extern hinter einem Proxy hänge. Mit dem Handy funzt es super!
Wäre super, wenn jemand ne Idee hätte.
Rabbit
Klappt bei mir wunderbar.
Sowohl per Smartphone Browser in der Mobilenansicht als auch mit einem PC Browser in der Desktopansicht.
Hängt dein PC auch an einem Proxy?
Rabbit
Seit dem Update1 der Beta sehe ich ein Download zwischen 200 KB und 550 KB, hat das jemand auch? Kein Download läuft, oder wie kann man herausfinden was gerade heruntergeladen wird?
=> Edit: Habe das "Problem" gefunden, mein Sohn hat eine Web-Cam installiert welche den Traffic verursacht hat...
