DDNS Updater ddns updater for OVH provider
fa355115
29. Jan. 2012
Hi guys,
Hi Qtip,
I am sorry I need to post in English, because my dutch is tooo bad
I have found the ddnsupdater 1-19 which I installed together with Init_thirdparty 1.5, thinking I could find my dns provided OVH for which I have 2 domains registered, which I'd like both to update with my public IP.
Unfortunately, I can not find OVH in the list of provideds in your app, just "custom provider", but I do not know the parameters to set for this custom pvovider.
So far, I have used the workaround to edit the "/etc.defaults/ ddns_provider.conf " and add the following lines :
[ovh.com]
modulepath=DynDNS
queryurl=www.ovh.com/nic/update?hostname=__HOSTNAME__&myip=__MYIP__&system=dyndns&wildcard=NOCHG&mx=NOCHG&backmx=NOCHG
... and it was working fine, but I now have 2 domains to update by OVH, and I'd like to use your tool, so :
1. can you please let me know if OVH support can be added : https://www.ovh.com/fr/index.xml
2. can you please let me know the custom parameters to set for this provider (protocol, server, wildcard, wait times, ...
Many Thanks !!!
My German is as bad as my Dutch :):)
Hope to read from you soon, as I plan t use this package with my OVH DNS provider !
Many thanks !
Hi fa355115, the site use the protocol "dyndns2", i can support this in the next release
Many Thanks !!!
the site use the "dyndns2" protocol, so make the following steps in ddns updater:
  • Add new host, select custom provider
  • in field "Protocol" put "dyndns2"
  • in field "Server" put "www.ovh.com"
  • in field "Hostname" put your hostname
  • in field "Login" put your login of the manager
  • in field "Password" and "Confirm password" put your password for the manager
you must do this steps again for your second host
this should work, but i can not test
Many thanks !! I will then test it and let you know.
But I have 2 additional questions for you :
1. I have dsm 3.x. and wondering if the "help" package is necessary / mandatory ? (Init_3rdpartyHelp_1.10.spk )
So I understand I first need to install "Init_3rdparty_1.5.spk" then "ddnsupdater_1.19.spk" ?
2. Is there a way I can be automatically informed when next release is .... released ?
Many Thanks !
oups ... what is the dutch word for that "abonnement" ?
Take a lokk for
Abonnement
Thema abonnieren und über neue Beiträge benachrichtigen:
in Editor at the Buttom in enhanced Mode!
ok - I hqve done something but I am not sure if I did it correctly ;-)
well, go to the thread i mentioned above, write a short note in there and check the box as shown in picture.
I think I can not do that because thread is closed.
"Thema geschlossen"
the helpfile for ddns updater in dsm 3.x require the package "Init_3rdparty_1.5.spk", so install in the following order:
  • install Init_3rdparty_1.5.spk and start package, after a few seconds refresh the browser
  • install Init_3rdPartyHelp_1.10.spk and start, then delete the browser cache or restart the browser. If this not help, just restart the DS.
  • install DDNS updater
DSM 4.x installation sequence:
Many Thanks !
You can add the package-source to your package center, the url is: http://update.10trum.de/packageupdate/getpackages.php . You get a complete list of avaiable package-sources in our wiki at http://www.synology-wiki.de/index.php/Paketzentrum_Quellen
If a update is available, the you get a dsm notification and see a button "update" in the package center near the ddns updater package entry
Many thanks, I learned something - I will be notified now.
I will install the packages and let you know the outcome for OVH.
ok - I have some tim to look at that now.
Just have a quesiton concerning the "help" package.
Last time I only installed "Init_3rdparty_1.5.spk" and "ddnsupdater_1.19.spk", without the help package.
I have found this help package called "Init_3rdpartyHelp_1.1.spk" (by the way, filename says 1.1, but should be 1.10, no ?? - http://package.10trum.de/index.php?id=40&pid=5), but I am not sure I need to install it as such, because I found this post totally unreadable which seem to ask doing additional things ?
"DSM 3.x: Ab Version 1.16 zusätzlich noch das Paket Init_3rdpartyHelp_1.10.spk installieren und ebenfalls ausführen."
http://www.synology-forum.de/showthread.html?15822-Init_3rdpartyHelp-Skript
I have DSM 3.2-1955
Can you please clarify what I should do with this help install package, and if there is something aditional to be done ?
Is that help package necessary ?
I have DSM 3.2-1955
Red Letters means:
starting up from DSM 3.x and higher versions you have to add the additional package called Init_3rdpartyHelp_1.10.spk and execute it.
don´t ask me what it does exactly but the programmer QTip will tell you more for shure.
Mike
ok - so this package is necessary for me, remains 1 question and 1 remark :
remark : filename seeme to refer to 1.1 instead of 1.10
1.1 and 1.10 are the same, i will fix this in the documentation
question : do I need to do something specific with the help package or just install it, as it is mentioned here something like :
Many thanks for your support !!
ok.
I have upgraded my DSM to version 4.0.2197.
I have seen in this version, under "Packages" that ddns was part of the "Other sources" packages. I guess it is because I have added "http://update.10trum.de/packageupdate/getpackages.php " as other potential sources ?
So I have installed your packages from there, meaning :
1. init-thirdparty version 1.5
2. ddns updater version 1.19
I have forgot to install the help package - not sure if it is of any use for me ? Is it mandatory ?
normally, I will be notified when a new version is installed.
I have set the parameters as stated above for OVH, and this is working fine.
Do you know when OVH will be part of the "providers" in a next release ?
Many Thanks !
