IPKG auf DS101j
ps915
26. Feb. 2011
ich komme einfach nicht weiter. Ich möchte IPKG auf meiner DS101j installieren.
Ich richte mich nach dieser Anleitung: http://www.synology-wiki.de/index.php/IPKG
Hier meine Schritte:
1. Als Root einloggen
2. wget http://ipkg.nslu2-linux.org/feeds/optware/syno-x07/cross/unstable/syno-x07-bootstrap_1.2-7_arm.xsh
3. sh syno-x07-bootstrap_1.2-7_arm.xsh
4. Dann scheitert der Befehl: ipkg update
Hier Der SHH Auszug:
login as: root
root@192.168.0.105's password:
BusyBox v1.16.1 (2010-10-23 01:00:23 CST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
DiskStation> cd /volume1/public
DiskStation> wget http://ipkg.nslu2-linux.org/feeds/optware/syno-x07/cross/unsta
--19:05:12-- http://ipkg.nslu2-linux.org/feeds/optware/syno-x07/cross/unstable/ syno-x07-bootstrap_1.2-7_arm.xsh
=> `syno-x07-bootstrap_1.2-7_arm.xsh'
Resolving ipkg.nslu2-linux.org... 140.211.169.169
Connecting to ipkg.nslu2-linux.org|140.211.169.169|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 250,388 (245K) [text/plain]
100%[====================================>] 250,388 194.39K/s
19:05:15 (193.87 KB/s) - `syno-x07-bootstrap_1.2-7_arm.xsh' saved [250388/250388 ]
DiskStation> sh syno-x07-bootstrap_1.2-7_arm.xsh
Optware Bootstrap for syno-x07.
Extracting archive... please wait
bootstrap/
bootstrap/bootstrap.sh
bootstrap/ipkg-opt.ipk
bootstrap/ipkg.sh
bootstrap/optware-bootstrap.ipk
bootstrap/wget.ipk
1226+1 records in
1226+1 records out
Creating temporary ipkg repository...
Installing optware-bootstrap package...
Unpacking optware-bootstrap.ipk...Done.
Configuring optware-bootstrap.ipk...Modifying /etc/rc.local
Done.
Installing ipkg...
Unpacking ipkg-opt.ipk...Done.
Configuring ipkg-opt.ipk...WARNING: can't open config file: /usr/syno/ssl/openss l.cnf
Done.
Removing temporary ipkg repository...
Installing wget...
bootstrap.sh: line 45: /opt/bin/ipkg: not found
DiskStation> ipkg update
/bin/sh: ipkg: not found
DiskStation>
Was mache ich falsch? :mad: Kann mir jemand helfen?
Gruß,
ps915
Versuch mal einen Reboot
Das habe ich auch gemacht und dann mit dem Befehl ipkg update versucht weiterzumachen. Doch leider kommt auch hier dann der Fehler wie oben. Muss ich noch die bootstrap.sh ausführen? Weil davon war im Tutorial nicht die Rede.
Nein, versuch nochmal das xsh ausführen. Die bootstrap.sh musst Du nicht selber ausführen.
Also ich habe nun per "reboot" die DS neu gestartet.
Habe mich als root angemeldt und bin in das verzeichnis "public" gewechselt.
Danach habe ich die Datei erneut ausgeführt:
login as: root
bootstrap/
bootstrap/ipkg.sh
bootstrap/wget.ipk
1226+1 records in
1226+1 records out
Backup your configuration settings, then type:
rm -rf /volume1/@optware
rm -rf /usr/lib/ipkg
!!Was bedeuten denn diese Befehle? Was sind den die Optware packages? Ist das mit einer Deinstalatin zu vergleichen?
This will remove all existing optware packages.
You must *reboot* and then restart the bootstrap script.
DiskStation>
Wie gehst nun weiter?
Hi, vor der installation wäre es besser gewesen das verzeichnis anzulegen
cd /volume1
mkdir public
Habe bei meiner DS411slim jetzt das gleiche Problem, reboot hat nicht gebracht
Greetings
Du hast eine 101j und keine x07+, somit hast Du das falsche Paket erwischt. Lade Dir dieses Bootstrap runter. Vor der Installation bitte
ausführen.
Okay, dann kann es ja nicht funktionieren. Aber leider bekomme ich auch mit dem neuen Paket diverse Fehlermeldungen:
login as: root
DiskStation> rm -rf /volume1/@optware
DiskStation> rm -rf /usr/lib/ipkg
DiskStation> sh ds101-bootstrap_1.0-4_armeb.xsh
DS-10x Bootstrap extracting archive... please wait
bootstrap/
bootstrap/bootstrap.ipk
bootstrap/ipkg.ipk
bootstrap/ipkg.sh
bootstrap/openssl.ipk
bootstrap/wget-ssl.ipk
48246+1 records in
48246+1 records out
Creating temporary ipkg repository... success
Installing DS101(g)-bootstrap package...Unpacking bootstrap.ipk...Done.
Configuring bootstrap.ipk...Regenerating dynamic linker cache...
/opt/sbin/ldconfig: line 1: syntax error: unexpected word (expecting ")")
Done.
success
Installing IPKG package... (Ignore missing md5sum warning)
Unpacking ipkg.ipk...Done.
Configuring ipkg.ipk..../ipkg.sh: line 1170: md5sum: not found
Done.
Installing OpenSSL../opt/bin/ipkg: line 1: syntax error: unexpected word (expecting ")")
DiskStation>
DiskStation>
login as: root
bootstrap/
bootstrap/ipkg.ipk
bootstrap/ipkg.sh
48246+1 records in
48246+1 records out
Done.
success
Done.
DiskStation>
Wo liegt denn nun der Fehler?
