sudo docker run -d \
> --name watchtower \
> -v /var/run/docker.sock:/var/run/docker.sock \
> containrrr/watchtower
docker run --rm --name=watchtowertemp -v /var/run/docker.sock:/var/run/docker.sock containrrr/watchtower:latest --cleanup --run-once
docker run -d --name=watchtower -v /var/run/docker.sock:/var/run/docker.sock --restart=always containrrr/watchtower:latest --cleanup
latest
zeigenNein ich habe überall latest drinnenGibst du eine Version direkt an?
Ja perfekt da hat er es gemacht und es scheint alles zu funktionieren nun läuft die 1.17.0Ich würde es entweder so machen (RunOnce):
The above exception was the direct cause of the following exception:
Traceback (most recent call last):
File "/usr/src/paperless/src/manage.py", line 10, in <module>
execute_from_command_line(sys.argv)
File "/usr/local/lib/python3.9/site-packages/django/core/management/__init__.py", line 446, in execute_from_command_line
utility.execute()
File "/usr/local/lib/python3.9/site-packages/django/core/management/__init__.py", line 440, in execute
self.fetch_command(subcommand).run_from_argv(self.argv)
File "/usr/local/lib/python3.9/site-packages/django/core/management/base.py", line 402, in run_from_argv
self.execute(*args, **cmd_options)
File "/usr/local/lib/python3.9/site-packages/django/core/management/base.py", line 448, in execute
output = self.handle(*args, **options)
File "/usr/local/lib/python3.9/site-packages/django/core/management/base.py", line 96, in wrapped
res = handle_func(*args, **kwargs)
File "/usr/local/lib/python3.9/site-packages/django/core/management/commands/migrate.py", line 114, in handle
executor = MigrationExecutor(connection, self.migration_progress_callback)
File "/usr/local/lib/python3.9/site-packages/django/db/migrations/executor.py", line 18, in __init__
self.loader = MigrationLoader(self.connection)
File "/usr/local/lib/python3.9/site-packages/django/db/migrations/loader.py", line 58, in __init__
self.build_graph()
File "/usr/local/lib/python3.9/site-packages/django/db/migrations/loader.py", line 235, in build_graph
self.applied_migrations = recorder.applied_migrations()
File "/usr/local/lib/python3.9/site-packages/django/db/migrations/recorder.py", line 81, in applied_migrations
if self.has_table():
File "/usr/local/lib/python3.9/site-packages/django/db/migrations/recorder.py", line 57, in has_table
with self.connection.cursor() as cursor:
File "/usr/local/lib/python3.9/site-packages/django/utils/asyncio.py", line 26, in inner
return func(*args, **kwargs)
File "/usr/local/lib/python3.9/site-packages/django/db/backends/base/base.py", line 323, in cursor
return self._cursor()
File "/usr/local/lib/python3.9/site-packages/django/db/backends/base/base.py", line 299, in _cursor
self.ensure_connection()
File "/usr/local/lib/python3.9/site-packages/django/db/backends/base/base.py", line 282, in ensure_connection
self.connect()
File "/usr/local/lib/python3.9/site-packages/django/db/utils.py", line 91, in __exit__
raise dj_exc_value.with_traceback(traceback) from exc_value
self.connect()
File "/usr/local/lib/python3.9/site-packages/django/db/backends/base/base.py", line 263, in connect
self.connection = self.get_new_connection(conn_params)
File "/usr/local/lib/python3.9/site-packages/django/db/backends/postgresql/base.py", line 215, in get_new_connection
connection = Database.connect(**conn_params)
File "/usr/local/lib/python3.9/site-packages/psycopg2/__init__.py", line 122, in connect
conn = _connect(dsn, connection_factory=connection_factory, **kwasync)
django.db.utils.OperationalError: could not translate host name "db" to address: Name or service not known
version: "3.6"
services:
broker:
container_name: redis
image: redis:latest
restart: unless-stopped
volumes:
- ../redis:/data
db:
container_name: postgres
image: postgres:15
volumes:
- ../pgdata:/var/lib/postgresql/data
- /volume1/docker/paperlessngx/exportpostgres:/var/lib/postgresql/data/backup
environment:
POSTGRES_DB: paperless
POSTGRES_USER: paperless
POSTGRES_PASSWORD: paperless
webserver:
container_name: paperlessngx
image: ghcr.io/paperless-ngx/paperless-ngx:latest
depends_on:
- db
- broker
ports:
- 8777:8000
healthcheck:
test: ["CMD", "curl", "-fs", "-S", "--max-time", "2", "http://localhost:8000"]
interval: 30s
timeout: 10s
retries: 5
volumes:
- /volume1/docker/paperlessngx/data:/usr/src/paperless/data
- /volume1/docker/paperlessngx/media:/usr/src/paperless/media
- /volume1/docker/paperlessngx/export:/usr/src/paperless/export
- /volume1/docker/paperlessngx/consume:/usr/src/paperless/consume
env_file: docker-compose.env
environment:
PAPERLESS_REDIS: redis://broker:6379
PAPERLESS_DBHOST: db
volumes:
data:
media:
pgdata:
redisdata:
wozu sind die beiden Punkte? Für einen Pfad den wir nicht wissen sollen? Ansonsten müsste da noch eine Pfadangabe zu deinen Daten wie etwa sowas:volumes: - ../redis:/data
- /volume1/paperless/redis:/redis
Bei dem db Abschnitt ist es das gleiche.
django.db.utils.OperationalError: connection to server at "db" (172.25.0.4), port 5432 failed: Connection refused
Is the server running on that host and accepting TCP/IP connections?
