Yippie
- 01. Feb. 2011
Da ich wie gesagt bereits anderweitig vorgegangen bin, kann ich nicht mit Sicherheit sage, ob diese Einträge hier den Upgrade-Fehler beschreiben/var/log/synoscgi.log
2022-08-31T11:16:06+02:00 ISAR synoscgi_SYNO.Core.Package.Installation_1_upload[30410]: pkgverify.cpp:299 Failed to verifypackage, spk=[/volume2/@tmp/upload_tmp.304100] result=[{"action":"prepare","beta":false,"betaIncoming":false,"error":{"code
":289,"description":"spk is not from synology"},"installReboot":false,"package":"synOCR","packageName":"synOCR DSM7","stage
":"prepare","success":false,"version":"1.2.0"}]
2022-08-31T11:16:11+02:00 ISAR synoscgi_SYNO.Core.Package.Installation_1_upgrade[30408]: pkgverify.cpp:299 Failed to verify
e":289,"description":"spk is not from synology"},"installReboot":false,"package":"synOCR","packageName":"synOCR DSM7","stag
e":"prepare","success":false,"version":"1.2.0"}]
2022-08-31T11:16:12+02:00 ISAR synoscgi_SYNO.Core.Package.Installation_1_upgrade[30571]: docker_compose_start/dockercompose
startworker.cpp:42 file [/var/packages/synOCR/var/docker-compose.yaml] missing[0xD900 manager.cpp:206]
startworker.cpp:80 Docker compose stop fail with compose file [/var/packages/synOCR/var/docker-compose.yaml].
2022-08-31T11:16:12+02:00 ISAR synoscgi_SYNO.Core.Package.Installation_1_upgrade[30408]: pkguninstall.cpp:252 Failed to rel
ease halt resource before uninstall synOCR [0x2000 bdb_get.c:40]
2022-08-31T11:16:12+02:00 ISAR synoscgi_SYNO.Core.Package.Installation_1_upgrade_SYNO.Docker.Container.PkgProfile_1_remove[
30573]: APIRunner.cpp:1101 AppArmor: change hat Original Hat failed [Operation not permitted]
30573]: APIRunner.cpp:1115 AppArmor: change hat failed [Operation not permitted]
30573]: APIRunner.cpp:1416 AppArmor: change hat Original Hat failed [Operation not permitted]
30573]: APIRunner.cpp:1421 AppArmor: change hat [SYNO.Core.Package.Installation] failed [Operation not permitted]
2022-08-31T11:16:27+02:00 ISAR login.cgi[32625]: login.cpp:174 ERROR: setresgid(-1, 0, -1) [Operation not permitted]
Hier die vermeitlichen Zeilen zum ersten Upgrade-Versuch aus /var/log/packages/synOCR.log
2022/08/31 10:41:08 upgrade synOCR 1.2.0.10 Begin start-stop-status stop
Stopping...
2022/08/31 10:41:08 upgrade synOCR 1.2.0.10 End start-stop-status stop ret=[0]
2022/08/31 10:41:10 upgrade synOCR 1.2.0.10 Begin preupgrade
2022/08/31 10:41:10 upgrade synOCR 1.2.0.10 End preupgrade ret=[0]
2022/08/31 10:41:10 upgrade synOCR 1.2.0.10 Begin preuninst
sed: couldn't open temporary file /etc/sedsZlV8b: Permission denied
2022/08/31 10:41:10 upgrade synOCR 1.2.0.10 End preuninst ret=[0]
2022/08/31 10:41:10 upgrade synOCR 1.2.0.10 Begin /bin/rm -rf /volume1/@appstore/synOCR
2022/08/31 10:41:10 upgrade synOCR 1.2.0.10 End /bin/rm -rf /volume1/@appstore/synOCR ret=[0]
2022/08/31 10:41:10 upgrade synOCR 1.2.0.10 Begin /bin/rm -rf /volume1/@apptemp/synOCR
2022/08/31 10:41:10 upgrade synOCR 1.2.0.10 End /bin/rm -rf /volume1/@apptemp/synOCR ret=[0]
2022/08/31 10:41:10 upgrade synOCR 1.2.0.10 Begin postuninst
2022/08/31 10:41:10 upgrade synOCR 1.2.0.10 End postuninst ret=[0]
2022/08/31 10:41:11 upgrade synOCR 1.2.0.12 Begin preinst
2022/08/31 10:41:11 upgrade synOCR 1.2.0.12 End preinst ret=[0]
2022/08/31 10:41:11 upgrade synOCR 1.2.0.12 Begin /bin/mkdir -p /volume1/@appstore/synOCR -m 755
2022/08/31 10:41:11 upgrade synOCR 1.2.0.12 End /bin/mkdir -p /volume1/@appstore/synOCR -m 755 ret=[0]
2022/08/31 10:41:11 upgrade synOCR 1.2.0.12 Begin /bin/rm -rf /volume1/@appstore/synOCR
2022/08/31 10:41:11 upgrade synOCR 1.2.0.12 End /bin/rm -rf /volume1/@appstore/synOCR ret=[0]
2022/08/31 10:41:11 upgrade synOCR 1.2.0.12 Begin /bin/mv -f /volume1/@tmp/synopkg/install.XGZ47b/package /volume1/@appstore/synOCR
2022/08/31 10:41:11 upgrade synOCR 1.2.0.12 End /bin/mv -f /volume1/@tmp/synopkg/install.XGZ47b/package /volume1/@appstore/synOCR ret=[0]
2022/08/31 10:41:11 upgrade synOCR 1.2.0.12 Begin /bin/rm -rf /var/packages/synOCR
2022/08/31 10:41:11 upgrade synOCR 1.2.0.12 End /bin/rm -rf /var/packages/synOCR ret=[0]
2022/08/31 10:41:11 upgrade synOCR 1.2.0.12 Begin /bin/mkdir -p /var/packages/synOCR -m 755
2022/08/31 10:41:11 upgrade synOCR 1.2.0.12 End /bin/mkdir -p /var/packages/synOCR -m 755 ret=[0]
2022/08/31 10:41:11 upgrade synOCR 1.2.0.12 Begin /bin/touch /var/packages/synOCR/installing
2022/08/31 10:41:11 upgrade synOCR 1.2.0.12 End /bin/touch /var/packages/synOCR/installing ret=[0]
2022/08/31 10:41:11 upgrade synOCR 1.2.0.12 Begin /bin/mv -f /volume1/@tmp/synopkg/install.XGZ47b/INFO /var/packages/synOCR/INFO
2022/08/31 10:41:11 upgrade synOCR 1.2.0.12 End /bin/mv -f /volume1/@tmp/synopkg/install.XGZ47b/INFO /var/packages/synOCR/INFO ret=[0]
2022/08/31 10:41:11 upgrade synOCR 1.2.0.12 Begin /bin/rm -rf /var/packages/synOCR/scripts
2022/08/31 10:41:11 upgrade synOCR 1.2.0.12 End /bin/rm -rf /var/packages/synOCR/scripts ret=[0]
2022/08/31 10:41:11 upgrade synOCR 1.2.0.12 Begin /bin/mv -f /volume1/@tmp/synopkg/install.XGZ47b/scripts /var/packages/synOCR/scripts
2022/08/31 10:41:11 upgrade synOCR 1.2.0.12 End /bin/mv -f /volume1/@tmp/synopkg/install.XGZ47b/scripts /var/packages/synOCR/scripts ret=[0]
2022/08/31 10:41:11 upgrade synOCR 1.2.0.12 Begin /bin/rm -rf /var/packages/synOCR/WIZARD_UIFILES
2022/08/31 10:41:11 upgrade synOCR 1.2.0.12 End /bin/rm -rf /var/packages/synOCR/WIZARD_UIFILES ret=[0]
2022/08/31 10:41:11 upgrade synOCR 1.2.0.12 Begin /bin/mv -f /volume1/@tmp/synopkg/install.XGZ47b/WIZARD_UIFILES /var/packages/synOCR/WIZARD_UIFILES
2022/08/31 10:41:11 upgrade synOCR 1.2.0.12 End /bin/mv -f /volume1/@tmp/synopkg/install.XGZ47b/WIZARD_UIFILES /var/packages/synOCR/WIZARD_UIFILES ret=[0]
2022/08/31 10:41:11 upgrade synOCR 1.2.0.12 Begin /bin/rm -rf /var/packages/synOCR/conf
2022/08/31 10:41:11 upgrade synOCR 1.2.0.12 End /bin/rm -rf /var/packages/synOCR/conf ret=[0]
2022/08/31 10:41:11 upgrade synOCR 1.2.0.12 Begin /bin/mv -f /volume1/@tmp/synopkg/install.XGZ47b/conf /var/packages/synOCR/conf
2022/08/31 10:41:11 upgrade synOCR 1.2.0.12 End /bin/mv -f /volume1/@tmp/synopkg/install.XGZ47b/conf /var/packages/synOCR/conf ret=[0]
2022/08/31 10:41:15 upgrade synOCR 1.2.0.12 Begin postinst
2022/08/31 10:41:15 upgrade synOCR 1.2.0.12 End postinst ret=[0]
2022/08/31 10:41:15 upgrade synOCR 1.2.0.12 Begin postupgrade
2022/08/31 10:41:15 upgrade synOCR 1.2.0.12 End postupgrade ret=[0]
2022/08/31 10:41:16 (system) trigger synOCR 1.2.0.12 Begin start-stop-status stop
Stopping...
chmod: cannot access '/volume1/Scanner/_log/inotify.log': No such file or directory
2022/08/31 10:41:16 (system) trigger synOCR 1.2.0.12 End start-stop-status stop ret=[0]
2022/08/31 10:41:28 upgrade synOCR 1.2.0.12 Begin preupgrade
2022/08/31 10:41:28 upgrade synOCR 1.2.0.12 End preupgrade ret=[0]
2022/08/31 10:41:28 upgrade synOCR 1.2.0.12 Begin preuninst
sed: couldn't open temporary file /etc/sedJXCZkK: Permission denied
2022/08/31 10:41:28 upgrade synOCR 1.2.0.12 End preuninst ret=[0]
2022/08/31 10:41:28 upgrade synOCR 1.2.0.12 Begin /bin/rm -rf /volume1/@appstore/synOCR
2022/08/31 10:41:28 upgrade synOCR 1.2.0.12 End /bin/rm -rf /volume1/@appstore/synOCR ret=[0]
2022/08/31 10:41:28 upgrade synOCR 1.2.0.12 Begin /bin/rm -rf /volume1/@apptemp/synOCR
2022/08/31 10:41:28 upgrade synOCR 1.2.0.12 End /bin/rm -rf /volume1/@apptemp/synOCR ret=[0]
2022/08/31 10:41:28 upgrade synOCR 1.2.0.12 Begin postuninst
2022/08/31 10:41:28 upgrade synOCR 1.2.0.12 End postuninst ret=[0]
2022/08/31 10:41:28 upgrade synOCR 1.2.0.12 Begin preinst
2022/08/31 10:41:28 upgrade synOCR 1.2.0.12 End preinst ret=[0]
2022/08/31 10:41:29 upgrade synOCR 1.2.0.12 Begin /bin/mkdir -p /volume1/@appstore/synOCR -m 755
2022/08/31 10:41:29 upgrade synOCR 1.2.0.12 End /bin/mkdir -p /volume1/@appstore/synOCR -m 755 ret=[0]
2022/08/31 10:41:29 upgrade synOCR 1.2.0.12 Begin /bin/rm -rf /volume1/@appstore/synOCR
2022/08/31 10:41:29 upgrade synOCR 1.2.0.12 End /bin/rm -rf /volume1/@appstore/synOCR ret=[0]
2022/08/31 10:41:29 upgrade synOCR 1.2.0.12 Begin /bin/mv -f /volume1/@tmp/synopkg/install.Hl3pMl/package /volume1/@appstore/synOCR
2022/08/31 10:41:29 upgrade synOCR 1.2.0.12 End /bin/mv -f /volume1/@tmp/synopkg/install.Hl3pMl/package /volume1/@appstore/synOCR ret=[0]
2022/08/31 10:41:29 upgrade synOCR 1.2.0.12 Begin /bin/rm -rf /var/packages/synOCR
2022/08/31 10:41:29 upgrade synOCR 1.2.0.12 End /bin/rm -rf /var/packages/synOCR ret=[0]
2022/08/31 10:41:29 upgrade synOCR 1.2.0.12 Begin /bin/mkdir -p /var/packages/synOCR -m 755
2022/08/31 10:41:29 upgrade synOCR 1.2.0.12 End /bin/mkdir -p /var/packages/synOCR -m 755 ret=[0]
2022/08/31 10:41:29 upgrade synOCR 1.2.0.12 Begin /bin/touch /var/packages/synOCR/installing
2022/08/31 10:41:29 upgrade synOCR 1.2.0.12 End /bin/touch /var/packages/synOCR/installing ret=[0]
2022/08/31 10:41:29 upgrade synOCR 1.2.0.12 Begin /bin/mv -f /volume1/@tmp/synopkg/install.Hl3pMl/INFO /var/packages/synOCR/INFO
2022/08/31 10:41:29 upgrade synOCR 1.2.0.12 End /bin/mv -f /volume1/@tmp/synopkg/install.Hl3pMl/INFO /var/packages/synOCR/INFO ret=[0]
2022/08/31 10:41:29 upgrade synOCR 1.2.0.12 Begin /bin/rm -rf /var/packages/synOCR/scripts
2022/08/31 10:41:29 upgrade synOCR 1.2.0.12 End /bin/rm -rf /var/packages/synOCR/scripts ret=[0]
2022/08/31 10:41:29 upgrade synOCR 1.2.0.12 Begin /bin/mv -f /volume1/@tmp/synopkg/install.Hl3pMl/scripts /var/packages/synOCR/scripts
2022/08/31 10:41:29 upgrade synOCR 1.2.0.12 End /bin/mv -f /volume1/@tmp/synopkg/install.Hl3pMl/scripts /var/packages/synOCR/scripts ret=[0]
2022/08/31 10:41:29 upgrade synOCR 1.2.0.12 Begin /bin/rm -rf /var/packages/synOCR/WIZARD_UIFILES
2022/08/31 10:41:29 upgrade synOCR 1.2.0.12 End /bin/rm -rf /var/packages/synOCR/WIZARD_UIFILES ret=[0]
2022/08/31 10:41:29 upgrade synOCR 1.2.0.12 Begin /bin/mv -f /volume1/@tmp/synopkg/install.Hl3pMl/WIZARD_UIFILES /var/packages/synOCR/WIZARD_UIFILES
2022/08/31 10:41:29 upgrade synOCR 1.2.0.12 End /bin/mv -f /volume1/@tmp/synopkg/install.Hl3pMl/WIZARD_UIFILES /var/packages/synOCR/WIZARD_UIFILES ret=[0]
2022/08/31 10:41:29 upgrade synOCR 1.2.0.12 Begin /bin/rm -rf /var/packages/synOCR/conf
2022/08/31 10:41:29 upgrade synOCR 1.2.0.12 End /bin/rm -rf /var/packages/synOCR/conf ret=[0]
2022/08/31 10:41:29 upgrade synOCR 1.2.0.12 Begin /bin/mv -f /volume1/@tmp/synopkg/install.Hl3pMl/conf /var/packages/synOCR/conf
2022/08/31 10:41:29 upgrade synOCR 1.2.0.12 End /bin/mv -f /volume1/@tmp/synopkg/install.Hl3pMl/conf /var/packages/synOCR/conf ret=[0]
2022/08/31 10:41:32 upgrade synOCR 1.2.0.12 Begin postinst
2022/08/31 10:41:32 upgrade synOCR 1.2.0.12 End postinst ret=[0]
2022/08/31 10:41:32 upgrade synOCR 1.2.0.12 Begin postupgrade
2022/08/31 10:41:33 upgrade synOCR 1.2.0.12 End postupgrade ret=[0]
2022/08/31 10:41:33 (system) trigger synOCR 1.2.0.12 Begin start-stop-status stop
Stopping...
2022/08/31 10:41:33 (system) trigger synOCR 1.2.0.12 End start-stop-status stop ret=[0]
Verwende synORC 1.2.0
