Hallo!
Meine neue Seagate IronWolf PRO 8 TB Festplatte klackt alle 2-3 Sekunden. Ich habe geprüft, ob EPC disabled ist und das ist der Fall:
Hier zum Anhören:
Datei von filehorst.de laden
Womit hängt das zusammen?
C:\Program Files\Seagate\SeaChest>SeaChest_PowerChoice -d PD2 --deviceInfo
SeaChest_PowerChoice - Seagate drive utilities
Copyright (c) 2017 Seagate Technology LLC, All Rights Reserved
SeaChest_PowerChoice Version: 1.5.0-1_13_2 X86_64
Build Date: Mar 6 2017
Today: Mon May 20 18:34:17 2019
\\.\PhysicalDrive2 - 0004-1ZF11G - - ATA
Model Number: 0004-1ZF11G
Serial Number:
Firmware Revision:
World Wide Name: 5000C500B4F11FDF
Drive Capacity (TB/TiB): 2.20/2.00
Temperature Data:
Current Temperature (C): 24
Highest Temperature (C): 37
Lowest Temperature (C): 22
Power On Time: 1 day 7 hours 15 minutes
Power On Hours: 31.25
MaxLBA: 4294967294
Native MaxLBA: Not Reported
Logical Sector Size (B): 512
Physical Sector Size (B): 512
Sector Alignment: 0
Rotation Rate (RPM): 7200
Form Factor (inch): 3.5
Last DST information:
Time since last DST (hours): 21.25
DST Status/Result: 0x0
DST Test run: 0x1
Interface speed:
Not Reported
Annualized Workload Rate (TB/yr): 2297.60
Total Bytes Read (TB): 8.13
Total Bytes Written (GB): 67.68
Drive Reported Utilization (%): Not Reported
Encryption Support: Not Supported
Cache Size (MiB): 256.00
Read Look-Ahead: Enabled
Write Cache: Enabled
Low Current Spinup: Disabled
SMART Status: Good
ATA Security Information: Supported
Zoned Device Type: Not a Zoned Device
Firmware Download Support: Full, Segmented, Deferred
Specifications Supported:
ACS-3
ACS-2
ATA8-ACS
ATA/ATAPI-7
ATA/ATAPI-6
ATA/ATAPI-5
ATA/ATAPI-4
SATA 3.1
SATA 3.0
SATA 2.6
SATA 2.5
SATA II: Extensions
SATA 1.0a
ATA8-AST
Features Supported:
Sanitize
SATA NCQ
SATA Rebuild Assist
SATA Software Settings Preservation [Enabled]
SATA Device Initiated Power Management
Power Management
Security
SMART [Enabled]
48bit Address
PUIS
GPL
Streaming
Write-Read-Verify
AMAC
EPC
Sense Data Reporting
SCT Write Same
SCT Error Recovery Control
SCT Feature Control
SCT Data Tables
Hier zum Anhören:
