Hello,
Since my german is not so good (i do understand it, if someone will answer in german) im writing in english and i hope someone can help me
I own a DS1812+ now for about a month.
I have a huge collection of astronomical images which are in astronomical FITS format.
I'm programing a script in python to collect image information from FITS header and store that information in a mysql database, but to reed fits images with python i need numpy/scipy (http://scipy.org/Download) and pyfits (http://www.stsci.edu/institute/software_hardware/pyfits) python libraries.
The instalation of libraries in python is usualy simple just executing > python setup.py install, but I'm having difficulties instaling numpy since it requires g77 or f77 and gcc compilers which are not found. Bellow is the error msg i get after trying to install numpy library
Is there a way to install these libraries on Synology?
I appreciate your help with my problem it would realy help me get my data into a database.
Best regards
Jure
sh: /usr/local/i686-linux-gnu/bin/i686-linux-gnu-ccache-gcc: not found
failure.
removing: _configtest.c _configtest.o
Traceback (most recent call last):
File "setup.py", line 214, in <module>
setup_package()
File "setup.py", line 207, in setup_package
configuration=configuration )
File "/volume1/homes/jurez/test/numpy-1.6.2/numpy/distutils/core.py", line 186, in setup
return old_setup(**new_attr)
File "/usr/local/lib/python2.7/distutils/core.py", line 152, in setup
dist.run_commands()
File "/usr/local/lib/python2.7/distutils/dist.py", line 953, in run_commands
self.run_command(cmd)
File "/usr/local/lib/python2.7/distutils/dist.py", line 972, in run_command
cmd_obj.run()
File "/volume1/homes/jurez/test/numpy-1.6.2/numpy/distutils/command/install.py", line 55, in run
r = old_install.run(self)
File "/usr/local/lib/python2.7/distutils/command/install.py", line 563, in run
self.run_command('build')
File "/usr/local/lib/python2.7/distutils/cmd.py", line 326, in run_command
self.distribution.run_command(command)
cmd_obj.run()
File "/volume1/homes/jurez/test/numpy-1.6.2/numpy/distutils/command/build.py", line 37, in run
old_build.run(self)
File "/usr/local/lib/python2.7/distutils/command/build.py", line 127, in run
self.run_command(cmd_name)
cmd_obj.run()
File "/volume1/homes/jurez/test/numpy-1.6.2/numpy/distutils/command/build_src.py", line 152, in run
self.build_sources()
File "/volume1/homes/jurez/test/numpy-1.6.2/numpy/distutils/command/build_src.py", line 163, in build_sources
self.build_library_sources(*libname_info)
File "/volume1/homes/jurez/test/numpy-1.6.2/numpy/distutils/command/build_src.py", line 298, in build_library_sources
sources = self.generate_sources(sources, (lib_name, build_info))
File "/volume1/homes/jurez/test/numpy-1.6.2/numpy/distutils/command/build_src.py", line 385, in generate_sources
source = func(extension, build_dir)
File "numpy/core/setup.py", line 696, in get_mathlib_info
raise RuntimeError("Broken toolchain: cannot link a simple C program")
RuntimeError: Broken toolchain: cannot link a simple C program
Best regards
Jure
