Neue Version: 24.0.2-1543
Adama
05. März 2013
Es gibt eine neue Version des Container Managers (24.0.2-1543). Aber seid nicht zu aufgeregt, außer dass explizit die DSM-Version für dieses Update angegeben wird, konnte ich in der History keinen Unterschied zur letzten Version ausmachen. (Oder hab ich was übersehen?)
(2025-06-24)
Compatibility & Installation
    This version requires DSM7.2.1 and above.
What's New
    Supports using the "docker compose" command in the command line interface (CLI).
    Supports customizing subnet settings for Container Manager.
Fixed Issues
    Fixed an issue where an unexpected error message might show up during project restart, cleanup, or image creation.
    Fixed an issue where duplicating a container with TCP/UDP port settings might fail.
    Fixed an issue where Container Manager version 20.10.23-1437 or earlier might not run properly if manually installed.
    Fixed an issue where moving a shared folder might not release the storage space at its original location.
Anmerkungen:
    This version is released in a staged rollout.
https://www.synology.com/de-de/releaseNote/ContainerManager?model=DS918+&os=DSM&version=7_x_series
