Jan 7 17:28:33 DiskStation kernel: [ 68.920000] md: invalid raid superblock magic on sda5
Jan 7 17:28:33 DiskStation kernel: [ 68.930000] md: sda5 does not have a valid v0.90 superblock, not importing!
Jan 7 17:28:33 DiskStation kernel: [ 68.950000] md: invalid raid superblock magic on sda6
Jan 7 17:28:33 DiskStation kernel: [ 68.950000] md: sda6 does not have a valid v0.90 superblock, not importing!
Jan 7 17:28:33 DiskStation kernel: [ 68.980000] md: invalid raid superblock magic on sda7
Jan 7 17:28:33 DiskStation kernel: [ 68.990000] md: sda7 does not have a valid v0.90 superblock, not importing!
Jan 7 17:28:33 DiskStation kernel: [ 69.020000] md: invalid raid superblock magic on sdb5
Jan 7 17:28:33 DiskStation kernel: [ 69.020000] md: sdb5 does not have a valid v0.90 superblock, not importing!
Jan 7 17:28:33 DiskStation kernel: [ 69.050000] md: invalid raid superblock magic on sdb6
Jan 7 17:28:33 DiskStation kernel: [ 69.060000] md: sdb6 does not have a valid v0.90 superblock, not importing!
Jan 7 17:28:33 DiskStation kernel: [ 69.090000] md: invalid raid superblock magic on sdb7
Jan 7 17:28:33 DiskStation kernel: [ 69.100000] md: sdb7 does not have a valid v0.90 superblock, not importing!
Jan 7 17:28:33 DiskStation kernel: [ 69.150000] md: invalid raid superblock magic on sdc5
Jan 7 17:28:33 DiskStation kernel: [ 69.160000] md: sdc5 does not have a valid v0.90 superblock, not importing!
Jan 7 17:28:33 DiskStation kernel: [ 69.180000] md: invalid raid superblock magic on sdc6
Jan 7 17:28:33 DiskStation kernel: [ 69.190000] md: sdc6 does not have a valid v0.90 superblock, not importing!
Jan 7 17:28:33 DiskStation kernel: [ 69.220000] md: invalid raid superblock magic on sdc7
Jan 7 17:28:33 DiskStation kernel: [ 69.220000] md: sdc7 does not have a valid v0.90 superblock, not importing!
Jan 7 17:28:33 DiskStation kernel: [ 69.300000] md: invalid raid superblock magic on sdd5
Jan 7 17:28:33 DiskStation kernel: [ 69.300000] md: sdd5 does not have a valid v0.90 superblock, not importing!
Jan 7 17:28:33 DiskStation kernel: [ 69.330000] md: invalid raid superblock magic on sdd6
Jan 7 17:28:33 DiskStation kernel: [ 69.330000] md: sdd6 does not have a valid v0.90 superblock, not importing!
Jan 7 17:28:33 DiskStation kernel: [ 69.360000] md: invalid raid superblock magic on sdd7
Jan 7 17:28:33 DiskStation kernel: [ 69.370000] md: sdd7 does not have a valid v0.90 superblock, not importing!
Jan 7 17:28:33 DiskStation kernel: [ 69.390000] md: sda2 has different UUID to sda1
Jan 7 17:28:33 DiskStation kernel: [ 69.400000] md: sdb2 has different UUID to sda1
Jan 7 17:28:33 DiskStation kernel: [ 69.400000] md: sdc2 has different UUID to sda1
Jan 7 17:28:33 DiskStation kernel: [ 69.410000] md: sdd2 has different UUID to sda1
Jan 7 17:28:33 DiskStation kernel: [ 70.900000] VFS: Mounted root (ext2 filesystem) on device 1:0.
Jan 7 17:28:33 DiskStation kernel: [ 71.740000] ds411j_synobios: module license 'Synology Inc.' taints kernel.
Jan 7 17:28:33 DiskStation kernel: [ 71.740000] Disabling lock debugging due to kernel taint
Jan 7 17:28:33 DiskStation kernel: [ 71.800000] correction with 0x0f
Jan 7 17:28:33 DiskStation kernel: [ 71.850000] 2016-1-7 16:28:26 UTC
Jan 7 17:28:33 DiskStation kernel: [ 71.860000] Brand: Synology
Jan 7 17:28:33 DiskStation kernel: [ 71.860000] Model: DS-411j
Jan 7 17:28:33 DiskStation kernel: [ 71.860000] This is default settings: set group disks wakeup number to 1, spinup time deno 1
Jan 7 17:28:33 DiskStation kernel: [ 71.930000] synobios: unload
Jan 7 17:28:33 DiskStation kernel: [ 72.050000] Got empty serial number. Generate serial number from product.
Jan 7 17:28:33 DiskStation kernel: [ 76.360000] EXT3-fs: md0: couldn't mount because of unsupported optional features (240).
Jan 7 17:28:33 DiskStation kernel: [ 76.360000] EXT2-fs: md0: couldn't mount because of unsupported optional features (240).
Jan 7 17:28:33 DiskStation kernel: [ 76.400000] VFS: Mounted root (ext4 filesystem) on device 9:0.
Jan 7 17:28:36 DiskStation s70_synocheckhw: fan/fan_parsing_fan_module.c:52 Out of range.
Jan 7 17:28:47 DiskStation kernel: [ 93.670000] <30>systemd-udevd[1376]: starting version 204
Jan 7 17:28:52 DiskStation kernel: [ 97.210000] init: syno-auth-check main process (1304) killed by TERM signal
Jan 7 17:28:56 DiskStation kernel: [ 102.100000] cesadev_init(bf190000)
Jan 7 17:28:56 DiskStation kernel: [ 102.330000] mvCesaInit: sessions=10240, queue=64, pSram=f0000000
Jan 7 17:28:59 DiskStation kernel: [ 104.930000] encryptfs using the OCF package.
Jan 7 17:29:04 DiskStation kernel: [ 109.980000] correction with 0x0f
Jan 7 17:29:04 DiskStation kernel: [ 110.040000] 2016-1-7 16:29:4 UTC
Jan 7 17:29:04 DiskStation kernel: [ 110.050000] Brand: Synology
Jan 7 17:29:04 DiskStation kernel: [ 110.050000] Model: DS-411j
Jan 7 17:29:04 DiskStation kernel: [ 110.050000] This is default settings: set group disks wakeup number to 1, spinup time deno 1
Jan 7 17:29:04 DiskStation synonetseqadj: conf_maxlanport_get.c:22 Failed to SLIBCFileGetKeyValue(/etc.defaults/synoinfo.conf,maxlanport)
Jan 7 17:29:06 DiskStation interface-catcher: eth0 (dhcp) is added
Jan 7 17:29:06 DiskStation interface-catcher: lo (inet 127.0.0.1 netmask 255.0.0.0 ) is added
Jan 7 17:29:21 DiskStation kernel: [ 127.120000] 0: w=1 pa=0 pr=4 m=1 a=2 r=4 op1=0 op2=0
Jan 7 17:29:21 DiskStation kernel: [ 127.130000] 3: w=2 pa=0 pr=4 m=1 a=2 r=4 op1=0 op2=0
Jan 7 17:29:21 DiskStation kernel: [ 127.130000] 2: w=3 pa=0 pr=4 m=1 a=2 r=4 op1=0 op2=0
Jan 7 17:29:21 DiskStation kernel: [ 127.140000] 1: w=4 pa=0 pr=4 m=1 a=2 r=4 op1=0 op2=0
Jan 7 17:29:21 DiskStation kernel: [ 127.140000] raid5: raid level 5 set md3 active with 4 out of 4 devices, algorithm 2
Jan 7 17:29:21 DiskStation kernel: [ 127.150000] RAID5 conf printout:
Jan 7 17:29:21 DiskStation kernel: [ 127.150000] --- rd:4 wd:4
Jan 7 17:29:21 DiskStation kernel: [ 127.160000] disk 0, o:1, dev:sdb6
Jan 7 17:29:21 DiskStation kernel: [ 127.160000] disk 1, o:1, dev:sda6
Jan 7 17:29:21 DiskStation kernel: [ 127.160000] disk 2, o:1, dev:sdd6
Jan 7 17:29:21 DiskStation kernel: [ 127.170000] disk 3, o:1, dev:sdc6
Jan 7 17:29:21 DiskStation kernel: [ 127.250000] 0: w=1 pa=0 pr=4 m=1 a=2 r=4 op1=0 op2=0
Jan 7 17:29:21 DiskStation kernel: [ 127.250000] 3: w=2 pa=0 pr=4 m=1 a=2 r=4 op1=0 op2=0
Jan 7 17:29:21 DiskStation kernel: [ 127.260000] 2: w=3 pa=0 pr=4 m=1 a=2 r=4 op1=0 op2=0
Jan 7 17:29:21 DiskStation kernel: [ 127.260000] 1: w=4 pa=0 pr=4 m=1 a=2 r=4 op1=0 op2=0
Jan 7 17:29:21 DiskStation kernel: [ 127.270000] raid5: raid level 5 set md4 active with 4 out of 4 devices, algorithm 2
Jan 7 17:29:21 DiskStation kernel: [ 127.270000] RAID5 conf printout:
Jan 7 17:29:21 DiskStation kernel: [ 127.280000] --- rd:4 wd:4
Jan 7 17:29:21 DiskStation kernel: [ 127.280000] disk 0, o:1, dev:sdd7
Jan 7 17:29:21 DiskStation kernel: [ 127.280000] disk 1, o:1, dev:sdc7
Jan 7 17:29:21 DiskStation kernel: [ 127.290000] disk 2, o:1, dev:sdb7
Jan 7 17:29:21 DiskStation kernel: [ 127.290000] disk 3, o:1, dev:sda7
Jan 7 17:29:21 DiskStation kernel: [ 127.500000] 0: w=1 pa=0 pr=4 m=1 a=2 r=4 op1=0 op2=0
Jan 7 17:29:21 DiskStation kernel: [ 127.510000] 3: w=2 pa=0 pr=4 m=1 a=2 r=4 op1=0 op2=0
Jan 7 17:29:21 DiskStation kernel: [ 127.510000] 2: w=3 pa=0 pr=4 m=1 a=2 r=4 op1=0 op2=0
Jan 7 17:29:21 DiskStation kernel: [ 127.520000] 1: w=4 pa=0 pr=4 m=1 a=2 r=4 op1=0 op2=0
Jan 7 17:29:21 DiskStation kernel: [ 127.520000] raid5: raid level 5 set md2 active with 4 out of 4 devices, algorithm 2
Jan 7 17:29:21 DiskStation kernel: [ 127.530000] RAID5 conf printout:
Jan 7 17:29:21 DiskStation kernel: [ 127.530000] --- rd:4 wd:4
Jan 7 17:29:21 DiskStation kernel: [ 127.530000] disk 0, o:1, dev:sda5
Jan 7 17:29:21 DiskStation kernel: [ 127.540000] disk 1, o:1, dev:sdb5
Jan 7 17:29:21 DiskStation kernel: [ 127.540000] disk 2, o:1, dev:sdc5
Jan 7 17:29:21 DiskStation kernel: [ 127.540000] disk 3, o:1, dev:sdd5
Jan 7 17:29:22 DiskStation spacetool.shared: raid_allow_rmw_check.c:48 fopen failed: /usr/syno/etc/.rmw.md3
Jan 7 17:29:22 DiskStation spacetool.shared: raid_allow_rmw_check.c:48 fopen failed: /usr/syno/etc/.rmw.md2
Jan 7 17:29:22 DiskStation spacetool.shared: raid_allow_rmw_check.c:48 fopen failed: /usr/syno/etc/.rmw.md4
Jan 7 17:29:24 DiskStation reg_ssdp_service: nginx_deploy.cpp:574 Failed to open share memory, No such file or directory
Jan 7 17:29:24 DiskStation spacetool.shared: spacetool.c:3010 [Info] Old vg path: [/dev/vg1000], New vg path: [/dev/vg1000], UUID: [3qWLUK-hIAS-UgP0-HhnG-09u2-R6nf-RRfxFE]
Jan 7 17:29:24 DiskStation spacetool.shared: spacetool.c:3017 [Info] Activate all VG
Jan 7 17:29:26 DiskStation spacetool.shared: spacetool.c:3028 Activate LVM [/dev/vg1000]
Jan 7 17:29:26 DiskStation spacetool.shared: spacetool.c:3071 space: [/dev/vg1000]
Jan 7 17:29:27 DiskStation spacetool.shared: spacetool.c:3097 space: [/dev/vg1000], ndisk: [12]
Jan 7 17:29:28 DiskStation dhcp-client: started on eth0
Jan 7 17:29:29 DiskStation kernel: [ 135.120000] nf_conntrack version 0.5.0 (1851 buckets, 7404 max)
Jan 7 17:29:34 DiskStation spacetool.shared: hotspare_repair_config_set.c:36 Failed to hup synostoraged
Jan 7 17:29:35 DiskStation kernel: [ 141.680000] init: dhcp-client (eth0) main process (4016) killed by TERM signal
Jan 7 17:29:36 DiskStation dhcp-client: stopped on eth0
Jan 7 17:29:36 DiskStation dhcp-client: started on eth0
