DSM 6.x und darunter 7.1-42661 Update 2
odol26
28. Apr 2014
Moin moin,
das update ist komplett an mir vorbei gegangen, wurde aber auch noch nicht automatisch angeboten.
(2022-06-01)
Important notes​
  1. Your Synology NAS may not notify you of this DSM update because of the following reasons. If you want to update your DSM to this version now, please click here to manually update it. Only Synology NAS with DSM 7.1 installed can be updated to this version.
    • The update is not available in your region yet. The update is expected to be available for all regions within the next few days, although the time of release in each region may vary slightly.
    • Your DSM is working fine without having to update. The system evaluates service statuses and system settings to determine whether it needs to update to this version.
  2. This update will restart your Synology NAS.
Compatibility & Installation​
  1. When an SSD's firmware version doesn't support the S.M.A.R.T test, the system will disable related functions.
Fixed Issues​
  1. Fixed an issue where the out-of-band port couldn't function properly when users configured Link Aggregation with only the ports on the external network card.
  2. Fixed an issue where users couldn't configure access via QuickConnect for Synology Drive Server because they couldn't find the package at Control Panel > External Access > QuickConnect > Advanced.
Kurt-oe1kyw
10. Mai 2015
Reaktionen: AndiHeitzer
