Fehlermeldung von postfix
HarryPotter
24. Aug. 2007
HAbe von Zeit zu Zeit (so alle 2-3 Tage folgenden Eintrag im Log:
Mar 11 10:58:19 postfix/smtpd[25869]: warning: 114.32.154.114: address not listed for hostname giveme500.info
Keine Ahunng was das ist. Ich habe diese Adresse nun für postfwd ebenfalls erfasst, nützt aber nichts.
http://www.postfix.org/faq.html#paranoid
warning: xxx.xxx.xxx.xxx: address not listed for hostname yyy.yyy.yyy
Postfix uses hostnames in its junk mail and mail relay controls. This means that in theory someone could be motivated to set up bogus DNS information, in order to get past your junk mail or mail relay controls.
When Postfix looks up the SMTP client hostname for the SMTP client IP address, then Postfix also checks if the SMTP client IP address is listed under the SMTP client hostname.
If the SMTP client IP address is not listed under the SMTP client hostname, then Postfix concludes that the SMTP client hostname does not belong to the SMTP client IP address, and ignores the SMTP client hostname. A warning is logged, so that you can find out why an SMTP client is or is not stopped by your junk mail or mail relay checks.
You could contact the people who maintain the SMTP client's DNS records, and explain to them that each IP address needs one PTR record, and that this one PTR record needs a matching A record.
Some people read the RFCs such that one IP address can have multiple PTR records, but that makes PTR records even less useful than they already are. And in any case, having multiple names per IP address only worsens the problem of finding out the SMTP client hostname.
Ich vermute mal dieser Zustellungsversuch kommt gar nicht bis zu Postfwd, sondern wird weiter vorne verworfen
dies bedeutet das Postfix keine gültige DNS Auflösung für giveme500.info mit der mitgelieferten IP erfragen konnte.
Wenn ich mir die A Records für giveme500.info anschauen, so sehe auch keine IP Adresse 114.32.154.114 die hierfür hinterlegt ist.
Nun kommt es auf deine Postfix Konfiguration an ob die Mail abgewiesen oder zugestellt wird.
Eine Abweisung siehst Du wenn in den folgenden Zeilen ein "NOQUEUE: reject:" zu dieser IP zu finden ist.
Deine Postfix Konfiguration kannst Du übringends über die Konsole mit postconf -n ausgeben lassen.
In messages sind keine weiteren Einträge zu diesen Ereignissen zu finden, grummel grummel
Hmm,
zu erkennen ist der Vorgang in diesem Status der Zustellung nur an der smtpd Prozess ID.
Da der SMTP Dialog noch nicht beendet ist, ist die Email noch nicht auf der Platte abgelegt und hat somit auch keine eindeutige Queue ID erhalten (macht die Suche aufwendiger).
Genauers kann ich Dir nur sagen wenn ich deine postfix conf sehe, oder die Logs mal durchforste.
Gruss
