moved docker app from volume 1 to volume 2 and all configs gone / help?
pedalracer
28. Jun 2019
I followed the guides I found on the net on how to move packages from one volume to another.
I did so and now all settings for docker (and surveillance station are gone..).
I had an Hzperbackup of docker app and other apps but it does not restore my apps as they were.
1st I stopped all packages, then in sharedfolders I changed from volume1 to volume2. restarted....
no more settings in apps.
I restored via Hyperbackup and it told me all restored fine. Docker config and data I assumed.
However none is restored. All my images and their configs to not appear.
What can I do?
haydibe
12. Apr 2016
I would strongly suggest to move the docker package back to the old volume.
Moving docker's data-root folder is not easy. If the old and new volume have different filesystems, it may happen that a different (docker) storage driver is used, which will render all metadata + images + containers useless. Switching between BTRFS and EXT4 will have an impact on the storage driver!
Please share the outputs of the shell commands:
sudo -i # become root
docker info | grep -iE 'root dir|storage'
mount | grep /dev/mapper
Does `Docker Root Dir` match the current volume?
Are the fs types identical?
