- 19. Feb. 2016
Auf einem Linuxsystem bekommt man mit
die Smartwerte angezeigt.
Auf der Syno bekomme ich
Allerdings kann das DSM die Smartwerte per Platte retrieven. Warum geht das nicht per native Linux Command smartctl?
sudo smartctl --all /dev/sda
smartctl 6.5 (build date Apr 2 2019) [x86_64-linux-4.4.59+] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Vendor: WDC
Product: WD20EARX-00PASB0
Revision: AB51
User Capacity: 2,000,398,934,016 bytes [2.00 TB]
Logical block size: 512 bytes
LU is fully provisioned
Logical Unit id: 0x50014ee20620eef6
Serial number: WD-WCAZA8864990
Device type: disk
Local Time is: Mon Sep 16 21:22:54 2019 CEST
SMART support is: Unavailable - device lacks SMART capability.
Current Drive Temperature: 0 C
Drive Trip Temperature: 0 C
Error Counter logging not supported
[GLTSD (Global Logging Target Save Disable) set. Enable Save with '-S on']
Device does not support Self Test logging
