- 17. Dez. 2014
Wie Puppetmaster schon schrieb, probiere es mal über die Konsole (per SSH mit Putty).
Disk /dev/sdc: 9.1 TiB, 10000831348736 bytes, 19532873728 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: 023CEEA2-82D4-4BBA-9C02-257BF8EEDDDC
Device Start End Sectors Size Type
/dev/sdc1 2048 4982527 4980480 2.4G Linux RAID
/dev/sdc2 4982528 9176831 4194304 2G Linux RAID
/dev/sdc3 9437184 19532668927 19523231744 9.1T Linux RAID
Disk /dev/sdd: 9.1 TiB, 10000831348736 bytes, 19532873728 sectors
Disklabel type: gpt
Disk identifier: 44F5B3DD-E68F-4BD7-A6E4-F95A475BADC6
/dev/sdd1 2048 4982527 4980480 2.4G Linux RAID
/dev/sdd2 4982528 9176831 4194304 2G Linux RAID
/dev/sdd3 9437184 19532668927 19523231744 9.1T Linux RAID
Disk /dev/sda: 9.1 TiB, 10000831348736 bytes, 19532873728 sectors
Disklabel type: gpt
Disk identifier: AC6C0686-4871-4FBE-BE56-914BCB3C112A
/dev/sda1 2048 4982527 4980480 2.4G Linux RAID
/dev/sda2 4982528 9176831 4194304 2G Linux RAID
/dev/sda3 9437184 19532668927 19523231744 9.1T Linux RAID
Disk /dev/sdb: 9.1 TiB, 10000831348736 bytes, 19532873728 sectors
Disklabel type: gpt
Disk identifier: 13FBE65F-2BAB-42A8-BF20-17B5FE9EF35B
/dev/sdb1 2048 4982527 4980480 2.4G Linux RAID
/dev/sdb2 4982528 9176831 4194304 2G Linux RAID
/dev/sdb3 9437184 19532668927 19523231744 9.1T Linux RAID
Disk /dev/md0: 2.4 GiB, 2549940224 bytes, 4980352 sectors
Disk /dev/md1: 2 GiB, 2147418112 bytes, 4194176 sectors
Disk /dev/zram0: 298 MiB, 312475648 bytes, 76288 sectors
Units: sectors of 1 * 4096 = 4096 bytes
Sector size (logical/physical): 4096 bytes / 4096 bytes
Disk /dev/zram1: 298 MiB, 312475648 bytes, 76288 sectors
Disk /dev/zram2: 298 MiB, 312475648 bytes, 76288 sectors
Disk /dev/zram3: 298 MiB, 312475648 bytes, 76288 sectors
Disk /dev/md2: 27.3 TiB, 29987680813056 bytes, 58569689088 sectors
I/O size (minimum/optimal): 65536 bytes / 196608 bytes
Disk /dev/synoboot: 120 MiB, 125829120 bytes, 245760 sectors
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x36f3f60f
Device Boot Start End Sectors Size Id Type
/dev/synoboot1 * 63 32129 32067 15.7M 83 Linux
/dev/synoboot2 32130 224909 192780 94.1M 83 Linux
Personalities : [linear] [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
md2 : active raid5 sda3[0] sdd3[3] sdc3[2] sdb3[4]
29284844544 blocks super 1.2 level 5, 64k chunk, algorithm 2 [4/4] [UUUU]
md1 : active raid1 sda2[0] sdb2[1] sdc2[2] sdd2[3]
2097088 blocks [4/4] [UUUU]
md0 : active raid1 sda1[0] sdb1[1] sdc1[2] sdd1[3]
2490176 blocks [4/4] [UUUU]
unused devices: <none>
/dev/md2:
Version : 1.2
Creation Time : Thu Sep 21 17:13:42 2017
Raid Level : raid5
Array Size : 29284844544 (27928.20 GiB 29987.68 GB)
Used Dev Size : 9761614848 (9309.40 GiB 9995.89 GB)
Raid Devices : 4
Total Devices : 4
Persistence : Superblock is persistent
Update Time : Wed May 23 06:42:56 2018
State : clean
Active Devices : 4
Working Devices : 4
Failed Devices : 0
Spare Devices : 0
Layout : left-symmetric
Chunk Size : 64K
Name : DiskStation:2 (local to host DiskStation)
UUID : 6515391f:2a5bdfec:c40421c2:7009aeba
Events : 37228
Number Major Minor RaidDevice State
0 8 3 0 active sync /dev/sda3
4 8 19 1 active sync /dev/sdb3
2 8 35 2 active sync /dev/sdc3
3 8 51 3 active sync /dev/sdd3
hier mal ein paar mehr Infos:
root@DiskStation:~# cat /proc/mdstat
Rich (BBCode):Personalities : [linear] [raid0] [raid1] [raid10] [raid6] [raid5] [raid4] md2 : active raid5 sda3[0] sdd3[3] sdc3[2] sdb3[4] 29284844544 blocks super 1.2 level 5, 64k chunk, algorithm 2 [4/4] [UUUU] md1 : active raid1 sda2[0] sdb2[1] sdc2[2] sdd2[3] 2097088 blocks [4/4] [UUUU] md0 : active raid1 sda1[0] sdb1[1] sdc1[2] sdd1[3] 2490176 blocks [4/4] [UUUU] unused devices: <none>
Bei mir und einer 916+ sind die Nummern auch durcheinander...
Na super, also alles gut aber nix funktioniert![]()
Das kannst du ausschliessen ;-)
Using volume group(s) on command line.
No volume groups found.
Hast du dir den Tipp/ Post#2 von Dil88 schon mal angesehen?
