Virtual DSM Manager - Neue Version
stulpinger
27. Mai 2009
Virtual DSM Manager wurde heute upgedated
Neuer Name: Virtual Machine Manager
Es ist nun möglich iso-Dateien (zB Windows) als Systemimage einzubinden
Weitere Tests (Windowsinstallation) kann ich erst am Abend machen
Windows 10 Installation startet, findet aber momentan keine Festplatte
LG aus Kärnten
amarthius
Super-Moderator
Teammitglied
03. Jun 2009
[h=3]Compatibility[/h][h=5]Applied Models[/h]
  • 17-series: FS3017, FS2017, RS4017xs+, RS18017xs+, RS3617xs+, RS3617xs, RS3617RPxs, DS3617xs, DS1817+, DS1517+
  • 16-series: RS18016xs+, RS2416+, RS2416RP+, DS916+, DS416play, DS716+II, DS716+, DS216+II, DS216+
  • 15-series: RC18015xs+, DS3615xs, DS2415+, DS1815+, DS1515+, RS815+, RS815RP+, DS415+
  • 14-series: RS3614xs+, RS3614xs, RS3614RPxs
  • 13-series: RS10613xs+, RS3413xs+
  • 12-series: DS3612xs, RS3412xs, RS3412RPxs
  • 11-series: DS3611xs, RS3411xs, RS3411RPxs
[h=3]Release notes[/h]What's new
  1. Virtual Machine Manager is an upgrade from Virtual DSM Manager.
  2. Supports Windows / Linux virtual machines.
  3. Supports importing OVA files to create virtual machines.
  4. Supports importing VMDK, VDI, VHD, VHDX, and IMG virtual disks.
  5. Added Beta Feedback page.
  6. Enhanced the stability of Virtual DSM when High Availability is enabled.
Fixed issues
  1. Fixed an issue where the status display of virtual machines might be incorrect.
  2. Minor bug fixes.
Limitations
  1. DS716+II, DS716+, DS216+II, DS216+, RS815(RP)+, DS415+ and models with less than 4GB of memory cannot run virtual machines, but can still be deployed as storage and quorum servers in a cluster.
  2. VirtIO SCSI driver is required during the Windows installation process. Please download Guest Tool for Virtual Machine Manager at Download Center.
Known Issues
  1. There is display corruption with Fedora 20. This issue will be fixed in a later version.
  2. Some Linux operating systems will repeat the installation process after rebooting. This process can only be completed after the ISO file has been unmounted. This issue will be fixed in a later version.
stulpinger
27. Mai 2009
Habs jetzt auch geschafft :eek:
Thonav
16. Feb 2014
Bei einer DS nutze ich ein Bond - scheint damit nicht zu funktionieren. Mitteilung "keine verfügbaren Netzwerke". Muss ich jetzt das Bond auflösen? Mit phpVirtualBox war das auch mit Bond problemlos möglich.
geimist
04. Jan 2012
Danke Flotho für den Link. Sonst wäre ich da schon nicht weitergekommen.
Kommt ihr mit dem Microsoft Remote Desktop auf eine VM?
Ich habe keine Möglichkeit gefunden, eine Portweiterleitung auf 3389 der VM anzulegen. Das WebVCN kann ja nicht das Ziel sein …
Flotho
29. Okt 2012
Ich komme ganz normal per RDP auf die VM. RDP aktivieren in Windows und eventuell Firewall deaktivieren.
m0useP4d
08. Okt 2012
Kann jemand vllt. was zu Performance zu phpVirtualBox sagen?
DKeppi
01. Apr 2011
Verstehe ich das richtig, dass man seine VM's von Virtualbox exportieren und im VMM importieren kann?
Das wäre ja perfekt! :)
Viell. wage ich das Update auf 6.1.1 wenn meine 916+ da ist!!!
geimist
04. Jan 2012
Ich konnte die .ova's zwar importieren, sie ließen sich aber nicht starten, da beim booten keine Festplatte erkannt wurde. Im VMM war sie aber korrekt erkannt. Hier wäre es sicherlich notwendig, die SCSI-Treiber noch einzubinden. Ich habe mir erst einmal eine neue Win7pro VM erstellt.
geimist
04. Jan 2012
Ich herhalte immer nur ein "Connection refused". Welche IP nutzt du? Ich habe nur die IP der DS. Der VM wird keine separate gegeben.
Edit:
was mich auch wundert: ich habe in der VM keinen Netzwerkzugriff. Die Treiber für die Netzwerkkarte konnten nicht gefunden werden. Wie habt ihr das gelöst?
iLion
07. Okt 2008
Synology hat noch eine eigene ISO mit den Treibern auf den Servern. Da sind auch Gäste-Treiber für Windows drin.
BlackWolf
20. Aug 2009
Wow... ging ja doch schneller von Synology als erwartet.
Muss nur erst mal durchblicken wie es funktioniert, so ein bissel anders als Virtualbox oder HyperV.
Blicke nur mit dem Netzwerk nicht ganz durch. Finde so was wie NAT oder Bridge nicht...
Wie bekomme ich die VM in Netz/Internet?
Update:
Ok.. scheint wohl nur über die 2te NIC zu gehen. Das ist wohl auch die Einschränkung für die Compatibility list.
Warum kein NAT oder Bridge bleibt wohl nur Synos Geheimnis ;-)
Thonav
16. Feb 2014
Keine Ahnung - irgendwie kann ich keine VM installieren, da keine verfügbaren Netzwerkverbindungen/Netzwerkschnittstellen. Muss ich mein 4fach-Bond auf einer DS1515+ dazu auflösen?
m0useP4d
08. Okt 2012
Also ich finde nun weder die Virtual DSM (hab früher mal ausprobiert) noch die neue Virtual Machine Manager für DS415+ :confused:
Auf https://www.synology.com/de-de/dsm/app_packages/Virtualization ist auch nichts von DS415+ zu sehen, sehr schade
Eingesetzte Modelle
Serie 17: FS3017, FS2017, RS4017xs+, RS18017xs+, RS3617xs+, RS3617xs, RS3617RPxs, DS3617xs, DS1817+, DS1517+
Serie 16: RS18016xs+, RS2416+, RS2416RP+, DS916+
Serie 15: RC18015xs+, DS3615xs, DS2415+, DS1815+, DS1515+, RS815+, RS815RP+
Serie 14: RS3614xs+, RS3614xs, RS3614RPxs
Serie 13: RS10613xs+, RS3413xs+
Serie 12: DS3612xs, RS3412xs, RS3412RPxs
Serie 11: DS3611xs, RS3411xs, RS3411RPxs
Hier direkt aber zu bekommen: http://download.synology.com/download/Package/spk/Virtualization/2.0.0-7933/ und manuell installierbar!
Thonav
16. Feb 2014
Danke @geimist - Bond ist nun aufgelöst. Problem ist nun, dass ich diesen virtuellen Festplattentreiber nicht installieren kann. Wenn ich die iso einbinde und das Win Setup starte, findet das Setup zwar die iso Datei im virtuellen CD Laufwerk, aber in den Verzeichnissen scheinbar keine gültigen scsi Treiber....
Wie wird Windows installiert? ;)
geimist
04. Jan 2012
Ich hatte das noch mit der ISO von Flotho gemacht. Darin gab es einen Ordner (irgendetwas mit SCSI) und mit diesen Treibern hatte der Installer dann auch die Festplatten erkannt.
