Yea! Supi, da freu ich mich drauf.Habe diese Nacht eine neue Version von VirtualBox (4.3.22-98236) kompiliert, bin nur noch nicht ganz fertig.
Darum freue ich mich hier auch etwas aktiv zu sein
arch="x86 cedarview avoton bromolow"
@DKeppi, was hast du eigentlich alles verändert das es auf der echten Synology funktioniert? Habe leider keine.
Arch in der INFO und die Symlinks?
Exception Object(
[message:protected] => The virtual machine 'Test' has terminated unexpectedly during startup with exit code 1 (0x1)
[string:Exception:private] =>
[code:protected] => 0
[file:protected] => /volume1/web/phpvirtualbox/lib/vboxconnector.php
[line:protected] => 2393
[trace:Exception:private] => Array
[0] => Array
[file] => /volume1/web/phpvirtualbox/lib/vboxconnector.php
[line] => 928
[function] => remote_progressGet
[class] => vboxconnector
[type] => ->
[args] => Array
[0] => Array
[progress] => f86ab4988da2632f-00000000000000fd
[_persist] => Array
[vboxHandle] => f86ab4988da2632f-00000000000000fb
[fn] => progressGet
[1] => Array
[file] => /volume1/web/phpvirtualbox/lib/ajax.php
[line] => 309
[function] => __call
[type] => ->
[args] => Array
[0] => progressGet
[1] => Array
[0] => Array
[_persist] => Array
[fn] => progressGet
[1] => Array
[0] => Array
[data] => Array
[responseData] => Array
[info] => Array
[completed] => 1
[canceled] =>
[description] => Starting VM
[operationDescription] => Creating process for virtual machine "Test" (headless)
[timeRemaining] => Array
[timeElapsed] => Array
[days] => 16495
[hours] => 15
[minutes] => 44
[seconds] => 22
[percent] => 0
[success] => 1
[key] => 720f4c5f2f9c111d81c1aa4a7f53b5bc
[errors] => Array
[persist] => Array
[messages] => Array
[2] => Array
[line] => 309
[function] => progressGet
[type] => ->
[args] => Array
[0] => Array
[_persist] => Array
[fn] => progressGet
[1] => Array
[0] => Array
[data] => Array
[info] => Array
[completed] => 1
[canceled] =>
[days] => 16495
[hours] => 15
[minutes] => 44
[seconds] => 22
[percent] => 0
[success] => 1
[errors] => Array
[persist] => Array
[messages] => Array
[previous:Exception:private] =>
