DDNS Updater Invalid file format when updating initthirdparty V1.7 003 on DSM 5.1-5004
fa355115
29. Jan. 2012
Hi there,
Trying to update this initthirdparty package to 1.7 003 within DSM5.1-5004 but getting an "Invalid file format" error message.
Something wrong in the package ?
Many Thanks !
... and I even see when clicking on the DDNS updater to open it, it shows some core instead of opening the software.
Can you please advise ?
Many Thanks !!
Hi there,
Many Thanks !
I test the Init_3rdparty package installation on my test DS again and all went fine, no errors. Have you updated Init_3rdparty via package center list or manually? Something went wrong with your installation. Checks whether an uninstall and then install Init_3rdparty helps instead of upgrade.
It seems Init_3rdparty ist not running and therefore DDNS updater shows only the source code on startup. Pls refresh/clear browser cache, maybe a reboot is required.
Thanks, I will try that. In the mean time I see that OvH, which is my provided why I used ddns, is part of the list of the supported providers on the Nas. Has it been added recently because I am sure it was not supported In te past and his is the reason why I used DDNS
