ich habe folgendes gemacht:
Wie binde ich das so ein, dass das für immer gilt und nicht nach jedem Neustart wieder verworfen ist?
Danke
PHP:
flip@ds106x ~/ssods/ssods-usbswap $ sudo mkdir /swap
Password:
flip@ds106x ~/ssods/ssods-usbswap $ sudo mount /dev/sdf4 /swap/
Found partition: b (Win95 FAT32)
flip@ds106x ~/ssods/ssods-usbswap $ sudo ./mkfile 4096 10240 /swap/swapfile
file=/swap/swapfile, blocksize=4096, blocks=10240, size=40.0 MB
flip@ds106x ~/ssods/ssods-usbswap $ sudo mkswap -v /swap/swapfile
Setting up swapspace version 0, size = 41938944 bytes
flip@ds106x ~/ssods/ssods-usbswap $ sudo chmod 0600 /swap/swapfile
flip@ds106x ~/ssods/ssods-usbswap $ sudo ./swapon -v -p 1 /swap/swapfile
swapon on /swap/swapfile
swapon: warning: /swap/swapfile has insecure permissions 0644, 0600 suggested
flip@ds106x ~/ssods/ssods-usbswap $ cat /proc/swaps
Filename Type Size Used Priority
/dev/hda2 partition 393584 72036 -1
/swap/swapfile file 40956 0 1
flip@ds106x ~/ssods/ssods-usbswap $ sudo ./swapoff -v /dev/hda2
swapoff on /dev/hda2
/swap/swapfile file 40956 17012 1
Danke
