DSM 6.x und darunter Dsm 4.3-3827
Phil88
01. Okt 2007
Hallo Zusammen,
ich habe eben eine Mail von Synology bekommen, aber irgendwie blick ich das nicht ganz. Ich habe noch die Version DSM 4.3-3810 installiert, reicht es wenn ich einfach die aktuelle Version installiere oder muß ich diesen Reinstall durchführen?
Gruß Phil
DSM Important Update
Dear Synology users,
Synology® confirmed known security issues (reported as CVE-2013-6955 and CVE-2013-6987) which would cause compromise to file access authority in DSM. An updated DSM version resolving these issues has been released accordingly.
The followings are possible symptoms to appear on affected DiskStation and RackStation:
Exceptionally high CPU usage detected in Resource Monitor:
CPU resource occupied by processes such as dhcp.pid, minerd, synodns, PWNED, PWNEDb, PWNEDg, PWNEDm, or any processes with PWNED in their names
Appearance of non-Synology folder:
An automatically created shared folder with the name “startup”, or a non-Synology folder appearing under the path of “/root/PWNED”
Redirection of the Web Station:
“Index.php” is redirected to an unexpected page
Appearance of non-Synology CGI program:
Files with meaningless names exist under the path of “/usr/syno/synoman”
Appearance of non-Synology script file:
Non-Synology script files, such as “S99p.sh”, appear under the path of “/usr/syno/etc/rc.d”
If users identify any of above situation, they are strongly encouraged to do the following:
For DiskStation or RackStation running on DSM 4.3, please follow the instruction here to REINSTALL DSM 4.3-3827.
For DiskStation or RackStation running on DSM 4.0, it’s recommended to REINSTALL DSM 4.0-2259 or onward from Synology Download Center.
For DiskStation or RackStation running on DSM 4.1 or DSM 4.2, it’s recommended to REINSTALL DSM 4.2-3243 or onward from Synology Download Center.
For other users who haven’t encountered above symptoms, it is recommended to go to
DSM > Control Panel > DSM Update page, update to versions above to protect DiskStation from malicious attacks.
Synology has taken immediate actions to fix vulnerability at the point of identifying malicious attacks. As proliferation of cybercrime and increasingly sophisticated malware evolves, Synology continues to casting resources mitigating threats and dedicates to providing the most reliable solutions for users. If users still notice their DiskStation behaving suspiciously after being upgraded to the latest DSM version, please contact security@synology.com.
Sincerely,
Synology Development Team
TheTwist76
21. Apr 2013
wie es in der Mail steht nur wenn Du betroffen bist. (If users identify any of above situation, they are strongly encouraged to do the following)
Wenn nicht dann reicht ein normales Update über die DSM aus, wie es in der Mail steht :
Wie man das prüfen kann steht auch hier im Forum http://www.synology-forum.de/showthread.html?50468-Aktive-Hackangriffe-auf-DSM-Versionen-kleiner-4.3.-3810-Update-3
Ein Reinstall sollte man durchführen damit die Daten die die Hacker abgelegt haben gelöscht werden. Bei einem Reinstall (Link in der Mail) Wird nur die Systempartition gelöscht nicht aber die Daten Partition.
Grüße
TS
Phil88
01. Okt 2007
danke für den Hinweis.
Phil
Darkdevil
08. Feb 2013
Betrifft es auch die User die noch die DSM 4.2-3211 installiert haben, müssen die auch updaten?
Phil88
01. Okt 2007
Mal so eine Frage, hätte nicht das Antivirus Programm der DS etwas erkennen können?
Philip
Darkdevil
08. Feb 2013
Ich frage mich, wie da überhaupt jemand reinkommen kann. Die Diskstations sind doch mit Benutzer/Passwort, DOS und IP-Autoblock geschützt. Wenn da jemand durchkommt müsste man doch auch den Anmeldeversuch sehen.
TheTwist76
21. Apr 2013
auf folgender Seite werden die Fehler genauer beschrieben was die Angreifer machen können. Laut Synology gibt es hierzu zwei Common Vulnerabilities and Exposures CVE-2013-6955, CVE-2013-6987
CVE-2013-6955
CVE-2013-6987
Diese Sicherheitslücke können Angreifer / Hacker ausnutzen. Und somit der Absicherung durch Benutzer/Password umgehen.
Viele Grüße
TS
