DDNS Updater Startprobleme beim Programmaufruf
Netranger
23. Nov. 2008
habe meine ds von 4.0 auf 4.2 anheben müssen und siehe da nun macht mir der ddns-updater probleme beim start:
den screen sehe ich - sonst nichts
<?php // ****************************************************************** // // * ddnsupdater - 3rdparty DDNS updater (webUI for ddclient) * // // * Modul: ddnsupdater (index) * // // * -------------------------------------- * // // * Version 1.24-001 - 25/02/2013 * // // * for more information check the changelog * // // ******************************************************************* // //$start = time(); putenv('HTTP_COOKIE='.$_SERVER['HTTP_COOKIE']); putenv('REMOTE_ADDR='.$_SERVER['REMOTE_ADDR']); $user = exec('/usr/syno/synoman/webman/modules/authenticate.cgi'); if ($user === '') { exit("403 Forbidden"); } print '<script type="text/javascript" src="scripts/check_appprivilege.js"></script>'; $spkver = "1.24-001"; include_once("include/config.php"); if ($_GET["debug"] == 1) { exec($ddnspath.'/ddnscmd.sh debug',$debugret); print '<script type="text/javascript">window.open("/webman/3rdparty/ddnsupdater/ddnsdebug.zip","top=200,left=600,width=400,height=300")</script>'; print 'After you saved the debug file, you can close this window'; die; } include_once("include/get_provider.php"); exec('PATH="/opt/bin:/opt/sbin:$PATH"',$ret); exec('/bin/ps | grep ddclient | grep -v grep', $ddnsstatus); exec($ddnsbin.' --help | tail -n 5 | head -n 1 | cut -d " " -f 3-',$ddnsversion); exec($ddnspath.'/ddnscmd.sh dsmversion 2>&1',$dsmversion); exec($ddnspath.'/ddnscmd.sh dsmlanguage 2>&1',$dsmlanguage); exec($ddnspath.'/ddnscmd.sh languages 2>&1',$ddnslanguages); exec($ddnspath.'/ddnscmd.sh checkstart',$ddnsperl); exec($ddnspath.'/ddnscmd.sh next-check 2>&1',$ddnscheck); if ($ddnscheck[0] == "" && $ddnsstatus[0] == "") { $sek = -1; } elseif (intval($ddnscheck[0]) > 0 && $ddnsstatus != "") { $checktext = "sleeping"; $sek = intval($ddnscheck[0]); } elseif (intval($ddnscheck[0]) == 0 && $ddnsstatus != "") { $checktext = "connecting"; $sek = 5; } if (file_exists($ddnsconffile)) { $ddnsconfig = @file($ddnsconffile); while ($z < count($ddnsconfig)) { if ($begin == false && strstr($ddnsconfig[$z],"# DDNS Provider Parameters Section")) { // search for start of values break; } elseif ($begin == false && !strstr($ddnsconfig[$z],"##") && substr($ddnsconfig[$z],0,1) != chr(10)) { $global_temp = explode("=",trim($ddnsconfig[$z])); $conf_global[$global_temp[0]]=$global_temp[1]; } $z++; } } else { $conf_global['daemon'] = 0; } ?> <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"> <html xmlns="http://www.w3.org/1999/xhtml" > <head> <link rel="stylesheet" type="text/css" href="extjs/resources/css/ext-all.css"> <link rel="stylesheet" type="text/css" href="extjs/resources/css/xtheme-gray.css"> <link rel="stylesheet" type="text/css" href="scripts/ddnsupdater.css"> <link rel="shortcut icon" href="favicon.ico"> <meta http-equiv="Content-Type" content="text/html; charset=UTF-8" /> <meta http-equiv="pragma" content="no-cache"><meta http-equiv="expires" content="0"><meta http-equiv="cache-control" content="no-cache"> <script type="text/javascript" src="extjs/adapter/ext/ext-base.js"></script> <script type="text/javascript" src="extjs/ext-all.js"></script> <script language="javascript" type="text/javascript"> function getUrlVars(){ var vars = [], hash; var hashes = window.location.href.slice(window.location.href.indexOf('?') + 1).split('&'); for(var i = 0; i < hashes.length; i++){ hash = hashes.split('='); vars.push(hash[0]); vars[hash[0]] = hash[1]; } return vars; } function convert_iso2syno(searchlang) { var langconv = Array(); langconv['de'] = 'ger'; //german langconv['en'] = 'enu'; //english US langconv['zh'] = 'chs'; //chinese simplified langconv['cs'] = 'csy'; //czech langconv['jp'] = 'jpn'; //japan langconv['ko'] = 'krn'; //korean langconv['da'] = 'dan'; //danish langconv['fr'] = 'fre'; //french langconv['it'] = 'ita'; //italian langconv['nl'] = 'nld'; //dutch langconv['no'] = 'nor'; //norwegian langconv['pl'] = 'plk'; //polish langconv['ru'] = 'rus'; //russian langconv['sp'] = 'spn'; //spanish langconv['sv'] = 'sve'; //swedish langconv['hu'] = 'hun'; //hungarian langconv['tr'] = 'trk'; //turkish langconv['pt'] = 'ptg'; //portuguese european if (langconv[searchlang] != '' && langconv[searchlang] != undefined){ return langconv[searchlang]; } else { return 'enu'; } } function convert_syno2iso(searchlang) { var langconv = Array(); langconv['ger'] = 'de'; //german langconv['enu'] = 'en'; //english US langconv['chs'] = 'zh'; //chinese simplified langconv['csy'] = 'cs'; //czech langconv['jpn'] = 'jp'; //japan langconv['krn'] = 'ko'; //korean langconv['dan'] = 'da'; //danish langconv['fre'] = 'fr'; //french langconv['ita'] = 'it'; //italian langconv['nld'] = 'nl'; //dutch langconv['nor'] = 'no'; //norwegian langconv['plk'] = 'pl'; //polish langconv['rus'] = 'ru'; //russian langconv['spn'] = 'sp'; //spanish langconv['sve'] = 'sv'; //swedish langconv['hun'] = 'hu'; //hungarian langconv['trk'] = 'tr'; //turkish langconv['ptg'] = 'pt'; //portuguese european if (langconv[searchlang] != '' && langconv[searchlang] != undefined){ return langconv[searchlang]; } else { return 'en'; } } var language = '<?php print $dsmlanguage[0];?>'; var urllang = getUrlVars()['lang']; if (urllang != undefined && urllang != '') { var ddnslang = convert_iso2syno(urllang); } else if (language == 'def') { if (navigator.appName == 'Netscape') { var language = navigator.language.substr(0,2); } else { var language = navigator.browserLanguage.substr(0,2); } var ddnslang = convert_iso2syno(language); } else if (language == undefined || language == '') { ddnslang = 'enu'; } else { ddnslang = language; } document.write('<script type="text/javascript" src="extjs/locale/ext-lang-' + convert_syno2iso(ddnslang) + '.js"\></script\>'); document.write('<script type="text/javascript" src="scripts/punycode.min.js"\></script\>'); document.write('<script type="text/javascript" src="scripts/ddnsupdater.js"\></script\>'); document.write('<script type="text/javascript" src="texts/enu/gui.js"\></script\>'); document.write('<script type="text/javascript" src="texts/' + ddnslang + '/gui.js"\></script\>'); </script> </head><title>DDNS updater</title><body> <!--[if lt IE 7]><style> /* style for IE 6 + IE5.5 + IE5.0 */ .gainlayout { height: 0; } </style><![endif]--> <!--[if IE 7]><style> .gainlayout { zoom: 1;} </style><![endif]--> <script type="text/javascript" src="scripts/functions.js"></script> <script language="javascript" type="text/javascript"> document.getElementsByTagName("body")[0].style.cursor = 'auto'; var intervaltime=<?php echo $conf_global['daemon'];?>; var checktext='<?php echo $checktext;?>'; var sek=<?php echo $sek;?>; var spkver='<?php echo $spkver;?>'; var ddclientver='<?php print $ddnsversion[0];?>'; var use_ssl = '<?php print $ddnsperl[0];?>'; var dsmversion = '<?php print $dsmversion[0];?>'; var syslogmessage = '<?php print $syslogmessage;?>'; var languages = '<?php for($i=0;$i<count($ddnslanguages);$i++){print $ddnslanguages[$i]." ";}?>'; <?php if (count($provider_protocol) == 0) get_provider(); reset($provider_name); $providerstore = "\nExt.namespace('Ext.provider');\n"; $providerstore .= "Ext.provider.names = [\n"; $protocolstore = "\nExt.namespace('Ext.protocol');\n"; $protocolstore .= "Ext.protocol.names = [\n"; $pc = 0; while(list($protocolname,$providername) = each($provider_name)) { $providerstore .= "['".$protocolname."','".$providername."','".$provider_server[$protocolname]."'],\n"; if ($pc < count($provider_protocol)) $protocolstore .= "['".$protocolname."','".$provider_comment[$protocolname]."'],\n"; $pc++; } $providerstore = substr($providerstore,0,-2)."\n"; $protocolstore = substr($protocolstore,0,-2)."\n"; $providerstore .= "];\n"; $protocolstore .= "];\n"; print $providerstore; print $protocolstore; ?> </script> <div id="ddnsmain"></div><div style="display:none"><div id="spkversionstext">SPK version <?php print $spkver;?></div></div> <?php //echo date("s",time() - $start);?> </body></html>
Init_3rdparty installiert und gestartet? Browsercache löschen.
installiert schon, aber nicht gestartet.
da stand doch dass man das nicht benötigt und ehrlich gesagt hat das vor sw-hub auf 4.2 auch tadelfein funktioniert.
noch was ist mir bereits vorher aufgefallen: habe 2 einträge aus der liste gelöscht und wurden auch nicht mehr angezeigt.
in der loganzeige rechts oben werden die gelöschten als nicht erreichbar angezeigt.
hast di eine eine idee wie ich das wieder in die gänge bekomme?
danke - mike
hallo qtip,
also der tipp init3rdparty dürfte geholfen haben, denn nun läuft alles wieder.
aber nochmals auf die gelöshten einträge zurückzukommen.
wie kann das sein wenn die gar nicht mehr in der liste stehen dass fehlereinträge von versuchen generiert werden oder lag das an der DS ?
l.g. mike
Du hast das mit Init_3rdpartyHelp verwechselt, das wird für die aktuelle Version nicht mehr benötigt, Init_3rdparty benötigt man für alle Apps, bei denen PHP verwendet wird. Das wird dir aber angezeigt, wenn du ein App installierst und etwas fehlen sollte.
Mit "Loganzeige oben rechts" meinst du bestimmt die Benachrichtigungsicon vom DSM. Wenn du Einträge löschst, dann sollte für diese Einträge auch kein Aktualisierungsversuch vom DDNS updater statfinden. Die Meldung kam evtl. noch bevor du sie gelöscht hattest.
okay, ich behalt das im auge und melde mich wenn´s probleme gibt.
danke dir nochmals für die schnelle antwort :cool:
und noch was: den fehler hatte ich nur an einer vistamaschine - browsercache geleert und es ging wieder :( naja, jetzt weis man es !
gruß - mike
