- 17. Juli 2013
das hier scheint mir ein relevanter Abschnitt (die # sind nur Maskierungen) :
Jul 16 20:17:47 kernel: [ 1542.630000] sd 2:0:0:0:
rejecting I/O to offline device
Jul 16 20:17:47 kernel: [ 1542.650000] Aborting journal on device sdq1.
Jul 16 20:17:47 kernel: [ 1542.650000] sd 2:0:0:0: rejecting I/O to offline device
Jul 16 20:17:47 kernel: [ 1542.660000] sd 2:0:0:0: rejecting I/O to offline device
Jul 16 20:17:47 kernel: [ 1542.670000] sd 2:0:0:0: rejecting I/O to offline device
Jul 16 20:17:47 kernel: [ 1542.700000] ext3_abort called.
Jul 16 20:17:47 kernel: [ 1542.700000] EXT3-fs error (device sdq1): ext3_journal_start_sb: Detected aborted journal
Jul 16 20:17:47 kernel: [ 1542.710000] Remounting filesystem read-only
Jul 16 20:17:47 kernel: [ 1542.710000] JBD: Detected IO errors while flushing file data on sdq1
Jul 16 20:17:47 synolocalbkp: localbkp_copy_file.c:156 Fail to write file /volumeUSB1/usbshare/SYNA_1/######/######/######/######/######!! errno=[30/Read-only file system]
Jul 16 20:17:47 synolocalbkp: localbkp_copy_file.c:100 Failed to open file [/volumeUSB1/usbshare/SYNA_1/######/######/######/######/######.###], errno=[30/Read-only file system]
Jul 16 20:17:47 synolocalbkp: localbkp_upload_share_data.c:146 utime(2) error directory:/volumeUSB1/usbshare/SYNA_1/######/######, errno=[30/Read-only file system]
Jul 16 20:17:48 kernel: [ 1543.110000] sd 2:0:0:0: rejecting I/O to offline device
Jul 16 20:17:48 synolocalbkp: main.c:371 SYNOLocalBkpMoveFile() failed.
Jul 16 20:17:48 kernel: [ 1543.140000] EXT3-fs error (device sdq1): ext3_find_entry: reading directory #16385 offset 0
Jul 16 20:17:49 backup.cgi: SYNOReadOneSectorFromDev(56): failed to open device [/dev/sdq] (errno = 6)
Jul 16 20:17:55 backup.cgi: SYNOReadOneSectorFromDev(56): failed to open device [/dev/sdq] (errno = 6)
Jul 16 20:18:01 backup.cgi: SYNOReadOneSectorFromDev(56): failed to open device [/dev/sdq] (errno = 6)
Jul 16 20:18:07 backup.cgi: SYNOReadOneSectorFromDev(56): failed to open device [/dev/sdq] (errno = 6)
Jul 16 20:18:12 backup.cgi: SYNOReadOneSectorFromDev(56): failed to open device [/dev/sdq] (errno = 6)
Jul 16 20:18:18 backup.cgi: SYNOReadOneSectorFromDev(56): failed to open device [/dev/sdq] (errno = 6)
Jul 16 20:18:23 backup.cgi: SYNOReadOneSectorFromDev(56): failed to open device [/dev/sdq] (errno = 6)
Jul 16 20:18:29 backup.cgi: SYNOReadOneSectorFromDev(56): failed to open device [/dev/sdq] (errno = 6)
Jul 16 20:18:35 backup.cgi: SYNOReadOneSectorFromDev(56): failed to open device [/dev/sdq] (errno = 6)
Jul 16 20:18:41 backup.cgi: SYNOReadOneSectorFromDev(56): failed to open device [/dev/sdq] (errno = 6)
Jul 16 20:18:48 backup.cgi: SYNOReadOneSectorFromDev(56): failed to open device [/dev/sdq] (errno = 6)
Jul 16 20:18:54 backup.cgi: SYNOReadOneSectorFromDev(56): failed to open device [/dev/sdq] (errno = 6)
Jul 16 20:19:00 backup.cgi: SYNOReadOneSectorFromDev(56): failed to open device [/dev/sdq] (errno = 6)
Jul 16 20:19:27 kernel: [ 1642.410000] sd 2:0:0:0: rejecting I/O to offline device
Jul 16 20:19:31 kernel: [ 1646.610000] sd 2:0:0:0: rejecting I/O to offline device
Jul 16 20:21:34 kernel: [ 1769.600000] sd 2:0:0:0: rejecting I/O to offline device
Jul 16 20:21:52 kernel: [ 1787.570000] __journal_remove_journal_head: freeing b_committed_data
Jul 16 20:21:52 kernel: [ 1787.630000] usb 1-1: lock for hub EH
Jul 16 20:21:52 kernel: [ 1787.910000] usb 1-1: unlock for hub EH
Jul 16 20:21:52 kernel: [ 1788.020000] hub 1-1:1.0: hub_port_status failed (err = -19)
Jul 16 20:21:52 kernel: [ 1788.030000] hub 1-1:1.0: hub_port_status failed (err = -19)
Jul 16 20:21:52 kernel: [ 1788.040000] hub 1-1:1.0: activate --> -19
Jul 16 20:21:53 kernel: [ 1788.490000] Got empty serial number. Generate serial number from product.
Jul 16 20:21:53 kernel: [ 1788.990000] usb 1-1.1: device descriptor read/64, error -32
Jul 16 20:21:53 kernel: [ 1789.180000] usb 1-1.1: device descriptor read/64, error -32
Jul 16 20:21:54 kernel: [ 1789.450000] usb 1-1.1: device descriptor read/64, error -32
Jul 16 20:21:54 kernel: [ 1789.640000] usb 1-1.1: device descriptor read/64, error -32
Jul 16 20:21:54 kernel: [ 1789.870000] usb 1-1.1: device descriptor read/8, error -71
Jul 16 20:21:54 kernel: [ 1790.010000] usb 1-1.1: device descriptor read/8, error -71
Jul 16 20:21:54 kernel: [ 1790.240000] usb 1-1.1: device descriptor read/8, error -71
Jul 16 20:21:55 kernel: [ 1790.380000] usb 1-1.1: device descriptor read/8, error -71
Jul 16 20:21:55 kernel: [ 1790.490000] hub 1-1:1.0: unable to enumerate USB device on port 1
Jul 16 20:21:55 hotplugd: ##### ACTION:remove
Jul 16 20:21:55 hotplugd: DEVICE:/proc/bus/usb/001/003
Jul 16 20:21:55 hotplugd: DEVPATH:1-1.1:1.0
Jul 16 20:21:55 hotplugd: SUBSYSTEM:usb
Jul 16 20:21:55 hotplugd: INTERFACE:8/6/80
Jul 16 20:21:55 hotplugd: DEVICE:/proc/bus/usb/001/002
Jul 16 20:21:55 hotplugd: DEVPATH:1-1:1.0
Jul 16 20:21:55 hotplugd: INTERFACE:9/0/0
Jul 16 20:21:55 hotplugd: ##### ACTION:add
Jul 16 20:21:55 hotplugd: DEVICE:/proc/bus/usb/001/004
Jul 16 20:21:55 hotplugd: hotplugd.c:912 ##### complete device hotplug!!
Jul 16 20:21:59 hotplugd: usb_get_device_id.c:56 failed get usb id Vendor=0000, ProdID=0000, SN=d6a3ebcbfbd5e7a5f6a3
Jul 16 20:21:59 hotplugd: hotplugd.c:1102 failed get usb device id from usb config, DEVICE=/proc/bus/usb/000/000
Jul 16 20:21:59 hotplugd: ##### ACTION:remove
Jul 16 20:21:59 hotplugd: DEVNAME:sdq
Jul 16 20:21:59 hotplugd: DEVICE:/proc/bus/usb/000/000
Jul 16 20:21:59 hotplugd: DEVPATH:sdq
Jul 16 20:21:59 hotplugd: SUBSYSTEM:block
Jul 16 20:21:59 hotplugd: PHYSDEVPATH:/devices/platform/orion-ehci.0/usb1/1-1/1-1.1/1-1.1:1.0/host2/target2:0:0/2:0:0:0
Jul 16 20:21:59 hotplugd: hotplugd.c (1534) ==== USB disk [sdq] plugged out====
Jul 16 20:21:59 hotplugd: SYNOReadOneSectorFromDev(56): failed to open device [/dev/sdq] (errno = 6)
Jul 16 20:21:59 hotplugd: volume_parts_info_get_by_dev.c:318 failed to get disk '/dev/sdq' size
Jul 16 20:21:59 scemd: modules/usbcopy.c:55 USBCopy - Unknown Signal: 12
Jul 16 20:22:01 kernel: [ 1796.570000] ext3_abort called.
Jul 16 20:22:01 kernel: [ 1796.580000] EXT3-fs error (device sdq1): ext3_put_super: Couldn't clean up the journal
Jul 16 20:22:56 externaldevices.cgi: airprint_lib.cpp:102 Failed to download driver list.
Jul 16 20:22:56 externaldevices.cgi: externaldevices.cpp:1101 Failed to load driver list.
Jul 16 20:23:03 s2s_service.cgi: s2s_service.cpp (98) no any section if synoS2S.info is empty.
Jul 16 20:23:15 s2s_sharepair.cgi: s2s_sharepair.cpp (67) no any section if synoS2S.info is empty.
Jul 16 20:23:19 s2s_service.cgi: s2s_service.cpp (98) no any section if synoS2S.info is empty.
Jul 16 20:23:42 PkgSynoMan.cgi: pkgcurltool.cpp:221 Failed to curl perform, code=6, err=Couldn't resolve host name
Jul 16 20:25:04 PkgSynoMan.cgi: pkgcurltool.cpp:221 Failed to curl perform, code=6, err=Couldn't resolve host name
Jul 16 20:26:25 PkgSynoMan.cgi: pkgcurltool.cpp:221 Failed to curl perform, code=6, err=Couldn't resolve host name
Jul 16 20:26:26 PkgSynoMan.cgi: pkgcurltool.cpp:330 Failed to curl perform, https://payment.synology.com/api/getPackageList.php
