senderversteller
- 10. Dez. 2015
services:
mailarchive-app:
image: s1t5/mailarchiver:latest
container_name: mailarchiver
restart: unless-stopped
security_opt:
- no-new-privileges:true
environment:
# Database Connection
- ConnectionStrings__DefaultConnection=Host=postgres;Database=MailArchiver;Username=mailuser;Password=54545454545;
# Authentication Settings
- Authentication__Username=admin
- Authentication__Password=1234567
- Authentication__SessionTimeoutMinutes=60
- Authentication__CookieName=MailArchiverAuth
# MailSync Settings
- MailSync__IntervalMinutes=15
- MailSync__TimeoutMinutes=60
- MailSync__ConnectionTimeoutSeconds=180
- MailSync__CommandTimeoutSeconds=300
- MailSync__AlwaysForceFullSync=false
- MailSync__IgnoreSelfSignedCert=false
# BatchRestore Settings
- BatchRestore__AsyncThreshold=50
- BatchRestore__MaxSyncEmails=150
- BatchRestore__MaxAsyncEmails=50000
- BatchRestore__SessionTimeoutMinutes=30
- BatchRestore__DefaultBatchSize=50
# BatchOperation Settings
- BatchOperation__BatchSize=50
- BatchOperation__PauseBetweenEmailsMs=50
- BatchOperation__PauseBetweenBatchesMs=250
# Selection Settings
- Selection__MaxSelectableEmails=250
# Npgsql Settings
- Npgsql__CommandTimeout=900
# Upload Settings for MBox and EML files
- Upload__MaxFileSizeGB=10
- Upload__KeepAliveTimeoutHours=4
- Upload__RequestHeadersTimeoutHours=2
# TimeZone Settings
- TimeZone__DisplayTimeZoneId=Europe/Berlin
# Database Maintenance Settings (Optional)
- DatabaseMaintenance__Enabled=false
- DatabaseMaintenance__DailyExecutionTime=02:00
- DatabaseMaintenance__TimeoutMinutes=30
# Logging Settings (Optional - defaults to Information level)
- Logging__LogLevel__Default=Information
- Logging__LogLevel__Microsoft_AspNetCore=Warning
- Logging__LogLevel__Microsoft_EntityFrameworkCore_Database_Command=Warning
ports:
- "5065:5000"
networks:
- postgres
volumes:
- ./data-protection-keys:/app/DataProtection-Keys
depends_on:
postgres:
condition: service_healthy
postgres:
image: postgres:17-alpine
container_name: postgres-db
security_opt:
environment:
POSTGRES_DB: MailArchiver
POSTGRES_USER: mailuser
POSTGRES_PASSWORD:12345
volumes:
- ./postgres-data:/var/lib/postgresql/data
networks:
- postgres
healthcheck:
test: ["CMD-SHELL", "pg_isready -U mailuser -d MailArchiver"]
interval: 10s
timeout: 5s
retries: 5
start_period: 10s
networks:
postgres:
Wenn kein Eintrag getätigt wird, erstellt der Container ein eigenes Bridgenetzwerk. Wenn man Network-Mode: Bridge angibt, wird der Container im Standard-Bridge-Netzwerk hinzugefügt. Das Gleiche gilt auch für den Eintrag host. Beim Standard-Bridge-Netzwerk können sich die Container nicht untereinander über den Hostnamen unterhalten, weil sie voneinander abgekapselt sind. Das geht dann aber notfalls über die IP der DS. Ein separates Netzwerk kann bei einem Stack mit mehreren Containern hilfreich sein. Allerdings nutze ich eine Datenbank für alle Container, weshalb ich diese Datenbank außerhalb des Stacks/Projektes ausgelagert habe, was den Dump und die Sicherung dieser erleichtert. Ein Container kann ja mehren Docker Netzwerken angehören, wodurch diese dann auch über den Hostnamen angesprochen werden können. Dieser Tage habe ich schon etwas dazu geschrieben. Wenn es dich interessiert, wirst du es finden. Lies dich in die Docker-Dokumentation ein! Es ist alles gut dokumentiert.Wie steht es um die "network-mode: host oder bridge"
braucht man diese nicht?
Danke für deine Erläuterung.Dieser Tage habe ich schon etwas dazu geschrieben. Wenn es dich interessiert, wirst du es finden. Lies dich in die Docker-Dokumentation ein! Es ist alles gut dokumentiert.
Hierfür habe ich eine Lösung gefunden:... auch die IMAP Einrichtung zu meinem eigenen Mailplus Server (über lokale IP oder domain) bekomme ich nicht eingerichtet. In Thunderbird (am PC) kann ich mich mit dem Mailplus Server per IMAP verbinden.
Auch hier würde ich gerne einen Tipp bekommen. Ich benutze dieselben Anmeldedaten wie unter Thunderbird (meine eigene Domain, Synology User mit Passwort, Mailadresse ist die, die im Mailplus Server eingetragen ist)
Also das Problem liegt an der fehlenden Aktivierung von IPv6 im Container Manager (dafür gibt es ein Skript von 007revad). Zusätzlich muss beim Netzwerk des Containers IPv6 aktiviert werden.Hierfür habe ich eine Lösung gefunden:
Mailarchiver kommt wohl mit IPv6 nicht klar (IPv6 only). Ich habe mal eine IPv4 über meinen vServer getunnel: siehe da, die Verbindung wird aufgebaut.
Als Change request @s1t5 : soll ich das als issue in Github eintragen?
Outlook personal accounts (sprich kein M365 Business) sowie auch Hotmail sind aktuell leider nicht möglich, da Microsoft hier keine Basic Authentifizierung mehr für den IMAP Abruf zulässt.
