- 04. Jan. 2012
Quellverzeichnisse sind wie gesagt leer, weil alle angelegten Konfigurationen leer sind.synOCR run at DSM7 or above
➜ check admin permissions: ok
➜ check docker group and permissions: ok [docker:x:65540:synOCR]
Error: duplicate column name: search_nearest_date
Error: duplicate column name: date_search_method
Error: duplicate column name: clean_up_spaces
synOCR wurde gestartet ...
Bitte warten, bis die Dateien fertig abgearbeitet wurden.
Error: no such column: img2pdf
! ! ! Quellverzeichnis oder Berechtigung in der Konfiguration prüfen ! ! !
Programmlauf wird beendet.
failed! (target file is empty or not available)create und moved_to. Wir müssen mal gucken, ob wir hier an Stelle von create close_write nehmen. Das könnte dein Problem lösen. Ich hoffe nur, dass es keine Seiteneffekte zu anderen Szenarien birgt./usr/syno/synoman/webman/3rdparty/synOCR/input_monitor.sh) folgende Änderung vornehmen in Zeile 27:nohup inotifywait --fromfile "${monitored_folders}" -e moved_to -e create --monitor --timeout -1 |
nohup inotifywait --fromfile "${monitored_folders}" -e moved_to -e close_write --monitor --timeout -1 |
/usr/syno/synoman/webman/3rdparty/synOCR/input_monitor.sh stop/usr/syno/synoman/webman/3rdparty/synOCR/input_monitor.sh start access file or directory contents were read
modify file or directory contents were written
attrib file or directory attributes changed
close_write file or directory closed, after being opened in writeable mode
close_nowrite file or directory closed, after being opened in read-only mode
close file or directory closed, regardless of read/write mode
open file or directory opened
moved_to file or directory moved to watched directory
moved_from file or directory moved from watched directory
move file or directory moved to or from watched directory
move_self A watched file or directory was moved.
create file or directory created within watched directory
delete file or directory deleted within watched directory
delete_self file or directory was deleted
unmount file system containing file or directory unmounted
ja genau. Nutze die Version 1.2.0.5 und inotify.Gehe ich recht in der Annahme, dass du die 'neue' Ordnerüberwachung in Verbindung mit inotifywait nutzt?
habe die Zeile geändert und damit scheint es jetzt zu funktionieren. Werde ich die Tage weiter beobachten, aber sieht erst mal gut ausnohup inotifywait --fromfile "${monitored_folders}" -e moved_to -e close_write --monitor --timeout -1 |
create zu close_write (#2.669)--output-type pdfa
--output-type pdfa-2
Nein, hatte ich nicht.@Syngen :
Hattest du in der bisherigen Version Metadaten mit dem ExifTool schreiben lassen? Blieb dort der PDF/A-Standard erhalten?
Scheint wohl wirklich an den Metadaten gelegen zu haben.
Ich hab die Beta mal für alle korrigiert (Version 1.2.0.7):Damit funktioniert es jetzt wieder.
Ich werde hier nochmal nachbessern müssen. Aufgrund eines fehlenden Kommas wurden in der letzten Version gar keine Metadaten geschrieben, weshalb auch die PDF/A-Eigenschaft erhalten blieb. Nach der Korrektur passt es wieder nicht mit PDF/A.Bitte teste mal diese Version mit einer kleinen Korrektur:
