Ja, ich habe die DS rebootet.
Ich habe die DS mehrfach gebootet. Auch die Win7 Clients und auch den Linux Client.
Ich habe in /var/log gestöbert. Dabei bin ich über die messages Datei gestolpert. Hier ein Auszug eines Boot Vorgangs von heute morgen:
May 10 06:01:09 kernel: [ 58.798528] md: md2: set sda3 to auto_remap [0]
May 10 06:01:09 kernel: [ 58.803148] md: md2: set sde3 to auto_remap [0]
May 10 06:01:09 kernel: [ 58.807679] md: md2: set sdd3 to auto_remap [0]
May 10 06:01:09 kernel: [ 58.812213] md: md2: set sdc3 to auto_remap [0]
May 10 06:01:09 kernel: [ 58.816743] md: md2: set sdb3 to auto_remap [0]
May 10 06:01:09 kernel: [ 59.034231] 0: w=1 pa=0 pr=5 m=1 a=2 r=5 op1=0 op2=0
May 10 06:01:09 kernel: [ 59.039202] 4: w=2 pa=0 pr=5 m=1 a=2 r=5 op1=0 op2=0
May 10 06:01:09 kernel: [ 59.044231] 3: w=3 pa=0 pr=5 m=1 a=2 r=5 op1=0 op2=0
May 10 06:01:09 kernel: [ 59.049197] 2: w=4 pa=0 pr=5 m=1 a=2 r=5 op1=0 op2=0
May 10 06:01:09 kernel: [ 59.054168] 1: w=5 pa=0 pr=5 m=1 a=2 r=5 op1=0 op2=0
May 10 06:01:09 kernel: [ 59.059133] raid5: raid level 5 set md2 active with 5 out of 5 devices, algorithm 2
May 10 06:01:09 kernel: [ 59.066793] RAID5 conf printout:
May 10 06:01:09 kernel: [ 59.070018] --- rd:5 wd:5
May 10 06:01:09 kernel: [ 59.072727] disk 0, o:1, dev:sda3
May 10 06:01:09 kernel: [ 59.076126] disk 1, o:1, dev:sdb3
May 10 06:01:09 kernel: [ 59.079525] disk 2, o:1, dev:sdc3
May 10 06:01:09 kernel: [ 59.082928] disk 3, o:1, dev:sdd3
May 10 06:01:09 kernel: [ 59.086327] disk 4, o:1, dev:sde3
May 10 06:01:09 spacetool: spacetool.c:2084 [Info] Activate all VG
May 10 06:01:09 dhcpcd[2097]: dhcpReboot: do not want cache
May 10 06:01:11 dhcpcd[2108]: dhcpReboot: do not want cache
May 10 06:01:12 s10_synocheckinfo: s10_synocheckinfo.c:907 SLIBCFileSetKeyValue([/etc.defaults/synoinfo.conf], [supplang], [enu,cht,chs,krn,
ger,fre,ita,spn,jpn,dan,nor,sve,nld,rus,plk,ptb,ptg,hun,trk,csy]) fail.(0x0B00)
May 10 06:01:12 dhcpcd[2097]: client.c(1560)HUP ddnsd result: return code = 256
May 10 06:01:12 dhcpcd[2097]: FileSetLine(468) (ERR_WRITE_FAILED)
May 10 06:01:12 dhcpcd[2097]: bound ip, lease time 180000 secs. close socket 8
May 10 06:01:12 s30_synocheckuser: CheckSmbConf(823): fflush(pfTmp) failed!
May 10 06:01:12 s42_synocheckgrp: SYNOICheckLocalGrp(264): system(szCommand=/bin/cp -f "/etc/group" "/etc/group_chk.tmp" > /dev/null 2>&1) f
ailed!
May 10 06:01:19 scemd: scemd.c:125 fan_type=3, raid_type=1, led_type=3, thermal_type=1, fanctrl_type=1, auto_poweron_type=1, dual_power_type
=1, usbcopy_type=2, fan_number=2, ebox_type=1, pis_type=0, rtc_type=1
May 10 06:01:21 scemd: modules/fan_speed_adjust_common.c:163 Type: INTERNAL Fan Mode: LOW
May 10 06:01:21 scemd: modules/raid_sys_volume_check.c:163 MD0 active disks 5, designed disks 5
May 10 06:01:21 scemd: modules/raid_sys_volume_check.c:163 MD1 active disks 5, designed disks 5
May 10 06:01:21 scemd: modules/disk_hibernation.c:429 Force hibernation enable, idle minutes 10
May 10 06:01:22 synocheckshare: share_db_build.c:178 section type is unexpected! iSecType=-1
May 10 06:01:22 synocheckshare: share_db_build.c:321 ShareDBSetOne() failed! synoerr=0x2200
May 10 06:01:22 synocheckshare: share_db_dump.c:358 fflush failed!! errno=28/No space left on device
May 10 06:01:22 synocheckshare: share_map_set.c:76 Failed to get share1 from /usr/syno/etc/smb.conf, ret=0, errno=0xB500
May 10 06:01:22 synocheckshare: share_set.c:704 Failed to set share right map: [share1], errno=0x2000
May 10 06:01:22 synocheckshare: share_restore.c:131 Restore share [share1] is ok!!
May 10 06:01:22 synocheckshare: wins_query1.c:51 key [security] not found or error!!
May 10 06:01:22 synocheckshare: share_map_set.c:76 Failed to get music from /usr/syno/etc/smb.conf, ret=0, errno=0xB500
May 10 06:01:22 synocheckshare: share_set.c:704 Failed to set share right map: [music], errno=0x2000
May 10 06:01:22 synocheckshare: share_restore.c:131 Restore share [music] is ok!!
May 10 06:01:22 synocheckshare: share_map_May 11 06:01:07 syslogd started: BusyBox v1.16.1
May 11 06:01:08 dhcpcd[2097]: dhcpReboot: do not want cache
May 11 06:01:09 kernel: [ 58.408793] md: md2: set sda3 to auto_remap [0]
May 11 06:01:09 kernel: [ 58.413392] md: md2: set sde3 to auto_remap [0]
May 11 06:01:09 kernel: [ 58.417922] md: md2: set sdd3 to auto_remap [0]
May 11 06:01:09 kernel: [ 58.422456] md: md2: set sdc3 to auto_remap [0]
May 11 06:01:09 kernel: [ 58.426986] md: md2: set sdb3 to auto_remap [0]
May 11 06:01:09 kernel: [ 58.593508] 0: w=1 pa=0 pr=5 m=1 a=2 r=5 op1=0 op2=0
May 11 06:01:09 kernel: [ 58.598480] 4: w=2 pa=0 pr=5 m=1 a=2 r=5 op1=0 op2=0
May 11 06:01:09 kernel: [ 58.603517] 3: w=3 pa=0 pr=5 m=1 a=2 r=5 op1=0 op2=0
May 11 06:01:09 kernel: [ 58.608483] 2: w=4 pa=0 pr=5 m=1 a=2 r=5 op1=0 op2=0
May 11 06:01:09 kernel: [ 58.613456] 1: w=5 pa=0 pr=5 m=1 a=2 r=5 op1=0 op2=0
May 11 06:01:09 kernel: [ 58.618422] raid5: raid level 5 set md2 active with 5 out of 5 devices, algorithm 2
May 11 06:01:09 kernel: [ 58.626083] RAID5 conf printout:
May 11 06:01:09 kernel: [ 58.629307] --- rd:5 wd:5
May 11 06:01:09 kernel: [ 58.632016] disk 0, o:1, dev:sda3
May 11 06:01:09 kernel: [ 58.635415] disk 1, o:1, dev:sdb3
May 11 06:01:09 kernel: [ 58.638814] disk 2, o:1, dev:sdc3
May 11 06:01:09 kernel: [ 58.642217] disk 3, o:1, dev:sdd3
May 11 06:01:09 kernel: [ 58.645616] disk 4, o:1, dev:sde3
May 11 06:01:09 spacetool: spacetool.c:2084 [Info] Activate all VG
May 11 06:01:11 dhcpcd[2108]: dhcpReboot: do not want cache
May 11 06:01:12 dhcpcd[2097]: client.c(1560)HUP ddnsd result: return code = 256
May 11 06:01:12 dhcpcd[2097]: FileSetLine(468) (ERR_WRITE_FAILED)
May 11 06:01:12 dhcpcd[2097]: bound ip, lease time 180000 secs. close socket 7
May 11 06:01:12 s10_synocheckinfo: s10_synocheckinfo.c:907 SLIBCFileSetKeyValue([/etc.defaults/synoinfo.conf], [supplang], [enu,cht,chs,krn,
May 11 06:01:12 s30_synocheckuser: CheckSmbConf(823): fflush(pfTmp) failed!
May 11 06:01:12 s42_synocheckgrp: SYNOICheckLocalGrp(264): system(szCommand=/bin/cp -f "/etc/group" "/etc/group_chk.tmp" > /dev/null 2>&1) f
ailed!
May 11 06:01:19 scemd: net_route_table_handler.c:72 Get IP from /etc/dhcpc/dhcpcd-eth1.info fail
May 11 06:01:19 scemd: net_route_table_check.c:46 NetRoutetableHandler clear [eth1] route table fail
May 11 06:01:19 scemd: scemd.c:125 fan_type=3, raid_type=1, led_type=3, thermal_type=1, fanctrl_type=1, auto_poweron_type=1, dual_power_type
May 11 06:01:20 scemd: modules/fan_speed_adjust_common.c:163 Type: INTERNAL Fan Mode: LOW
May 11 06:01:20 scemd: modules/raid_sys_volume_check.c:163 MD0 active disks 5, designed disks 5
May 11 06:01:20 scemd: modules/raid_sys_volume_check.c:163 MD1 active disks 5, designed disks 5
May 11 06:01:20 scemd: modules/disk_hibernation.c:429 Force hibernation enable, idle minutes 10
May 11 06:01:21 synocheckshare: share_db_build.c:178 section type is unexpected! iSecType=-1
May 11 06:01:21 synocheckshare: share_db_build.c:321 ShareDBSetOne() failed! synoerr=0x2200
May 11 06:01:22 synocheckshare: share_db_dump.c:358 fflush failed!! errno=28/No space left on device
May 11 06:01:22 synocheckshare: share_map_set.c:76 Failed to get share1 from /usr/syno/etc/smb.conf, ret=0, errno=0xB500
May 11 06:01:22 synocheckshare: share_set.c:704 Failed to set share right map: [share1], errno=0x2000
May 11 06:01:22 synocheckshare: share_restore.c:131 Restore share [share1] is ok!!
May 11 06:01:22 synocheckshare: wins_query1.c:51 key [security] not found or error!!
May 11 06:01:22 synocheckshare: share_map_set.c:76 Failed to get music from /usr/syno/etc/smb.conf, ret=0, errno=0xB500
May 11 06:01:22 synocheckshare: share_set.c:704 Failed to set share right map: [music], errno=0x2000
Aber die richtigen Schlüsse daraus ziehen kann ich leider nicht.
Grüße
