Wie unrar installieren?
eigentlich ist das Schlimmste schon überstanden. Im Prinzip müßte jetzt ein
ipkg install unrar
ausreichen.
Peter
Das kommt dann
DiskStation> ipkg install unrar
Installing unrar (3.7.8-1) to /opt/...
Downloading http://ipkg.nslu2-linux.org/feeds/optware/ds101g/cross/stable/unrar_3.7.8-1_powerpc.ipk
Installing libstdc++ (5.0.6-6) to /opt/...
Downloading http://ipkg.nslu2-linux.org/feeds/optware/ds101g/cross/stable/libstdc++_5.0.6-6_powerpc.ipk
ipkg: //opt/lib/ipkg/info/libstdc++.control: Permission denied
ipkg: Cannot create symlink from ./opt/lib/libstdc++.so to 'libstdc++.so.5.0.6': Permission denied
ipkg: Cannot create symlink from ./opt/lib/libstdc++.so.5 to 'libstdc++.so.5.0.6': Permission denied
ipkg: /opt/lib/libstdc++.so.5.0.6: Permission denied
can't get //opt/lib/ipkg/info/libstdc++.control open for read
ipkg: //opt/lib/ipkg/info/unrar.control: Permission denied
ipkg: /opt/bin/unrar: Permission denied
can't get //opt/lib/ipkg/info/unrar.control open for read
Configuring libstdc++
Configuring unrar
ipkg_conf_write_status_files: Can't open status file: //opt/lib/ipkg/status for writing: Permission denied
pkg_write_filelist pkg=libstdc++ returned 13
pkg_write_filelist pkg=unrar returned 13
Successfully terminated.
Collected errors:
Unable to open the control file in  set_flags_from_control
Could not open //opt/lib/ipkg/info/libstdc++.list for writing: Permission denied
Could not open //opt/lib/ipkg/info/unrar.list for writing: Permission denied
DiskStation> DiskStation> ipkg install unrar
-sh: DiskStation: not found
DiskStation> Installing unrar (3.7.8-1) to /opt/...
-sh: Syntax error: "(" unexpected
DiskStation> Downloading http://ipkg.nslu2-linux.org/feeds/optware/ds101g/cross/stable/unrar_3.7.8-1_powerpc.ipk
-sh: Downloading: not found
DiskStation> Installing libstdc++ (5.0.6-6) to /opt/...
DiskStation> Downloading http://ipkg.nslu2-linux.org/feeds/optware/ds101g/cross/stable/libstdc++_5.0.6-6_powerpc.ipk
DiskStation> ipkg: //opt/lib/ipkg/info/libstdc++.control: Permission denied
-sh: ipkg:: not found
DiskStation> ipkg: Cannot create symlink from ./opt/lib/libstdc++.so to 'libstdc++.so.5.0.6': Permission denied
DiskStation> ipkg: Cannot create symlink from ./opt/lib/libstdc++.so.5 to 'libstdc++.so.5.0.6': Permission denied
DiskStation> ipkg: /opt/lib/libstdc++.so.5.0.6: Permission denied
DiskStation> can't get //opt/lib/ipkg/info/libstdc++.control open for read
Configuring unrar
-sh: cant get //opt/lib/ipkg/info/libstdc++.control open for read
cant: not foundipkg_conf_write_status_files: Can't open status file: //opt/lib/ipkg/status for writing: Permission denied
DiskStation> Configuring libstdc++
-sh: Configuring: not found
DiskStation> Configuring unrar
DiskStation> ipkg_conf_write_status_files: Can't open status file: //opt/lib/ipkg/status for writing: Permission denied
> Collected errors:
unrar --help
Hier findest du alle Befehle die du brauchst!
Wenn dir das nicht hilft, dann kannst du auch die Googlesuche verwenden.
Für dich wird wohl dieser Befehl interessant sein:
unrar -x [Archivname] [Zielordner]
Hier findest du das komplette Manual für unrar.
Grüße
Smulg
Es gibt auch eine 3rd-party-apps fürs Problem unrar ... *guck*
Itari
