wie installiere ich pycurl?
Pa-Vis Kalka
20. Nov. 2013
DS413j - DSM 5.2-5592 Update 3
Also ich verzweifel langsam. Die neuste Version von pyload startet offensichtlich nicht ohne ein paar zusätzliche python pakete....
eigentlich kann es doch nicht so schwer sein, aber:
pip install pycurl
Collecting pycurl
  Using cached pycurl-7.19.5.1.tar.gz
    Complete output from command python setup.py egg_info:
    Traceback (most recent call last):
      File "<string>", line 20, in <module>
      File "/tmp/pip-build-SBUnJx/pycurl/setup.py", line 634, in <module>
        ext = get_extension(split_extension_source=split_extension_source)
      File "/tmp/pip-build-SBUnJx/pycurl/setup.py", line 392, in get_extension
        ext_config = ExtensionConfiguration()
      File "/tmp/pip-build-SBUnJx/pycurl/setup.py", line 65, in __init__
        self.configure()
      File "/tmp/pip-build-SBUnJx/pycurl/setup.py", line 100, in configure_unix
        raise ConfigurationError(msg)
    __main__.ConfigurationError: Could not run curl-config: [Errno 2] No such file or directory
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-build-SBUnJx/pycurl
easy_install
Searching for pycurl
Reading https://pypi.python.org/simple/pycurl/
Best match: pycurl 7.19.5.1
Downloading https://pypi.python.org/packages/source/p/pycurl/pycurl-7.19.5.1.tar.gz#md5=f44cd54256d7a643ab7b16e3f409b26b
Processing pycurl-7.19.5.1.tar.gz
Writing /tmp/easy_install-wfvMUd/pycurl-7.19.5.1/setup.cfg
Running pycurl-7.19.5.1/setup.py -q bdist_egg --dist-dir /tmp/easy_install-wfvMUd/pycurl-7.19.5.1/egg-dist-tmp-tbvj5w
  File "/usr/bin/easy_install", line 9, in <module>
    load_entry_point('distribute==0.6.19', 'console_scripts', 'easy_install')()
  File "build/bdist.linux-armv5tel/egg/setuptools/command/easy_install.py", line 2245, in main
  File "/usr/lib/python2.7/distutils/core.py", line 151, in setup
    dist.run_commands()
  File "/usr/lib/python2.7/distutils/dist.py", line 953, in run_commands
    self.run_command(cmd)
  File "/usr/lib/python2.7/distutils/dist.py", line 972, in run_command
    cmd_obj.run()
  File "build/bdist.linux-armv5tel/egg/setuptools/command/easy_install.py", line 380, in run
  File "build/bdist.linux-armv5tel/egg/setuptools/command/easy_install.py", line 629, in easy_install
  File "build/bdist.linux-armv5tel/egg/setuptools/command/easy_install.py", line 659, in install_item
  File "build/bdist.linux-armv5tel/egg/setuptools/command/easy_install.py", line 842, in install_eggs
  File "build/bdist.linux-armv5tel/egg/setuptools/command/easy_install.py", line 1070, in build_and_install
  File "build/bdist.linux-armv5tel/egg/setuptools/command/easy_install.py", line 1056, in run_setup
  File "build/bdist.linux-armv5tel/egg/setuptools/sandbox.py", line 240, in run_setup
  File "/usr/lib/python2.7/contextlib.py", line 35, in __exit__
    self.gen.throw(type, value, traceback)
  File "build/bdist.linux-armv5tel/egg/setuptools/sandbox.py", line 193, in setup_context
  File "build/bdist.linux-armv5tel/egg/setuptools/sandbox.py", line 152, in save_modules
  File "build/bdist.linux-armv5tel/egg/setuptools/sandbox.py", line 126, in __exit__
  File "build/bdist.linux-armv5tel/egg/setuptools/sandbox.py", line 110, in dump
MemoryError
Was genau mach ich falsch? :mad:
ich hole den Thread mal aus der Versenkung. Habe exakt das selbe Problem. Ich muss pycurl für ein Script haben und kann es genauso wenig installieren. Zugriff erfolgt per SSH.
Weiß hier jetzt mittlerweile einer Rat? Durchforste jetzt seid Tagen das Netz
mit pip
admin@Datenmonster:/volume1/Basis/script$ sudo pip install pycurl
Collecting pycurl
  Using cached pycurl-7.43.0.tar.gz
      File "<string>", line 1, in <module>
      File "/tmp/pip-build-mJNbQQ/pycurl/setup.py", line 823, in <module>
        ext = get_extension(sys.argv, split_extension_source=split_extension_source)
      File "/tmp/pip-build-mJNbQQ/pycurl/setup.py", line 497, in get_extension
        ext_config = ExtensionConfiguration(argv)
      File "/tmp/pip-build-mJNbQQ/pycurl/setup.py", line 71, in __init__
        self.configure()
      File "/tmp/pip-build-mJNbQQ/pycurl/setup.py", line 107, in configure_unix
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-build-mJNbQQ/pycurl/
mit easy_install
admin@Datenmonster:/volume1/Basis/script $ sudo easy_install pycurl
Best match: pycurl 7.43.0
Downloading https://pypi.python.org/packages/12/3f/557356b60d8e59a1cce62ffc07ecc03e4f8a202c86adae34d895826281fb/pycurl-7.43.0.tar.gz#md5=c94bdba01da6004fa38325e9bd6b9760
Processing pycurl-7.43.0.tar.gz
Writing /tmp/easy_install-5BQYz0/pycurl-7.43.0/setup.cfg
Running pycurl-7.43.0/setup.py -q bdist_egg --dist-dir /tmp/easy_install-5BQYz0/pycurl-7.43.0/egg-dist-tmp-St2ZWe
  File "/bin/easy_install", line 9, in <module>
    load_entry_point('setuptools==20.9.0', 'console_scripts', 'easy_install')()
  File "build/bdist.linux-armv5tel/egg/setuptools/command/easy_install.py", line 2241, in main
    dist.run_commands()
    cmd_obj.run()
  File "build/bdist.linux-armv5tel/egg/setuptools/command/easy_install.py", line 391, in run
  File "build/bdist.linux-armv5tel/egg/setuptools/command/easy_install.py", line 640, in easy_install
  File "build/bdist.linux-armv5tel/egg/setuptools/command/easy_install.py", line 670, in install_item
  File "build/bdist.linux-armv5tel/egg/setuptools/command/easy_install.py", line 850, in install_eggs
  File "build/bdist.linux-armv5tel/egg/setuptools/command/easy_install.py", line 1078, in build_and_install
  File "build/bdist.linux-armv5tel/egg/setuptools/command/easy_install.py", line 1064, in run_setup
  File "build/bdist.linux-armv5tel/egg/setuptools/sandbox.py", line 246, in run_setup
  File "build/bdist.linux-armv5tel/egg/setuptools/sandbox.py", line 195, in setup_context
  File "build/bdist.linux-armv5tel/egg/setuptools/sandbox.py", line 166, in save_modules
  File "build/bdist.linux-armv5tel/egg/setuptools/sandbox.py", line 141, in resume
  File "build/bdist.linux-armv5tel/egg/setuptools/sandbox.py", line 154, in save_modules
  File "build/bdist.linux-armv5tel/egg/setuptools/sandbox.py", line 243, in run_setup
  File "build/bdist.linux-armv5tel/egg/setuptools/sandbox.py", line 273, in run
  File "build/bdist.linux-armv5tel/egg/setuptools/sandbox.py", line 242, in runner
  File "build/bdist.linux-armv5tel/egg/setuptools/sandbox.py", line 46, in _execfile
  File "/tmp/easy_install-5BQYz0/pycurl-7.43.0/setup.py", line 823, in <module>
  File "/tmp/easy_install-5BQYz0/pycurl-7.43.0/setup.py", line 497, in get_extension
  File "/tmp/easy_install-5BQYz0/pycurl-7.43.0/setup.py", line 71, in __init__
  File "/tmp/easy_install-5BQYz0/pycurl-7.43.0/setup.py", line 107, in configure_unix
setuptools.sandbox.UnpickleableException: ConfigurationError('Could not run curl-config: [Errno 2] No such file or directory',)
habe das gleiche Problem - wie konntet ihr das lösen?
VG - CG
Bei mir unter DSM 5.2 funktioniert das pyload 0.4.9-5 vom pyload Team / enkidu.
Sonst installiert habe ich nur Python, Python 3 von synocommunity, Pyhton 3 von Synology und Python Module von Synology
Bei IPKG habe ich noch ein paar pycurl Pakete gesehen. Ob das aber besser funktioniert kann ich grad nicht sagen ohne Test.
ipkg hab ich leider nicht drauf. hat beim letzten Mal irgendwie nicht ordentlich hingehauen
