VPN-Verbindung nicht möglich (PPTP / OpenVPN)
drdave
12. Mai 2011
Nabend allerseits,
nach etlichen vergeblichen Versuchen wende ich mich nun Rat suchend an euch. Ich bekomme beim besten Willen keine VPN-Verbindung ins LAN zustande.
Versucht habe ich es via 3G-Tethering (VF), sowie von dem Rechner eines Freundes aus (Win 7).
Wenn ich es via PPTP versuche erhalte ich den Fehlercode 619, bei OpenVPN folgendes:
Thu Sep 06 23:10:36 2012 OpenVPN 2.2.2 Win32-MSVC++ [SSL] [LZO2] [PKCS11] built on Dec 15 2011
Thu Sep 06 23:10:43 2012 IMPORTANT: OpenVPN's default port number is now 1194, based on an official port number assignment by IANA.  OpenVPN 2.0-beta16 and earlier used 5000 as the default port.
Thu Sep 06 23:10:43 2012 WARNING: No server certificate verification method has been enabled.  See http://openvpn.net/howto.html#mitm for more info.
Thu Sep 06 23:10:43 2012 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Thu Sep 06 23:10:44 2012 LZO compression initialized
Thu Sep 06 23:10:44 2012 UDPv4 link local (bound): [undef]:1194
Thu Sep 06 23:10:44 2012 UDPv4 link remote: xxx:1194
Thu Sep 06 23:10:44 2012 read UDPv4: Connection reset by peer (WSAECONNRESET) (code=10054)
Thu Sep 06 23:10:48 2012 read UDPv4: Connection reset by peer (WSAECONNRESET) (code=10054)
Thu Sep 06 23:10:52 2012 read UDPv4: Connection reset by peer (WSAECONNRESET) (code=10054)
Thu Sep 06 23:11:00 2012 read UDPv4: Connection reset by peer (WSAECONNRESET) (code=10054)
Thu Sep 06 23:11:14 2012 read UDPv4: Connection reset by peer (WSAECONNRESET) (code=10054)
Thu Sep 06 23:11:44 2012 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Thu Sep 06 23:11:44 2012 TLS Error: TLS handshake failed
Thu Sep 06 23:11:44 2012 SIGUSR1[soft,tls-error] received, process restarting
Screens meiner Config habe ich angehangen. Ports sind im Router weitergeleitet, User hat VPN-Berechtigung, Firewall @ DSM ist deaktiviert, Windows-FW auch. NAS und Router wurden neugestartet. Lt. div. sind die Ports anscheinend doch dicht.
Hoffentlich weiß jemand Rat. Danke im Vorraus ;-)
Nabend, PPTP und OpenVPN sind zwei paar Schuhe :)
Hast Du die neue Version des VPN Server auf der DSM 4.1, denn mit 4.o hat der neue VPN Server Probleme.
Und das ganze mal im eigenen Netz versucht ?
Guß Jo
Ich danke dir joku!
Das Update hat's gerissen. PPTP und openVPN funktionieren nun.
Nur aus Interesse: Eine VPN-Verbindung vom gleichen ins gleiche Netzwerk ist möglich und läuft ohne Kollisionen ab?
Gruß drdave
Moin, moin drdave, bei mir geht es, ich habe alles unverädert, die IP Vergaben, versuche es :) Gruß Jo
