Volume abgestürzt! Wiederherstellen?
Deepbluesee
Gesperrt
03. Okt. 2011
ich habe eine DS918+ mit 4x10TB im SHR
jetzt ist das einzige Volume 1 abgestürzt, alle Platten sind aber OK laut SMART und Iron Wolf
Ticket habe ich erstellt und in der Zwischenzeit das gefunden:
Re: Filesystem check with DSM5
Quote
Unread post by gonzalu » Sat Jan 06, 2018 3:33 pm
mipial wrote:
DuncanDonovan wrote:
Just for people who cannot complete
CODE: SELECT ALL
syno_poweroff_task -d
because they get a TERMINATED message:
Perhaps you could not log in directly to FTP with root and you tried to login with admin first and then sudo sh to become root. If you do that, you have to to a...
CODE: SELECT ALL
cd /
...first before you do:
CODE: SELECT ALL
sudo sh
Otherwise your home directory of the user admin is on /volume_1 and this prevents syno_poweroff_task -d from successfully finishing. If you first change to / syno_poweroff_task -d will complete successfully.
THIS! I have been struggling with /dev/vg1000/lv "in use" for hours, till I started away from it.
Then it was only a matter of:
CODE: SELECT ALL
login as: admin
admin@servidor's password:
admin@Servidor:~$ cd /
admin@Servidor:/$ sudo sh
Password:
sh-4.3# syno_poweroff_task -d
sh-4.3# vgchange -ay
1 logical volume(s) in volume group "vg1000" now active
sh-4.3# fsck.ext4 -pvf -C 0 /dev/vg1000/lv
And it has just finished running fsck, after 15-20 minutes, and repaired the errors.
Just wanted to say thanks to this post and to everyone for contributing to the cause. FSCK finally running on fix mode for me...
Synology tech support actually said for me to offload my 40TB to some other place, wipe clean and start fresh... If they had a LOANER program I would LOVE to do that but I am limited by the minimum $2500 expense of buying another array just to back it up. I realize this is the RIGHT way to do it but today it is still prohibitively expensive to do so.
leider kommt bei mir folgende Fehlermeldung:
fsck.ext4: Bad magic number in super-block while trying to open /dev/vg1000/lv
/dev/vg1000/lv:
The superblock could not be read or does not describe a correct ext2
filesystem. If the device is valid and it really contains an ext2
filesystem (and not swap or ufs or something else), then the superblock
is corrupt, and you might try running e2fsck with an alternate superblock:
e2fsck -b 8193 <device>
Jemand ne Idee?
Wenn ein Volume abstürzt liegt das in der Regel an einer oder mehreren Platten mit Defekten.
An der Stelle ist dann auch nicht der SMART Test und dessen Ergebnis relevant, sondern wie sich die Platten mit ihren jeweiligen einzelnen SMART-Werten darstellt. Es kann durchaus sein, dass ein einzelner Wert von Test als nicht gravierend eingestuft wird, dem DSM aber genügt, um die Platte aus dem RAID fliegen zu lassen.
Klar das macht Sinn aber ich habe alles getestet und es wird kein Fehler angezeigt, ich kann auch auf alle Daten zugreifen, ich verstehe es nicht.
DISK4 ID199
Da gibt es einen Fehler im UDMA_CRC_Error_Count
IMHO ein möglicher Wackler am Steckkontakt?
=> https://forum.ubuntuusers.de/topic/smart-interpretation-relevanz-von-udma-crc-er/
Evtl. hilft es, die DS herunterzufahren und die Disk zu entnehmen und auf korrekten Sitz mit hoffentlich gutem Kontakt zu prüfen. Danach DS starten und gucken, was nun angezeigt wird.
Ein regelmäßiges Backup machst Du aber schon?
Das Problem bei Seagate ist, dass relevante Werte nicht in einer einfach lesbaren Form dargestellt werden. Hier müsste man extern mit dem Sagte Tool prüfen. Was das dann ausspuckt, weiß ich aber nicht.
Auffällig ist auf jeden Fall ID 199 von Datenträger 4. UDMA-CRC Error deutet auf ein Kontaktproblem hin und kann durchaus der Grund für das abgestürzte RAID sein.
ok werde ich testen aber die Diskstation steht die ganze Zeit Ruhig wundert mich schon wenns das wäre.
wie kann ich den Status abgestürzt entfernen?
So also laut der Quelle ist der Fehler nur bei UDMA 66 o 100 relevant und dann deutlich schlechter als 2. habe Trotzdem mal aus gemacht und Disk rein und raus. Ändert sich nix.
Die wichtigste Frage:
Wie bekomme ich den Status Abgestürzt weg?!
in Beitrag #1 versuchst Du per fsck.ext4 das Filesystem zu prüfen und in Beitrag #4 sieht man, dass Du btrfs und kein ext4 als Filesystem hast, das kann nicht funktionieren. Du musst Dich mit den Tools von btrfs beschäftigen.
PS: bitte nicht quer durchs Forum posten.
verdammt stimmt daran habe ich gar nicht gedacht! Wie kann ich ein Volume mit BTRFS checken?
