TVHeadend Einträge in /var/log/mediasrv.log
hadi
28. Sep. 2013
habe tvheadend (aktuellste Version) auf einer DS412+ laufen (DSM4.3) mit einem Sundtek DVB-C Stick. Es funktioniert soweit alles prima (Aufnahmen usw). Aber:
a) Platten gehen nicht mehr in den Ruhezustand (anderer Beitrag)
b) In der mediasrv.log Datei finden sich permanent folgende Einträge, wenn tvheadend läuft:
2013-11-04 20:11:21 [7552] Symbol rate: 6899982
2013-11-04 20:11:21 [7552] Constellation: QAM256
2013-11-04 20:11:21 [7552] Mirroring: Normal
2013-11-04 20:11:22 [7552] Channel found (802000000)
2013-11-04 20:11:22 [7552] =============
2013-11-04 20:11:22 [7552] Symbol rate: 6899982
2013-11-04 20:11:22 [7552] Constellation: QAM256
2013-11-04 20:11:22 [7552] Mirroring: Normal
2013-11-04 20:11:23 [7552] Channel found (802000000)
2013-11-04 20:11:23 [7552] =============
2013-11-04 20:11:23 [7552] Symbol rate: 6899980
2013-11-04 20:11:23 [7552] Constellation: QAM256
2013-11-04 20:11:23 [7552] Mirroring: Normal
2013-11-04 20:11:24 [7552] Channel found (802000000)
2013-11-04 20:11:24 [7552] =============
2013-11-04 20:11:24 [7552] Symbol rate: 6899982
2013-11-04 20:11:24 [7552] Constellation: QAM256
2013-11-04 20:11:24 [7552] Mirroring: Normal
2013-11-04 20:11:25 [7552] Channel found (802000000)
2013-11-04 20:11:25 [7552] =============
2013-11-04 20:11:25 [7552] Symbol rate: 6899982
2013-11-04 20:11:25 [7552] Constellation: QAM256
2013-11-04 20:11:25 [7552] Mirroring: Normal
2013-11-04 20:11:26 [7552] Channel found (802000000)
2013-11-04 20:11:26 [7552] =============
2013-11-04 20:11:26 [7552] Symbol rate: 6899979
2013-11-04 20:11:26 [7552] Constellation: QAM256
2013-11-04 20:11:26 [7552] Mirroring: Normal
2013-11-04 20:11:27 [7552] Channel found (802000000)
2013-11-04 20:11:27 [7552] =============
2013-11-04 20:11:27 [7552] Symbol rate: 6899983
2013-11-04 20:11:27 [7552] Constellation: QAM256
2013-11-04 20:11:27 [7552] Mirroring: Normal
2013-11-04 20:11:28 [7552] Channel found (802000000)
2013-11-04 20:11:28 [7552] =============
Die Einträge laufen jede Sekunde weiter...
Hat einer eine Erklärung dafür?
Könnte evtl. auch das Problem/Ursache für den Ruhezustand sein?
Danke & Grüße,
Hadi
Ich bin da leider noch nicht weiterkommen.
Hat niemand einen Ansatzpunkt?
Oder weiß jemand ob/wo man für tvheadend einstellen kann, ob bzw. was geloggt wird?
Oder wohin es geloggt wird (dann könnte man das ja umbiegen)?
Bin für jede Idee dankbar.
