svn installation
Tester0815
14. Okt. 2012
Hallo @all
versuche gerade auf meiner Diskstation1512+ (DSM 4.1-2661) ein svn zu installieren.
Bin nach der Anleitung vorgegangen:
http://www.synology-wiki.de/index.php/SVN-Server_installieren
DiskStation> ipkg update
Downloading http://ipkg.nslu2-linux.org/feeds/optware/syno-i686/cross/unstable/Packages.gz
Inflating http://ipkg.nslu2-linux.org/feeds/optware/syno-i686/cross/unstable/Packages.gz
Updated list of available packages in /opt/lib/ipkg/lists/cross
Successfully terminated.
DiskStation> ipkg install svn
Installing svn (1.7.7-1) to root...
Downloading http://ipkg.nslu2-linux.org/feeds/optware/syno-i686/cross/unstable/svn_1.7.7-1_i686.ipk
package apr-util suggests installing sqlite
package apr-util suggests installing openldap-libs
Installing neon (0.29.3-1) to root...
Downloading http://ipkg.nslu2-linux.org/feeds/optware/syno-i686/cross/unstable/neon_0.29.3-1_i686.ipk
Installing openssl (0.9.8v-2) to root...
Downloading http://ipkg.nslu2-linux.org/feeds/optware/syno-i686/cross/unstable/openssl_0.9.8v-2_i686.ipk
Installing zlib (1.2.5-1) to root...
Downloading http://ipkg.nslu2-linux.org/feeds/optware/syno-i686/cross/unstable/zlib_1.2.5-1_i686.ipk
Installing libxml2 (2.7.8-1) to root...
Downloading http://ipkg.nslu2-linux.org/feeds/optware/syno-i686/cross/unstable/libxml2_2.7.8-1_i686.ipk
Installing apr (1.4.6-1) to root...
Downloading http://ipkg.nslu2-linux.org/feeds/optware/syno-i686/cross/unstable/apr_1.4.6-1_i686.ipk
Installing apr-util (1.4.1-1) to root...
Downloading http://ipkg.nslu2-linux.org/feeds/optware/syno-i686/cross/unstable/apr-util_1.4.1-1_i686.ipk
Installing e2fslibs (1.40.3-5) to root...
Downloading http://ipkg.nslu2-linux.org/feeds/optware/syno-i686/cross/unstable/e2fslibs_1.40.3-5_i686.ipk
Installing expat (2.0.1-1) to root...
Downloading http://ipkg.nslu2-linux.org/feeds/optware/syno-i686/cross/unstable/expat_2.0.1-1_i686.ipk
Installing gdbm (1.8.3-4) to root...
Downloading http://ipkg.nslu2-linux.org/feeds/optware/syno-i686/cross/unstable/gdbm_1.8.3-4_i686.ipk
Installing libdb (4.2.52-3) to root...
Downloading http://ipkg.nslu2-linux.org/feeds/optware/syno-i686/cross/unstable/libdb_4.2.52-3_i686.ipk
Installing cyrus-sasl-libs (2.1.23-2) to root...
Downloading http://ipkg.nslu2-linux.org/feeds/optware/syno-i686/cross/unstable/cyrus-sasl-libs_2.1.23-2_i686.ipk
Installing psmisc (22.17-1) to root...
Downloading http://ipkg.nslu2-linux.org/feeds/optware/syno-i686/cross/unstable/psmisc_22.17-1_i686.ipk
Installing ncurses (5.7-1) to root...
Downloading http://ipkg.nslu2-linux.org/feeds/optware/syno-i686/cross/unstable/ncurses_5.7-1_i686.ipk
Installing file (5.09-1) to root...
Downloading http://ipkg.nslu2-linux.org/feeds/optware/syno-i686/cross/unstable/file_5.09-1_i686.ipk
Installing sqlite (3.7.14.1-1) to root...
Downloading http://ipkg.nslu2-linux.org/feeds/optware/syno-i686/cross/unstable/sqlite_3.7.14.1-1_i686.ipk
Installing readline (6.1-2) to root...
Downloading http://ipkg.nslu2-linux.org/feeds/optware/syno-i686/cross/unstable/readline_6.1-2_i686.ipk
Installing openldap-libs (2.3.43-2) to root...
Downloading http://ipkg.nslu2-linux.org/feeds/optware/syno-i686/cross/unstable/openldap-libs_2.3.43-2_i686.ipk
Configuring apr
Configuring apr-util
Configuring cyrus-sasl-libs
Configuring e2fslibs
Configuring expat
Configuring file
Configuring gdbm
Configuring libdb
Configuring libxml2
Configuring ncurses
update-alternatives: Linking //opt/bin/clear to /opt/bin/ncurses-clear
Configuring neon
Configuring openldap-libs
Configuring openssl
Configuring psmisc
update-alternatives: Linking //opt/bin/killall to /opt/bin/psmisc-killall
update-alternatives: Linking //opt/bin/pidof to /opt/bin/psmisc-killall
Configuring readline
Configuring sqlite
Configuring svn
Configuring zlib
soweit so gut. Allerdings wird weder der svnowner angelegt, wie im wiki beschrieben, noch /volume1/svn.
Irgendwie ist da was schief gelaufen oder?
Hab jetzt händisch svn angelegt und mein Repos. Aber dann muss ich ja den Benutzer wechseln und das geht alles nicht.
DiskStation> tail /var/log/messages
Nov 23 21:33:10 root: Cloud Station updater: start upgrade server db
Nov 23 21:33:10 root: Cloud Station updater: start move db
Nov 23 21:33:10 root: moving old client DB for
Nov 23 21:33:10 root: all volume: /volume1
Nov 23 21:33:10 root: create /volume1/@tmp/@cstn-share.9688
Nov 23 21:33:10 root: moving old client OK
Nov 23 21:33:10 root: CS: [start.sh]: Cloud station start...
Nov 23 21:33:11 scheduler: scheduler.c:322 Failed to get value of download_amule_schedule
Nov 23 21:34:48 scemd: scemd.c:413 stop manutild.
DiskStation> chown svnadmin:users -R /volume1/svn/gedankenstuetze/
chown: unknown user/group svnadmin:users
Weiß jemand Rat?
Viele Grüße
Tester
Bei mir ist die SVN-Installation schon etwas her.
Soweit ich mich erinnere, habe ich einfach einen Benutzer "svn" angelegt und einen "gemeinsamen Ordner" svn sowie die Rechte entsprechend eingestellt, dass sonst niemand drankommt.
Dann noch zwei Einträge in die /etc/services
svn             3690/tcp                        #Subversion
svn             3690/udp                        #Subversion
und einen in /etc/inetd.conf
svn     stream  tcp  nowait     svn     /opt/bin/svnserve svnserve -i -r /volume1/svn
Dann noch die Anpassung dem inetd mitgeteilt (killall -HUP inetd), das war's.
Neue Repositories mache ich so:
1.) telnet auf die DS als root
2.) su svn
3.) cd /volume1/svn
4.) svnadmin create <Repos>
5.) dann in <Repos>/conf die passwd und svnserve.conf anpassen
Gruß Benares
