SPK: MailStation Plus (MailStation add-on)
m4rkd4rk
21. Sep. 2011
Hi there,
I have been creating a SPK file called MailStation Plus. With this package you can control mail aliases and multiple domeins within DSM. Maybe some people are interested in this package, since they don't want to do anything with SSH and the postfix configuration files.
You can download MailStation Plus from my website. Maybe one of you can add this on the German Wiki also?
http://markinthedark.nl/stuff/downloads/category/3-synology-spk.html
Greetings,
Mark
For SCREENSHOTS look here: http://markinthedark.nl/stuff/photo-gallery/category/7-screenshots-mailstation-plus-v01.html
Download via this forum: Anhang anzeigen MailStationPlus-0.1.txt
PS: Seems zip Files cannot be uploaded anymore. I changed the extension to .txt. So change it back to zip after downloading the file. Please notice if you install this in DSM, please unzip first and then install the SPK file in DSM.
Hi Mark
I tried to download the spk to watch into the code. But unfortunately it seems that the "Agree to Terms" is saved in a cookie. Bad if a user does not accept cookies from your domain ;)
You can add this to our german Wiki if you like, just register there and you should be allowed to publish in Wiki.
Thanks for your effort
tobi
Hi Mark
tobi
jahlives,
As you have seen I use Joomla for my website. The component for downloading is named Phoca Download. Unfortunally I can't configure the use of cookies or not. I never heard of this problem before, but will have a look. I can't add an attachment here, otherwise I would add it for you.
mark
Hi Mark
can you zip it and send it to my email? postmaster[AET]brain[MINUS]force[DOT]ch
I will add it to your post then.
The problem with the cookie is as follows: Actually there are a lot of discussion reagarding the privacy right of the user. Especially in germany there are discussions how a user can decide whether a server is allowed to set a cookie or not. Most people say that there must be a opt-in proccedure, means the user must explicitly allow that the server can set a cookie.
I have mailed the SPK in a ZIP file to your address.
I have also added the SPK in you German Wiki.
Thanks a lot.
