Rails kann einige Gems nicht installieren
w1cked
21. Juni 2011
Hab leider mit einigen Ruby on Rails Gems Probleme beim installieren. Bis jetzt sind das Thin und Sqlite3. Im Falle von Sqlite3 hab ich folgende fehlermeldung:
DiskStation> gem install sqlite3
Building native extensions. This could take a while...
ERROR: Error installing sqlite3:
ERROR: Failed to build gem native extension.
/opt/bin/ruby extconf.rb
checking for sqlite3.h... *** extconf.rb failed ***
Could not create Makefile due to some reason, probably lack of
necessary libraries and/or headers. Check the mkmf.log file for more
details. You may need configuration options.
Provided configuration options:
--with-opt-dir
--with-opt-include
--without-opt-include=${opt-dir}/include
--with-opt-lib
--without-opt-lib=${opt-dir}/lib
--with-make-prog
--without-make-prog
--srcdir=.
--curdir
--ruby=/opt/bin/ruby
--with-sqlite3-dir
--without-sqlite3-dir
--with-sqlite3-include
--without-sqlite3-include=${sqlite3-dir}/include
--with-sqlite3-lib
--without-sqlite3-lib=${sqlite3-dir}/lib
--enable-local
--disable-local
/opt/lib/ruby/1.9.1/mkmf.rb:362:in `try_do': The complier failed to generate an executable file. (RuntimeError)
You have to install development tools first.
from /opt/lib/ruby/1.9.1/mkmf.rb:431:in `try_cpp'
from /opt/lib/ruby/1.9.1/mkmf.rb:828:in `block in find_header'
from /opt/lib/ruby/1.9.1/mkmf.rb:668:in `block in checking_for'
from /opt/lib/ruby/1.9.1/mkmf.rb:274:in `block (2 levels) in postpone'
from /opt/lib/ruby/1.9.1/mkmf.rb:248:in `open'
from /opt/lib/ruby/1.9.1/mkmf.rb:274:in `block in postpone'
from /opt/lib/ruby/1.9.1/mkmf.rb:270:in `postpone'
from /opt/lib/ruby/1.9.1/mkmf.rb:667:in `checking_for'
from /opt/lib/ruby/1.9.1/mkmf.rb:827:in `find_header'
from extconf.rb:34:in `<main>'
Gem files will remain installed in /opt/lib/ruby/gems/1.9.1/gems/sqlite3-1.3.6 for inspection.
Results logged to /opt/lib/ruby/gems/1.9.1/gems/sqlite3-1.3.6/ext/sqlite3/gem_make.out
Ich finde leider nicht raus was ihm da fehlt. Das mkmf.log ist leer.
Hat jemand schon Erfahrung damit und kann mir vielleicht weiter helfen?
