- 15. Mai 2008
Hab gerade mal in einem Seagate-Manual Erläuterungen zum Platten-Power-Management gefunden, die vielleicht ganz interessant sind:
Power-management modes
The drive provides programmable power management to provide greater energy efficiency. In most systems, you can control power management through the system setup program. The drive features the following power-management modes:
Active mode
The drive is in Active mode during the read/write and seek operations.
Idle mode
The buffer remains enabled, and the drive accepts all commands and returns to Active mode any time disc access is necessary.
Standby mode
The drive enters Standby mode when the host sends a Standby Immediate command. If the host has set the standby timer, the drive can also enter Standby mode automatically after the drive has been inactive for a specifiable length of time. The standby timer delay is established using a Standby or Idle command. In Standby mode, the drive buffer is enabled, the heads are parked and the spindle is at rest. The drive accepts all commands and returns to Active mode any time disc access is necessary.
Sleep mode
The drive enters Sleep mode after receiving a Sleep command from the host. In Sleep mode, the drive buffer is disabled, the heads are parked and the spindle is at rest. The drive leaves Sleep mode after it receives a Hard Reset or Soft Reset from the host. After receiving a reset, the drive exits Sleep mode and enters Standby mode with all current translation parameters intact.
Idle and Standby timers
Each time the drive performs an Active function (read, write or seek), the standby timer is reinitialized and begins counting down from its specified delay times to zero. If the standby timer reaches zero before any drive activity is required, the drive makes a transition to Standby mode. In both Idle and Standby mode, the drive accepts all commands and returns to Active mode when disc access is necessary.
itari
Power modes Heads Spindle Buffer Avg Watts*
Active Tracking Rotating Enabled 11
Idle Tracking Rotating Enabled 8
Standby Parked Stopped Enabled 1
Sleep Parked Stopped Disabled 1
* Beispiel-Werte für eine Seagate Barracuda 7200.11
Idle mode
Standby mode
Sleep mode
itari
