openvpn: WARNING in /var/log/messages
Ap0phis
16. Dez. 2010
Oct  9 07:31:24 openvpn[7692]: IMPORTANT: OpenVPN's default port number is now 1194, based on an official port number assignment by IANA.  OpenVPN 2.0-beta16 and earlier used 5000 as the default port.
Oct  9 07:31:24 openvpn[7692]: NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Oct  9 07:31:25 openvpn[7692]: WARNING: file '/usr/local/synovpn/etc/openvpn/keys/server.key' is group or others accessible
Oct  9 07:31:25 openvpn[7692]: WARNING: POTENTIALLY DANGEROUS OPTION --client-cert-not-required may accept clients which do not present a certificate
Wo ist hier genau das Problem? ... oder sind es gar 2 Probleme?
root@SynoDS111:~> ls -la /usr/local/synovpn/etc/openvpn/keys/
drwxr-xr-x    2 root     root          4096 Sep 18 17:46 .
drwxr-xr-x    3 root     root          4096 Sep  6 15:30 ..
-rwxr-xr-x    1 root     root          1866 Sep  3 21:01 README.txt
lrwxrwxrwx    1 root     root            41 Sep 18 17:46 ca.crt -> /usr/syno/etc/synovpn/openvpn/keys/ca.crt
-rw-r--r--    1 root     root           245 Sep  3 21:01 dh1024.pem
-rwxr-xr-x    1 root     root           445 Sep  3 21:01 openvpn.ovpn
-rwxrwxrwx    1 root     root          2214 Sep 18 17:46 openvpn.zip
lrwxrwxrwx    1 root     root            45 Sep 18 17:46 server.crt -> /usr/syno/etc/synovpn/openvpn/keys/server.crt
lrwxrwxrwx    1 root     root            45 Sep 18 17:46 server.key -> /usr/syno/etc/synovpn/openvpn/keys/server.key
root@SynoDS111:~> ls -la /usr/syno/etc/synovpn/openvpn/keys/
drwxrwxrwx    2 root     root          4096 Aug 16 09:22 .
drwxrwxrwx    3 root     root          4096 Sep 18 20:52 ..
-r--------    1 root     root          1204 Aug 16 09:22 ca.crt
-r--------    1 root     root           887 Aug 16 09:22 ca.key
-rw-rw-rw-    1 root     root            17 Aug 16 09:22 ca.srl
-rw-rw-rw-    1 root     root          1184 Aug 16 09:22 server.crt
-rw-rw-rw-    1 root     root           741 Aug 16 09:22 server.csr
-rw-rw-rw-    1 root     root           916 Aug 16 09:22 server.key
root@SynoDS111:~>
Habe lediglich - schon länger her - im VPN-Center openvpn aktiviert und das Zertifikat geladen.
Könnte die Rechtevergabe ein Bug im VPN-Center sein?
Sieht so aus wie wenn das Synology deaktiviert hat.
