lighttpd startet nicht
bizarre
12. März 2010
Hallo Leute,
da es einen Bug seitens der SSL-Direktiven in einer älteren Version gab, updatete ich lighttpd auf die aktuelle Version und sicherte die Config zurück.
Leider startet der Server nicht mehr. Ich bekomme nun folgende Fehlermeldung:
2010-09-20 20:55:41: (plugin.c.131) Cannot load plugin mod_fastcgi more than once, please fix your config (we may not accept such configs in future releases
Kann damit jemand was anfangen?
Vielen Dank für die Hilfe im Voraus!
Poste doch mal die hier angemoserte Konfigurationsdatei.
Itari
Das Problem ist, ich weiß auch gar nicht welche Konfig er meint?
Die lighttpd.conf? Die 10-php-fcgi.conf?
lighttpd.conf:
server.modules              = (
                                "mod_access",
                                "mod_fastcgi",
                                "mod_cgi",
                                "mod_accesslog" )
server.document-root        = "/opt/share/www/"
server.errorlog             = "/opt/var/log/lighttpd/error.log"
index-file.names            = ( "index.php", "index.html",
                                "index.htm", "default.htm",
                                "lighttpd/index.html" )
mimetype.assign             = (
  ".pdf"          =>      "application/pdf",
  ".sig"          =>      "application/pgp-signature",
  ".spl"          =>      "application/futuresplash",
  ".class"        =>      "application/octet-stream",
  ".ps"           =>      "application/postscript",
  ".torrent"      =>      "application/x-bittorrent",
  ".dvi"          =>      "application/x-dvi",
  ".gz"           =>      "application/x-gzip",
  ".pac"          =>      "application/x-ns-proxy-autoconfig",
  ".swf"          =>      "application/x-shockwave-flash",
  ".tar.gz"       =>      "application/x-tgz",
  ".tgz"          =>      "application/x-tgz",
  ".tar"          =>      "application/x-tar",
  ".zip"          =>      "application/zip",
  ".mp3"          =>      "audio/mpeg",
  ".m3u"          =>      "audio/x-mpegurl",
  ".wma"          =>      "audio/x-ms-wma",
  ".wax"          =>      "audio/x-ms-wax",
  ".ogg"          =>      "application/ogg",
  ".wav"          =>      "audio/x-wav",
  ".gif"          =>      "image/gif",
  ".jpg"          =>      "image/jpeg",
  ".jpeg"         =>      "image/jpeg",
  ".png"          =>      "image/png",
  ".xbm"          =>      "image/x-xbitmap",
  ".xpm"          =>      "image/x-xpixmap",
  ".xwd"          =>      "image/x-xwindowdump",
  ".css"          =>      "text/css",
  ".html"         =>      "text/html",
  ".htm"          =>      "text/html",
  ".js"           =>      "text/javascript",
  ".asc"          =>      "text/plain",
  ".c"            =>      "text/plain",
  ".cpp"          =>      "text/plain",
  ".log"          =>      "text/plain",
  ".conf"         =>      "text/plain",
  ".text"         =>      "text/plain",
  ".txt"          =>      "text/plain",
  ".dtd"          =>      "text/xml",
  ".xml"          =>      "text/xml",
  ".mpeg"         =>      "video/mpeg",
  ".mpg"          =>      "video/mpeg",
  ".mov"          =>      "video/quicktime",
  ".qt"           =>      "video/quicktime",
  ".avi"          =>      "video/x-msvideo",
  ".asf"          =>      "video/x-ms-asf",
  ".asx"          =>      "video/x-ms-asf",
  ".wmv"          =>      "video/x-ms-wmv",
  ".bz2"          =>      "application/x-bzip",
  ".tbz"          =>      "application/x-bzip-compressed-tar",
  ".tar.bz2"      =>      "application/x-bzip-compressed-tar"
accesslog.filename          = "/opt/var/log/lighttpd/access.log"
url.access-deny             = ( "~", ".inc", ".sqlite" )
$HTTP["url"] =~ "\.pdf$" {
  server.range-requests = "disable"
static-file.exclude-extensions = ( ".fcgi", ".php", ".pl", ".py", ".rb" )
server.port                = 81
server.pid-file            = "/var/run/lighttpd.pid"
cgi.assign                 = ( ".pl"  => "/opt/bin/perl",
                               ".cgi" => "/opt/bin/perl" )
include_shell "cat /opt/etc/lighttpd/conf.d/*.conf"
10-php-fcgi.conf:
server.modules += ( "mod_fastcgi" )
fastcgi.server = ( ".php" =>
                   ( "localhost" =>
                     ( "socket" => "/tmp/php-fcgi.sock",
                       "bin-path" => "/opt/bin/php-fcgi",
                       "max-procs" => 1,
                       "min-procs" => 1,
                       "max-load-per-proc" => 4,
Nimm doch mal die 1. Zeile
aus der Datei 10-php-fcgi.conf heraus und probiere es dann.
Itari
Ok, bekomme nun keine Fehlermeldung, jedoch läuft der Prozess nicht, sprich der Server startet trotzdem nicht.
Dann mache doch mal die ganz Datei leer.
Itari
Habe es hinbekommen.
Die Fehlermeldung besteht zwar immer noch, lighttpd startet jedoch wieder.
Letztendlich war das Problem der server.event-handler, welcher auf "poll" gesetzt werden musste.
Kannst ja noch mal versuchen die Zeile zu löschen (wie oben) ... offensichtlich wird das Teil ja 2x geladen.
Itari
