Kopano Postausgang
Gerd88
13. März 2009
habe von zarafa4h auf kopano4s gewechselt.
Empfange und versende die Mails über meinen Hoster.
Alles funktioniert ausser der Mailversand zu meinem Hoster.
Die Mails bleiben im Postausgang stecken.
Bei zarafa4h hatte ich keine Probleme mit dem Mailversand.
Anbei meine Einstellungen.
Wäre froh, wenn Ihr mit da helfen könntet.
MfG. Gerd
alias_maps = hash:/etc/aliases
body_checks = regexp:/etc/kopano/postfix/body_checks
bounce_template_file = /etc/kopano/postfix/bounce.cf
delay_warning_time = 4h
header_checks = regexp:/etc/kopano/postfix/header_checks
mailbox_size_limit = 0
maximal_backoff_time = 8000s
maximal_queue_lifetime = 7d
message_size_limit = 15728640
minimal_backoff_time = 1000s
mydomain = mydomain.com
myhostname = mail.mydomain.com
mynetworks = 127.0.0.0/8, 192.168.0.0/28, [::1]/128
myorigin = $mydomain
notify_classes = resource software protocol
recipient_bcc_maps = hash:/etc/kopano/postfix/recipient_bcc
relayhost = mydomain:587
sender_bcc_maps = hash:/etc/kopano/postfix/sender_bcc
smtp_helo_timeout = 60s
smtp_host_lookup = dns, native
smtp_sasl_auth_enable = yes
smtp_sasl_password_maps = hash:/etc/kopano/postfix/sasl_passwd
smtp_sasl_security_options = noanonymous
smtp_tls_CAfile = /etc/ssl/certs/ca-certificates.crt
smtp_use_tls = yes
smtpd_banner = $myorigin ESMTP Postfix Kopano
smtpd_client_restrictions = permit_mynetworks
smtpd_data_restrictions = reject_unauth_pipelining reject_multi_recipient_bounce
smtpd_hard_error_limit = 12
smtpd_helo_required = yes
smtpd_helo_restrictions = permit_mynetworks reject_invalid_helo_hostname reject_non_fqdn_helo_hostname reject_unknown_helo_hostname
smtpd_recipient_limit = 16
smtpd_recipient_restrictions = permit_mynetworks check_recipient_access hash:/etc/kopano/postfix/recipient_access reject_invalid_hostname reject_unauth_destination reject_unknown_recipient_domain
smtpd_sender_restrictions = reject_unknown_address check_sender_access hash:/etc/kopano/postfix/sender_access
smtpd_soft_error_limit = 3
unknown_local_recipient_reject_code = 450
virtual_alias_maps = hash:/etc/kopano/postfix/valiases
virtual_mailbox_domains = /etc/kopano/postfix/vdomains
virtual_transport = lmtp:127.0.0.1:2003
@Gerd88
mal diesen Post und davor gelesen?
Der Versand funktioniert auch mit den Änderungen nicht.
Änderung in der Spooler.CFG und Dagent.cfg, mit #
plugin_enable = no
Änderung in der Spooler.CFG, jeweils ohne #
smtp_server = localhost
smtp_port = 25
pid_file = /var/run/kopano/spooler.pid
Die Datenbank habe ich neu aufgesetzt.
Bekomme im mail.log folgende Fehlermeldung.
Jun 13 14:37:06 kopano4s postfix/lmtp[417]: 7EA991F21725: to=<postmaster@mydomain.com>, orig_to=<postmaster>, relay=127.0.0.1[127.0.0.1]:2003, delay=0.26, delays=0.08/0.04/0.08/0.06, dsn=5.1.1, status=bounced (host 127.0.0.1[127.0.0.1] said: 503 5.1.1 User does not exist (in reply to RCPT TO command))
Jun 13 14:37:06 kopano4s postfix/bounce[420]: warning: 7EA991F21725: undeliverable postmaster notification discarded
Jun 13 14:37:06 kopano4s postfix/qmgr[219]: 7EA991F21725: removed
Könnte es sein, dass der Alias Bcc falsch ist? Die Mailadresse postmaster@mydomain.com besteht. Aber root und admin nicht.
Alias | Recipient
postmaster@mydomain.com | postmaster@mydomain.com
root@mydomain.com | postmaster@mydomain.com
admin@mydomain.com | postmaster@mydomain.com
Da scheint mit dem User etwas nicht zu passen, so sieht das zumindest aus. Dann vielleicht nochmal die SMTP-Daten für den Relay durchgehen
- Account
- Port 25, 465, 587
- Passwort
in der Datei
/etc/zarafa4h/postfix/sasl_passwd
zum Beispiel :
smtp.strato.de Kontoname:Passwort
oder
smtp.strato.de:587 Kontoname:Passwort
Hallo Andy,
habe jetzt folgendes probiert.
Änderung in der Spooler.CFG und Dagent.cfg, ohne #
plugin_enable = no
Die Mails werden nun versendet, aber ich erhalte eine Meldung über eine fehlerhafte Zustellung zurück.
Die Mailadresse existiert aber.
This is the mail system at host mail.mydomain.com.
I'm sorry to have to inform you that your message could not
be delivered to one or more recipients. It's attached below.
For further assistance, please send mail to <postmaster>
If you do so, please include this problem report. You can
delete your own text from the attached returned message.
The mail system
<gerd.myname@mydomain.com>: host 127.0.0.1[127.0.0.1] said: 503 5.1.1 User
Hallo Andy,
vielen Dank für deine Hilfe.
Jetzt funktioniert alles.
Die Lösung ist wie folgt.
Richtigstellen der Smtp Mail-Domain und
Änderung in der Spooler.CFG und Dagent.cfg, jeweils ohne #
plugin_enable = no
smtp_port = 25
die Plugins sind in der nächsten k4s Version 0.8.4 per default disabled. Das hilft dann den Neuinstallationen.
Bitte noch etwas andres Prüfen, was ggf. Probleme macht und im nächsten Release gefixt ist: nicht alle Postfix hash maps sind bei der Grundinstallation aufgebaut, was auch im Log (/var/log/kopano/mail.log) als Warnung angezeigt wird.
Am Besten folgendes ausführen: > kopano-postfix map /etc/kopano/postfix/sender_access und auch für recipient_access
-TosoBoso
Danke tosoboso,
noch eine NAchfrage dazu, wie sieht es mit sender dependet relay aus, geht so was und gibt es eine transport, so dass ich, wie ich es in der univention VM am laufen habe, die mails die von kopano useren zu kopano useren gegen auf dem system direkt zugestellt werden statt über den relay...
[email]mailtest@gmail.com[/email] lmtp:127.0.0.1:2003
Freue mich schon auf die nächste Version....danke Dir
