kann man diaspora auf einer DS411 laufen lassen?
Laut der Page brauchst du folgende Dinge auf deinem Server:
In order to run Diaspora, you will need to install the following dependencies (specific instructions follow):
  • Build tools - Packages needed to compile the components that follow.
  • Ruby - The Ruby programming language. (We're developing mostly on 1.8.7, but we also support 1.9.2.)
  • RubyGems - A package manager for Ruby code that we use to download libraries ("gems") that Diaspora uses.
  • Bundler - A gem management tool for Ruby projects.
  • MySQL - Backend storage engine.
  • Or: PostgreSQL - Backend storage engine.
  • SQLite3 - Relational database management system
  • OpenSSL - An encryption library.
  • libcurl - A library to make HTTP requests (and much more).
  • ImageMagick - An image processing library we use to resize uploaded photos.
  • Git - A version control system, which you will need to download the Diaspora source code from GitHub.
  • Redis - A persistent key-value store that we use via Resque for background job processing.
Ob die alle auf der DS vertreten sind, weiß ich nicht. Manches dürfte man auch per IPKG installieren können.
