IPKG Installationsproblem auf DS210j
ubuntulinux
23. Jan. 2010
Guten Tag,
ich habe mir eine DS210j gekauft und versuche seit längerem, ipkg zu installieren.
Leider erhalte ich immer folgende Fehlermeldung
diskstation> sh syno-mvkw-bootstrap_1.2-7_arm.xsh
Optware Bootstrap for syno-mvkw.
Extracting archive... please wait
bootstrap/
bootstrap/bootstrap.sh
bootstrap/ipkg-opt.ipk
bootstrap/ipkg.sh
bootstrap/optware-bootstrap.ipk
bootstrap/wget.ipk
1232+1 records in
1232+1 records out
Creating temporary ipkg repository...
Installing optware-bootstrap package...
Unpacking optware-bootstrap.ipk...Done.
Configuring optware-bootstrap.ipk...mount: Mounting /volume1/@optware on /opt fa        iled: No such file or directory
mkdir: Cannot create directory `/opt/etc': No such file or directory
chmod: /opt/etc: No such file or directory
mkdir: Cannot create directory `/opt/var/': No such file or directory
chmod: /opt/var: No such file or directory
mkdir: Cannot create directory `/opt/tmp': No such file or directory
chmod: /opt/tmp: No such file or directory
mkdir: Cannot create directory `/opt/lib': No such file or directory
chmod: /opt/lib: No such file or directory
//tmp/ipkg/info/optware-bootstrap.ipk.preinst failed. Aborting installation of o        ptware-bootstrap.ipk
Installing ipkg...
Unpacking ipkg-opt.ipk...Done.
Configuring ipkg-opt.ipk...tar: Cannot create directory `./opt/etc': No such fil        e or directory
tar: ./opt/etc/ipkg.conf: No such file or directory
tar: Write Error: Broken pipe
tar: ./opt/lib/libipkg.so.0: input/output error -- Broken pipe
tar: Error exit delayed from previous errors
Done.
Removing temporary ipkg repository...
Installing wget...
bootstrap.sh: bootstrap.sh: 55: /opt/bin/ipkg: not found
BusyBox v1.1.0 (2009.11.12-17:45+0000) Built-in shell (ash)
Enter 'help' for a list of built-in commands.
diskstation>
Wo liegt hier das Problem? Ich habe das Script verwendet:
http://ipkg.nslu2-linux.org/feeds/o...ss/unstable/syno-mvkw-bootstrap_1.2-7_arm.xsh
Viele Grüsse
Ubuntulinux
Bist Du als root angemeldet?
gruss
dude
Bist schon mit 'root' angemeldet? Post mal einen 'mount'
Itari
danke für die Antworten
Ja ich bin als root angemeldet.
Mount:
diskstation> mount
/dev/md0 on / type ext3 (rw,data=ordered)
/tmp on /tmp type tmpfs (rw)
/sys on /sys type sysfs (rw)
/proc/bus/usb on /proc/bus/usb type usbfs (rw)
/dev/md2 on /volume1 type ext3 (usrquota,grpquota)
/volume1/@optware on /opt type --bind (rw)
diskstation>
Würde mich auch interessieren. Zumal der Lösungsvorschlag in dem Thread quasi ist "schnell direkt nach dem booten einloggen und die Installation starten - nicht zu lange warten". Klingt für mich nach Voodoo... tut mir leid.
gruss
dude
