Hyper Backup Hyper Backup startet nicht!
Toby-ch
02. Okt. 2013
Hallo zusammen
Ich sichere meine DS1815+ ( Haupt Server ) auf meine DS1515+ via Hyperbackup. Doch dies geht nicht mehr richtig wie die folgenden Logs zeigen:
Error	2018/05/11 22:32:35	SYSTEM	[Network][DS1815 To DS1515 Ohne TimeBackup] Failed to run backup task.
Error	2018/05/11 22:32:34	SYSTEM	[Network][DS1815 To DS1515 Ohne TimeBackup] Failed to backup data.
Error	2018/05/11 22:32:26	SYSTEM	[Network][DS1815 To DS1515 Ohne TimeBackup] Exception occurred while backing up data. (Destination is busy deleting backup versions.)
Error	2018/05/11 22:32:26	SYSTEM	[Network][DS1815 To DS1515 Ohne TimeBackup] Failed to access the backup destination. (The backup destination is busy. Please try again later.)
Information	2018/05/11 22:32:15	SYSTEM	[Network][DS1815 To DS1515 Ohne TimeBackup] Backup task started.
Error	2018/05/11 22:12:55	SYSTEM	[Network][DS1815 To DS1515 Ohne TimeBackup] Failed to run backup task.
Error	2018/05/11 22:12:54	SYSTEM	[Network][DS1815 To DS1515 Ohne TimeBackup] Failed to backup data.
Error	2018/05/11 22:12:47	SYSTEM	[Network][DS1815 To DS1515 Ohne TimeBackup] Exception occurred while backing up data. (Destination is busy deleting backup versions.)
Error	2018/05/11 22:12:47	SYSTEM	[Network][DS1815 To DS1515 Ohne TimeBackup] Failed to access the backup destination. (The backup destination is busy. Please try again later.)
Information	2018/05/11 22:12:34	SYSTEM	[Network][DS1815 To DS1515 Ohne TimeBackup] Backup task started.
Error	2018/05/11 22:00:26	SYSTEM	[Network][DS1815 To DS1515 Ohne TimeBackup] Failed to run backup task.
Error	2018/05/11 22:00:25	SYSTEM	[Network][DS1815 To DS1515 Ohne TimeBackup] Failed to backup data.
Error	2018/05/11 22:00:18	SYSTEM	[Network][DS1815 To DS1515 Ohne TimeBackup] Exception occurred while backing up data. (Destination is busy deleting backup versions.)
Error	2018/05/11 22:00:18	SYSTEM	[Network][DS1815 To DS1515 Ohne TimeBackup] Failed to access the backup destination. (The backup destination is busy. Please try again later.)
Information	2018/05/11 22:00:04	SYSTEM	[Network][DS1815 To DS1515 Ohne TimeBackup] Backup task started.
Information	2018/05/11 00:05:17	SYSTEM	[DS1815 To DS1515 Ohne TimeBackup] Trigger version rotation.
Information	2018/05/11 00:05:15	SYSTEM	[Network][DS1815 To DS1515 Ohne TimeBackup] Backup task finished successfully. [2498005 files scanned] [65 new files] [23 files modified] [2497917 files unchanged]
Information	2018/05/10 22:07:38	SYSTEM	[Network][DS1815 To DS1515 Ohne TimeBackup] Backup task started.
Error	2018/05/10 22:04:03	SYSTEM	[Network][DS1815 To DS1515 Ohne TimeBackup] Failed to run backup task.
DAS GEHT SO WEITER ANGEFANGEN HAT ES NACH DIESEM EINTRAG:
Error	2018/04/29 18:11:03	SYSTEM	[Network][DS1815 To DS1515 Ohne TimeBackup] Failed to run backup task.
Error	2018/04/29 18:11:01	SYSTEM	[Network][DS1815 To DS1515 Ohne TimeBackup] Failed to backup data.
Error	2018/04/29 18:10:54	SYSTEM	[Network][DS1815 To DS1515 Ohne TimeBackup] Exception occurred while backing up data. (Destination is busy deleting backup versions.)
Error	2018/04/29 18:10:54	SYSTEM	[Network][DS1815 To DS1515 Ohne TimeBackup] Failed to access the backup destination. (The backup destination is busy. Please try again later.)
Information	2018/04/29 18:10:42	SYSTEM	[Network][DS1815 To DS1515 Ohne TimeBackup] Backup task started.
Information	2018/04/29 18:10:11	admin	[DS1815 To DS1515 Ohne TimeBackup] Trigger version rotation.
Information	2018/04/29 18:10:11	admin	[Network][DS1815 To DS1515 Ohne TimeBackup] Enabled backup rotation [Smart Recycle, number of versions: 30].
Information	2018/04/29 18:10:11	admin	[Network][DS1815 To DS1515 Ohne TimeBackup] Add shared folders
ES GING DANACH PLÖTZLICH TEILWEISE JEDOCH SEIT MEINEM EINGREIFFEN:
Information	2018/05/05 23:49:33	admin	[DS1815 To DS1515 Ohne TimeBackup] Trigger version rotation.
Information	2018/05/05 23:49:32	admin	[Network][DS1815 To DS1515 Ohne TimeBackup] Enabled backup rotation [Smart Recycle, number of versions: 14].
Hier das log der DS1515+
Error	2018/05/11 22:32:26	DS1815	[192.168.0.176] Failed to start backup.
Error	2018/05/11 22:12:47	DS1815	[192.168.0.176] Failed to start backup.
Error	2018/05/11 22:00:18	DS1815	[192.168.0.176] Failed to start backup.
Information	2018/05/11 17:47:08	DS1815	[Localhost] Version [2017-09-30 21:00:13] rotated.
Information	2018/05/11 14:54:06	DS1815	[Localhost] Version [2017-09-20 21:00:13] rotated.
Information	2018/05/11 12:59:33	DS1815	[Localhost] Version [2017-09-09 21:00:40] rotated.
Information	2018/05/11 10:52:47	DS1815	[Localhost] Version [2017-08-31 21:01:08] rotated.
Information	2018/05/11 08:27:48	DS1815	[Localhost] Version [2017-08-18 21:00:24] rotated.
Information	2018/05/11 04:28:09	DS1815	[Localhost] Version [2017-08-09 21:00:52] rotated.
Information	2018/05/11 02:03:50	DS1815	[Localhost] Version [2017-08-02 21:00:54] rotated.
Information	2018/05/11 00:32:58	DS1815	[Localhost] Version [2018-04-12 21:00:15] rotated.
Information	2018/05/11 00:05:20	DS1815	[Localhost] Backup rotation started.
Information	2018/05/11 00:04:33	DS1815	[192.168.0.176] Backup complete.
Information	2018/05/10 23:18:38	DS1815	[192.168.0.176] Backup started.
Error	2018/05/10 22:03:53	DS1815	[192.168.0.176] Failed to start backup.
Error	2018/05/10 22:00:15	DS1815	[192.168.0.176] Failed to start backup.
Error	2018/05/10 21:45:17	DS1815	[192.168.0.176] Failed to start backup.
Information	2018/05/10 20:06:54	DS1815	[Localhost] Version [2017-07-16 21:00:40] rotated.
Information	2018/05/10 17:35:00	DS1815	[Localhost] Version [2017-07-09 21:00:32] rotated.
Information	2018/05/10 16:18:09	DS1815	[Localhost] Version [2017-07-02 21:00:34] rotated.
Information	2018/05/10 14:53:09	DS1815	[Localhost] Version [2017-06-25 21:00:32] rotated.
Information	2018/05/10 13:20:58	DS1815	[Localhost] Version [2017-06-16 21:00:23] rotated.
Information	2018/05/10 10:15:21	DS1815	[Localhost] Version [2017-06-09 00:00:24] rotated.
Information	2018/05/10 09:10:36	DS1815	[Localhost] Version [2018-04-11 21:00:15] rotated.
Information	2018/05/10 08:55:14	DS1815	[Localhost] Version [2018-04-10 21:00:16] rotated.
Information	2018/05/10 08:40:49	DS1815	[Localhost] Version [2018-04-09 21:00:15] rotated.
Information	2018/05/10 08:25:15	DS1815	[Localhost] Version [2018-04-08 21:00:30] rotated.
Fatzit seit dem eingriffen vom 05.05.2018 läuft das backup nur wenn ich die DS1515+ zuerst neu starte! Jedoch begreife ich diesen Eintrag nich: The backup destination is busy. Please try again later.) Die DS1515+ Macht nichts. sie läuft auf IDEL keine CPU last oder sonstiges.
Habe ich mir evtl mein Backup abgeschossen ?:confused:
Besten dank für eure Hilfe
