Hyper Backup Hyper Backup Fehler bei Metadaten
GhostTalker
17. Sep. 2012
Hallo
Seit heute bekomme ich immer einen Fehler, wenn ich über Hyper Backup meine Daten auf die externe Festplatte sichern möchte.
Bevor ich nun die Option heraus nehme, wollte ich einmal kurz fragen ob jemand so ein Problem schon einmal gehabt hat.
Das ganze läuft auf der DS212 mit DSM 6.0 - 7321 Update 6
Error,2016/05/29 12:07:52,SYSTEM,[Local to share][Local Backup Set 1] Failed to run backup task.
Error,2016/05/29 12:07:48,SYSTEM,[Local to share][Local Backup Set 1] Failed to backup data.
Error,2016/05/29 12:07:48,SYSTEM,[Local to share][Local Backup Set 1] Exception occured while backing up metadata. [/volume1/@tmp/11672/Markus]
Information,2016/05/29 11:51:40,SYSTEM,[Local to share][Local Backup Set 1] Backup task started.
Error,2016/05/29 11:34:25,SYSTEM,[Local to share][Local Backup Set 1] Failed to run backup task.
Error,2016/05/29 11:34:22,SYSTEM,[Local to share][Local Backup Set 1] Failed to backup data.
Error,2016/05/29 11:34:22,SYSTEM,[Local to share][Local Backup Set 1] Exception occured while backing up metadata. [/volume1/@tmp/4153/Markus]
Information,2016/05/29 11:18:37,SYSTEM,[Local to share][Local Backup Set 1] Backup task started.
Error,2016/05/29 04:09:56,SYSTEM,[Local to share][Local Backup Set 1] Failed to run backup task.
Error,2016/05/29 04:09:53,SYSTEM,[Local to share][Local Backup Set 1] Failed to backup data.
Error,2016/05/29 04:09:53,SYSTEM,[Local to share][Local Backup Set 1] Exception occured while backing up metadata. [/volume1/@tmp/25432/Markus]
