Firmware DSM 5.0-4482
DesiWeb
15. Juni 2011
Hallo zusammen
meine DS meldete eine neue Firmware (DSM 5.0-4482), welche ich auf der einen DS auch gleich mit Erfolg installiert habe...
Hier die Release-Notes:
Version: 5.0-4482
(2014/04/24)
Compatibility and Installation
After installing this version of DSM on DS214play, the device will shut down and then power on automatically after two minutes.
Change Log
Added the GeoIP* feature in Firewall settings, enabling you to allow or block IP addresses from certain countries.
Added an option to save files in UTF-8 (with BOM) format in Text Editor.
Fixed a security issue of Windows File Service to prevent remote attackers from obtaining access. (CVE-2013-4496)
Fixed several security issues related to cURL. (CVE-2014-0139, CVE-2014-0015, CVE-2013-6422)
Fixed an issue where CGI programs could not run on Personal websites.
Added feature to disconnect user connections to HTTP(S) services after a user's password is changed.
Improved the stability of iSCSI target service.
Improved the stability of file transfers via Apple File Protocol.
*This feature includes GeoLite data created by MaxMind, available from http://www.maxmind.com.
Viel Erfolg!
na toll, wie ofte denn noch, kannst du alles hier lesen
