Emails werden nicht verschickt
Bluefire69
07. Aug. 2012
Moin zusammen
versuche gerade Zarafa zum laufen zu bekommen - EMails empfangen geht ohne Probleme - Problem ist beim versenden
Emails werden in den Ordner Sent Items verschoben, kommen aber beim Empfänger nicht an
Zarafa Spooler.log sagt
Sat Oct 27 13:35:42 2012: [31150] Sending e-mail for user XXX, subject: 'test', size: 1897
Sat Oct 27 13:35:42 2012: [31150] Sending message with Message-ID: zarafa.508bc70e.79ae.077d8d8e36fa8b8b@XXX
Sat Oct 27 13:35:43 2012: [31150] E-mail for user XXX was accepted by SMTP server
Messages.log sagt
Oct 27 13:35:42 postfix/smtpd[31281]: connect from localhost[127.0.0.1]
Oct 27 13:35:43 postfix/smtpd[31281]: 22A7E16E1: client=localhost[127.0.0.1]
Oct 27 13:35:43 postfix/cleanup[31284]: 22A7E16E1: message-id=<zarafa.508bc70e.79ae.077d8d8e36fa8b8b@XXX>
Oct 27 13:35:43 postfix/smtpd[31281]: disconnect from localhost[127.0.0.1]
Oct 27 13:35:43 postfix/qmgr[7660]: 22A7E16E1: from=<XXX>, size=1949, nrcpt=1 (queue active)
Oct 27 13:35:43 spamd[9074]: spamd: connection from localhost [127.0.0.1] at port 50914
Oct 27 13:35:43 spamd[9074]: spamd: setuid to spamfilter succeeded
Oct 27 13:35:43 spamd[9074]: spamd: processing message <zarafa.508bc70e.79ae.077d8d8e36fa8b8b@XXX> for spamfilter:783
Oct 27 13:35:44 spamd[9074]: spamd: clean message (-0.6/5.0) for spamfilter:783 in 0.6 seconds, 1907 bytes.
Oct 27 13:35:44 spamd[9074]: spamd: result: . 0 - ALL_TRUSTED,AWL,HTML_MESSAGE,MIME_HTML_MOSTLY,MPART_ALT_DIFF scantime=0.6,size=1907,user=spamfilter,uid=783,required_score=5.0,rhost=localhost,raddr=127.0.0.1,rport=50914,mid=<zarafa.508bc70e.79ae.077d8d8e36fa8b8b@XXX
Oct 27 13:35:44 spamd[8005]: prefork: child states: II
Oct 27 13:35:44 postfix/pickup[7659]: B7DFA16E3: uid=783 from=<XXX>
Oct 27 13:35:44 postfix/cleanup[31284]: B7DFA16E3: message-id=<zarafa.508bc70e.79ae.077d8d8e36fa8b8b@XXX>
Oct 27 13:35:44 postfix/pipe[31349]: 22A7E16E1: to=<XXX>, relay=spamassassin, delay=1.8, delays=0.28/0.21/0/1.3, dsn=2.0.0, status=sent (delivered via spamassassin service)
Oct 27 13:35:44 postfix/qmgr[7660]: 22A7E16E1: removed
Oct 27 13:35:44 postfix/qmgr[7660]: B7DFA16E3: from=<XXX>, size=2286, nrcpt=1 (queue active)
Oct 27 13:35:46 postfix/pipe[31451]: B7DFA16E3: to=<XXX>, relay=zarafa, delay=2.2, delays=0.02/0.3/0/1.9, dsn=5.3.0, status=bounced (internal software error)
Oct 27 13:35:46 postfix/cleanup[31284]: E889E16E2: message-id=<20121027113546.E889E16E2@XXX.de>
Oct 27 13:35:46 postfix/qmgr[7660]: E889E16E2: from=<>, size=3949, nrcpt=1 (queue active)
Oct 27 13:35:46 postfix/bounce[31553]: B7DFA16E3: sender non-delivery notification: E889E16E2
Oct 27 13:35:46 postfix/qmgr[7660]: B7DFA16E3: removed
Oct 27 13:35:48 postfix/pipe[31451]: E889E16E2: to=<XXX>, relay=zarafa, delay=1.3, delays=0.02/0/0/1.3, dsn=5.3.0, status=bounced (internal software error)
Oct 27 13:35:48 postfix/qmgr[7660]: E889E16E2: removed
Verstehe nicht so ganz den internal software error und sender non-delivery notification - jemand eine Idee ?
DSM 4.1 und Zarafa 0.2.9 mit Z-Push 1.5.11 installiert
Kannst du mal den Spamassin ausknipsen und schauen ob es dann funktioniert?
Gruß Julian
Moin Julian
Spamassin ist aus - hat aber nix gebracht - Emails wandern weiter in den Sent Item Ordner, kommen beim Empfänger aber nicht an
Messages.log
Oct 27 19:03:04 postfix/smtpd[5750]: connect from localhost[127.0.0.1]
Oct 27 19:03:04 postfix/smtpd[5750]: 7AD4216ED: client=localhost[127.0.0.1]
Oct 27 19:03:04 postfix/cleanup[5819]: 7AD4216ED: message-id=<zarafa.508c13c7.15ee.3d74d5655e501381@XXX>
Oct 27 19:03:04 postfix/smtpd[5750]: disconnect from localhost[127.0.0.1]
Oct 27 19:03:04 postfix/qmgr[631]: 7AD4216ED: from=<XXX.de>, size=1949, nrcpt=1 (queue active)
Oct 27 19:03:06 postfix/pipe[5822]: 7AD4216ED: to=<XXX.de>, relay=zarafa, delay=2.2, delays=0.26/0.22/0/1.8, dsn=5.3.0, status=bounced (internal software error)
Oct 27 19:03:06 postfix/cleanup[5819]: 98A6216EF: message-id=<20121027170306.98A6216EF@XXX.de>
Oct 27 19:03:06 postfix/qmgr[631]: 98A6216EF: from=<>, size=3662, nrcpt=1 (queue active)
Oct 27 19:03:06 postfix/bounce[5955]: 7AD4216ED: sender non-delivery notification: 98A6216EF
Oct 27 19:03:06 postfix/qmgr[631]: 7AD4216ED: removed
Oct 27 19:03:07 postfix/pipe[5822]: 98A6216EF: to=<XXX.de>, relay=zarafa, delay=1.1, delays=0.02/0/0/1.1, dsn=5.3.0, status=bounced (internal software error)
Oct 27 19:03:07 postfix/qmgr[631]: 98A6216EF: removed
Das dagent.log sagt
Sat Oct 27 19:03:06 2012: [ 5887] Failed to resolve recipient ronny
Sat Oct 27 19:03:07 2012: [ 5957] Failed to resolve recipient info
und spooler.log weiterhin
Sat Oct 27 19:03:03 2012: [ 5614] Sending e-mail for user XXX, subject: 'test', size: 1897
Sat Oct 27 19:03:03 2012: [ 5614] Sending message with Message-ID: zarafa.508c13c7.15ee.3d74d5655e501381@XXX
Sat Oct 27 19:03:04 2012: [ 5614] E-mail for user XXX was accepted by SMTP server
Danke und Gruß
Ronny
