Hallo
Ich finde nichts verdächtiges im Log :
Nov 10 08:47:11 syslogd started: BusyBox v1.16.1
Nov 10 08:47:11 kernel: [ 36.920000] cesadev_init(bf17b000)
Nov 10 08:47:11 kernel: [ 36.950000] mvCesaInit: sessions=10240, queue=64, pSram=f0000000
Nov 10 08:47:11 kernel: [ 37.090000] encryptfs using the OCF package.
Nov 10 08:47:11 kernel: [ 37.480000] correction with 0x0f
Nov 10 08:47:11 kernel: [ 37.540000] Brand: Synology
Nov 10 08:47:11 kernel: [ 37.540000] Model: DS-212+
Nov 10 08:47:11 kernel: [ 37.540000] This is default settings: set group disks wakeup number to 1, spinup time deno 1
Nov 10 08:47:12 spacetool: spacetool.c:2463 [Info] Old vg path: [/dev/vg1000], New vg path: [/dev/vg1000], UUID: [ewGNHb-MoWC-x1CG-hoBA-oh3i-dfv6-gDsfWx]
Nov 10 08:47:12 spacetool: spacetool.c:2470 [Info] Activate all VG
Nov 10 08:47:12 spacetool: spacetool.c:2481 Activate LVM [/dev/vg1000]
Nov 10 08:47:13 synovspace: vspace_wrapper_load_all.c:75 [INFO] The mount device path of space [/volume1] is [/dev/vg1000/lv]
Nov 10 08:47:21 scemd: scemd.c:155 fan_type=6, raid_type=1, led_type=1, thermal_type=2, diskled_ctrl_type=1, auto_poweron_type=1, dual_power_type=1, usbcopy_type=1, fan_number=1, eunit_pwron_type=2, pis_type=1, rtc_type=1, lcm_type=2, wifi_wps_type=0
Nov 10 08:47:21 scemd: modules/fan_speed_adjust_common.c:118 Type: INTERNAL Fan Mode: LOW
Nov 10 08:47:22 scemd: modules/raid_sys_volume_check.c:150 MD0 active disks 2, designed disks 2
Nov 10 08:47:22 scemd: modules/raid_sys_volume_check.c:150 MD1 active disks 2, designed disks 2
Nov 10 08:47:22 scemd: modules/disk_hibernation.c:1783 Force hibernation enable, idle minutes 10
Nov 10 08:47:22 scemd: modules/disk_hibernation.c:1798 SATA Deep sleep timer 1
Nov 10 08:47:22 scemd: modules/disk_hibernation.c:1807 Eunit Deep sleep timer 0
Nov 10 08:47:22 scemd: disk/disk_config_all.c:124 apply /usr/syno/bin/syno_disk_ctl --wcache-off /dev/sda 1>/dev/null 2>&1
Nov 10 08:47:22 scemd: disk/disk_config_all.c:124 apply /usr/syno/bin/syno_disk_ctl --wcache-off /dev/sdb 1>/dev/null 2>&1
Nov 10 08:47:22 kernel: [ 51.440000] ata1.00: Disable disk write cache in EH
Nov 10 08:47:23 kernel: [ 51.530000] ata2.00: Disable disk write cache in EH
Nov 10 08:47:23 scemd: modules/scemd_connector.c:103 scemd connector thread start.
Nov 10 08:47:23 scemd: scemd.c:155 fan_type=6, raid_type=1, led_type=1, thermal_type=2, diskled_ctrl_type=1, auto_poweron_type=1, dual_power_type=1, usbcopy_type=1, fan_number=1, eunit_pwron_type=2, pis_type=1, rtc_type=1, lcm_type=2, wifi_wps_type=0
Nov 10 08:47:23 scemd: scemd.c:354 WIFI/WPS button is not support on this model.
Nov 10 08:47:23 kernel: [ 51.950000] usb usb2: No SuperSpeed endpoint companion for config 1 interface 0 altsetting 0 ep 129: using minimum values
Nov 10 08:47:23 kernel: [ 52.140000] Got empty serial number. Generate serial number from product.
Nov 10 08:47:24 synoprint: printer_enable_ext.c:488 delete printer failed: no bus id
Nov 10 08:47:24 syno_hdd_util: Model:[WD20EARX-00PASB0], Firmware:[51.0AB51], S/N:[WD-WCAZAF484056] in [/dev/sdb] is not ssd
Nov 10 08:47:24 manutild: user_db_open.c:213 SLIBCBdbOpen [/tmp/.db.user.tmp.4754.name.2647] failed. synoerr=0x0700
Nov 10 08:47:24 manutild: user_db_rebuild.c:65 rename(/tmp/.db.user.tmp.4754.name.2647, /tmp/.db.user.name.2647) = (2)/No such file or directory
Nov 10 08:47:24 manutild: user_db_open.c:291 user db is still not ready after rebuild
Nov 10 08:47:24 syno_hdd_util: Model:[WD20EARX-00PASB0], Firmware:[51.0AB51], S/N:[WD-WCAZAF062953] in [/dev/sda] is not ssd
Nov 10 08:47:26 synocheckshare: Fix shares in smb.conf.
Nov 10 08:47:26 synocheckshare: service_disable_set.c(68)Not defined date : id=4
Nov 10 08:47:30 synousbdisk: RCClean succeeded
Nov 10 08:47:31 synosata: synosata.c:152 no external sata devices granted
Nov 10 08:47:33 ddnsd: main(ddnsd.c:3006): not enable DDNS, shutdown daemon
Nov 10 08:47:33 hotplugd: hotplugd.c:1033 failed get usb status from usb config, DEVICE=/proc/bus/usb/001/001, usbid=1d6b:0002
rion-ehci.0
Nov 10 08:47:33 hotplugd: ##### ACTION:add
Nov 10 08:47:33 hotplugd: DEVICE:/proc/bus/usb/001/001
Nov 10 08:47:33 hotplugd: DEVPATH:usb1
Nov 10 08:47:33 hotplugd: SUBSYSTEM:usb
Nov 10 08:47:33 hotplugd: hotplugd.c:807 Fail to recognize usb DEVNAME=, DEVPATH=usb1
Nov 10 08:47:33 hotplugd: hotplugd.c:1331 failed to setup usb config, (DEVPATH, DEVICE, ACTION, DEVNAME, INTERFACE)=(usb1, /proc/bus/usb/001/001, add, , )
rion-ehci.0
Nov 10 08:47:33 hotplugd: DEVPATH:1-0:1.0
Nov 10 08:47:33 hotplugd: INTERFACE:9/0/0
Nov 10 08:47:33 hotplugd: hotplugd.c:1033 failed get usb status from usb config, DEVICE=/proc/bus/usb/002/001, usbid=1d6b:0003:0000:01:01.0
Nov 10 08:47:33 hotplugd: DEVICE:/proc/bus/usb/002/001
Nov 10 08:47:33 hotplugd: DEVPATH:usb2
Nov 10 08:47:33 hotplugd: hotplugd.c:807 Fail to recognize usb DEVNAME=, DEVPATH=usb2
Nov 10 08:47:33 hotplugd: hotplugd.c:1331 failed to setup usb config, (DEVPATH, DEVICE, ACTION, DEVNAME, INTERFACE)=(usb2, /proc/bus/usb/002/001, add, , )
Nov 10 08:47:33 hotplugd: DEVPATH:2-0:1.0
Nov 10 08:47:33 hotplugd: DEVICE:/proc/bus/usb/001/002
Nov 10 08:47:33 hotplugd: DEVPATH:1-1
Nov 10 08:47:33 hotplugd: external_disk_port_check.c:280 device path should not be NULL
Nov 10 08:47:33 hotplugd: DEVPATH:1-1:1.0
Nov 10 08:47:33 hotplugd: hotplugd.c:835 ##### complete device hotplug!!
Nov 10 08:47:36 upnpd: (upnpd.c:203) upnpd.c(203) : IP change (old IP = NULL, new IP = 46.140.82.54)
Nov 10 08:48:07 root: Cloud Station updater: Upgrade database
Nov 10 08:48:07 root: Cloud Station updater: start upgrade data db
Nov 10 08:48:07 root: Cloud Station updater: start upgrade server db
Nov 10 08:48:08 root: Cloud Station updater: start move db
Nov 10 08:48:08 root: moving old client DB for
Nov 10 08:48:08 root: all volume: /volume1 /volumeUSB1
Nov 10 08:48:08 root: create /volume1/@tmp/@cstn-share.8759
Nov 10 08:48:08 root: create /volumeUSB1/@tmp/@cstn-share.8759
Nov 10 08:48:08 root: moving old client OK
Nov 10 08:48:08 root: CS: [start.sh]: Cloud station start...
Nov 10 08:48:35 synorelayd: stop failed, start again
killall: synolunbkp: no process killed
Nov 10 08:49:22 scemd: scemd.c:414 stop manutild.
Nov 10 09:03:11 usrctl: [ERROR] db-api.cpp:284 sqlite3_open: unable to open database file
Nov 10 09:03:11 usrctl: [ERROR] service-ctrl.cpp(1105): Fail to initialize ver db /volume1/@cloudstation and user db !
Nov 10 09:44:17 usrctl: [ERROR] db-api.cpp:284 sqlite3_open: unable to open database file
Nov 10 09:44:17 usrctl: [ERROR] service-ctrl.cpp(1105): Fail to initialize ver db /volume1/@cloudstation and user db !
Nov 10 10:39:41 usrctl: [ERROR] db-api.cpp:284 sqlite3_open: unable to open database file
Nov 10 10:39:41 usrctl: [ERROR] service-ctrl.cpp(1105): Fail to initialize ver db /volume1/@cloudstation and user db !
Ich greife via Name (webaccess) und via IP Adresse z. B. Via Package Center - Zarafa - More auf die Webseiten zu.
Im Übrigen habe ich eine fixe interne und externe IP Adresse.
