- 30. Juni 2016
habe meine DS415play per seriell am PC dran und bekomme beim booten folgenden Fehler.
shell> reset
WARM_BOOT
Intel(R) Consumer Electronics Firmware Development Kit (Intel(R) CEFDK)
Copyright (C) 1999-2012 Intel Corporation. All rights reserved.
Build Time (02/06/14 19:05:13).
Searching 8051 FW in MFH...
Load 8051 FW from MFH successfully!
No active splash screen found in flash.
Showing black screen.
SMM: Ok
ACPI Init: finished with table region from 00011aa0 to 00018000
acpi: Created tables at 00011aa0-00018000
PCIe Port0 setting: Auto
PCIe Port1 setting: Auto
CEFDK Version : CE5300 (SMP enabled)
8051 Firmware : C0-1.0.49 (0x00050000)
8051 FW I/O Module : NEC-1.0.082
Silicon Stepping : D0 (PCI)
Silicon SKU : 0x07C
Board : REF0
CPU Threads : 4
CPU Multiplier : 12
CPU Bus Speed : 100 MHz
Memory Size : 1024 MB
Memory Type & Speed : x16 DDR3-1600 (11-11-11)
Memory Configuration : A B Interleave Mode 1
PCI Mode : PCI Standard
Boot Mode : SPI-NOR
mac address is the same, skip sync.
Registered net controller: e1000e
Waiting for the Link up: /
1000M FD Link is ready!
Configure IP via static IP.
Mac address is : 00:11:32:38:E6:24
Host IP address is: 192.168.2.100
Subnet Mask is : 255.255.255.0
Gateway address is: 192.168.2.1
Press 'Enter' within 2 seconds to disable automatic boot.
Hit a key to start the shell...
ERROR: Kernel not found!
Attempting to boot Linux from NOR ...
Kernel not found at 0xC0140000 in NOR, continue booting from HD.
Attempting to boot Redboot...
ERROR: No active Redboot found in flash.
Attempting to boot Linux...
Attempting to boot from HDD...
Attempting to boot redboot from Sector 1 of HD 0...
No valid redboot found in HD(s).
Reading boot sector...done.
Error: Invalid boot sector.
Was kann ich tun?
Vielen Dank!
shell> reset
WARM_BOOT
SMM: Ok
Silicon SKU : 0x07C
Board : REF0
CPU Threads : 4
CPU Multiplier : 12
Boot Mode : SPI-NOR
Was kann ich tun?
Vielen Dank!
