DSM 7.2 DS216j - MariaDB - GSSAPI plugin error
Tamagotschi
22. Juli 2019
Hallo!
Nach einem Upgrade aug DSM 7.2.1 - 69057 Update 1
bekomme ich Fehlermeldungen in der LOG Datei:
231106 10:48:07 mysqld_safe Starting mariadbd daemon with databases from /var/packages/MariaDB10/target/mysql
2023-11-06 10:48:08 0 [Warning] option 'table_open_cache': unsigned value 4 adjusted to 10
2023-11-06 10:48:08 0 [Note] Starting MariaDB 10.11.2-MariaDB source revision 358cf98197cbb847ec51228c53472b40393fe44e as process 18034
2023-11-06 10:48:08 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
2023-11-06 10:48:08 0 [Note] InnoDB: Number of transaction pools: 1
2023-11-06 10:48:08 0 [Note] InnoDB: Using generic crc32 instructions
2023-11-06 10:48:08 0 [Note] InnoDB: Using Linux native AIO
2023-11-06 10:48:08 0 [Note] InnoDB: Initializing buffer pool, total size = 16.000MiB, chunk size = 1.000MiB
2023-11-06 10:48:08 0 [Note] InnoDB: Completed initialization of buffer pool
2023-11-06 10:48:08 0 [Note] InnoDB: File system buffers for log disabled (block size=4096 bytes)
2023-11-06 10:48:08 0 [Note] InnoDB: 128 rollback segments are active.
2023-11-06 10:48:08 0 [Note] InnoDB: Setting file '/var/packages/MariaDB10/target/mysql/ibtmp1' size to 12.000MiB. Physically writing the file full; Please wait ...
2023-11-06 10:48:08 0 [Note] InnoDB: File '/var/packages/MariaDB10/target/mysql/ibtmp1' size is now 12.000MiB.
2023-11-06 10:48:08 0 [Note] InnoDB: log sequence number 222744993; transaction id 837209
2023-11-06 10:48:08 0 [Note] InnoDB: Loading buffer pool(s) from /volume1/@appdata/MariaDB10/mariadb10/ib_buffer_pool
2023-11-06 10:48:08 0 [Note] Plugin 'FEEDBACK' is disabled.
2023-11-06 10:48:08 0 [Warning] mariadbd: GSSAPI plugin : default principal 'mariadb/localhost@' not found in keytab
2023-11-06 10:48:08 0 [ERROR] mariadbd: Server GSSAPI error (major 851968, minor 2529639093) : gss_acquire_cred failed -Unspecified GSS failure. Minor code may provide more information. Keytab FILE:/etc/krb5.keytab is nonexistent or empty.
2023-11-06 10:48:08 0 [ERROR] Plugin 'gssapi' init function returned error.
2023-11-06 10:48:08 0 [Note] Server socket created on IP: '0.0.0.0'.
2023-11-06 10:48:08 0 [Note] /usr/local/mariadb10/bin/mariadbd: ready for connections.
Version: '10.11.2-MariaDB' socket: '/run/mysqld/mysqld10.sock' port: 3306 Source distribution
2023-11-06 10:48:08 3 [Warning] Access denied for user 'root'@'localhost' (using password: NO)
2023-11-06 10:48:08 0 [Note] InnoDB: Buffer pool(s) load completed at 231106 10:48:08
GSSAPI Fehler - kann das der Grund sein, warum ich mit einer Window Anwendung nicht mehr auf die Datenbank konnektieren kann?
VG
Nein, der Fehler steht in der vorletzten Zeile:
Setze also ein Passwort für den MariaDB root user und teste es danach erneut
Ansonsten ggf. hier mal nachlesen:
https://mariadb.com/kb/en/authentication-plugin-gssapi/
Okay, habe ja nichts verändert - nur ein Upgrade DSM 7.1.x auf DSM 7.2.1 - 69057 Update 1.
Vorher war mariaDB 10.3.x drauf, nun - soweit ich das sehen kann - 10.11.2 .
Also was muss ich tun, damit alles wieder klappt??
Dann weiß ich auch nicht weiter.
Ggf. ein Ticket bei Synology eröffnen.
Ok, Problem gelöst.
Habe ein Backup der Datenbank gemacht, dann die Version MariaDB 10.11.x deinstalliert.
Danach das PKT von MariaDB 10.3.x (DMS Version 7.1) installiert. Diese Version kann man auf der Synologyseiter runter laden.
Das PKT lässt sich - zum Glück - installieren.
DB Sicherung wieder eingespielt, fertig.
Und schon klappen die Anmeldungen div. Programme mit der DB wieder ;-)
