Nummer Serie DS214Se Blue LED Blinking
KRP81
03. Jan. 2018
Due to Power Failure during update My NAS (Synology DS214Se) not booting. Synology assistant Not Detecting my NAS.
I have connected DS214Se using USB to Serial TTL adapter via Serial port on Motherboard of Synology DS214Se. I got it connected via extraputty and the rest is mentioned below.
Need Help to recover my DS214Se.
BootROM 1.08
Booting from SPI flash
High speed PHY - Version: 2.1.2 (COM-PHY-V20)
Update PEX Device ID 0x67100
High speed PHY - Ended Successfully
DDR3 Training Sequence - Ver 4.5.0
DDR3 Training Sequence - Ended Successfully
Status = MV_OK
BootROM: Image checksum verification PASSED
__ __ _ _
| \/ | __ _ _ ____ _____| | |
| |\/| |/ _` | '__\ \ / / _ \ | |
| | | | (_| | | \ V / __/ | |
|_| |_|\__,_|_| \_/ \___|_|_|
_ _ ____ _
| | | | | __ ) ___ ___ | |_
| | | |___| _ \ / _ \ / _ \| __|
| |_| |___| |_) | (_) | (_) | |_
\___/ |____/ \___/ \___/ \__|
** LOADER **
U-Boot 2011.12-SYNO-944e83b-2013-08-13 (Aug 14 2013 - 14:05:18) Marvell version: v2011.12 2013_Q1.2
Board: SYNO-DS214se-BP
SoC: MV6710 A1
CPU: Marvell PJ4B v7 UP (Rev 1) LE
CPU @ 800 [MHz]
L2 @ 533 [MHz]
TClock @ 200 [MHz]
DDR @ 533 [MHz]
DDR 16Bit Width, FastPath Memory Access
DRAM: 256 MiB
Map: Code: 0x0ff09000:0x0ffa1354
BSS: 0x0ffef0a0
Stack: 0x0f9f8ef8
Heap: 0x0f9f9000:0x0ff09000
MMC: MRVL_MMC: 0
SF: Detected M25P64 with page size 64 KiB, total 8 MiB
*** Warning - bad CRC, using default environment
PEX 0.0(0): Detected No Link.
PEX 0.1(1): Detected No Link.
FPU not initialized
USB 0: Host Mode
USB 1: Host Mode
Modules/Interfaces Detected:
RGMII0 Phy
PEX0 (Lane 0)
PEX1 (Lane 1)
SATA0 (Lane 2)
SATA1 (Lane 3)
Synology Model: DS214se
Fan Status: Good
Net: egiga0 [PRIME]
Press Ctrl+C to abort autoboot in 3 second
## Booting kernel from Legacy Image at f40c0000 ...
Image Name: Linux-3.2.40
Created: 2017-10-06 10:13:18 UTC
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2157536 Bytes = 2.1 MiB
Load Address: 00008000
Entry Point: 00008000
Verifying Checksum ... Bad Data CRC
ERROR: can't get kernel image!
Marvell>> setenv ipaddr 192.168.1.15
Marvell>> setenv serverip 192.168.1.3
Marvell>> setenv gatewayip 192.168.1.1
Marvell>> tftpboot 0x2000000 zImage
Using egiga0 device
TFTP from server 192.168.1.3; our IP address is 192.168.1.15
Filename 'zImage'.
Load address: 0x2000000
Loading: #################################################################
done
Bytes transferred = 2157304 (20eaf8 hex)
Marvell>> tftpboot 0x3000000 rd.bin
Using egiga0 device
Filename 'rd.bin'.
Load address: 0x3000000
done
Bytes transferred = 3669524 (37fe14 hex)
Marvell>> tftpboot 0x4000000 uboot_DS214se.bin
Using egiga0 device
Filename 'uboot_DS214se.bin'.
Load address: 0x4000000
done
Bytes transferred = 742968 (b5638 hex)
Marvell>> bootm 0x2000000 0x3000000 0x4000000
## Booting kernel from Legacy Image at 02000000 ...
Created: 2017-11-10 12:07:36 UTC
Data Size: 2157240 Bytes = 2.1 MiB
Verifying Checksum ... OK
## Loading init Ramdisk from Legacy Image at 03000000 ...
Image Name: synology_armada370_214se 15217
Created: 2017-11-10 15:39:43 UTC
Image Type: ARM Linux RAMDisk Image (gzip compressed)
Data Size: 3669460 Bytes = 3.5 MiB
Load Address: 08000000
Entry Point: 08000000
Loading Kernel Image ... OK
OK
BootROM 1.08
Status = MV_OK
__ __ _ _
_ _ ____ _
| | | | | __ ) ___ ___ | |_
** LOADER **
SoC: MV6710 A1
CPU @ 800 [MHz]
L2 @ 533 [MHz]
TClock @ 200 [MHz]
DDR @ 533 [MHz]
DRAM: 256 MiB
BSS: 0x0ffef0a0
Stack: 0x0f9f8ef8
MMC: MRVL_MMC: 0
FPU not initialized
USB 0: Host Mode
USB 1: Host Mode
RGMII0 Phy
PEX0 (Lane 0)
PEX1 (Lane 1)
SATA0 (Lane 2)
SATA1 (Lane 3)
Fan Status: Good
Net: egiga0 [PRIME]
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
[ 0.000000] Linux version 3.2.40 (root@build3) (gcc version 4.9.3 20150311 (p rerelease) (crosstool-NG 1.20.0) ) #15217 Fri Nov 10 20:06:54 CST 2017
[ 0.000000] CPU: Marvell PJ4Bv7 Processor [561f5811] revision 1 (ARMv7), cr=1 8c53c7d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] Machine: Marvell Armada-370
[ 0.000000] Using UBoot passing parameters structure
[ 0.000000] >>>>>>>Tag MAC ae:1d:06:43:50:00
[ 0.000000] >>>>>>>Tag MAC 00:00:00:00:00:00
[ 0.000000] Memory policy: ECC disabled, Data cache writealloc
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping off. Total pa ges: 65024
[ 0.000000] Kernel command line: console=ttyS0,115200 ip=off initrd=0x8000040 ,8M root=/dev/md0 rw syno_hw_version=DS214se ihd_num=2 netif_num=1 flash_size=8
[ 0.000000] Synology Hardware Version: DS214se-j
[ 0.000000] Internal HD num: 2
[ 0.000000] Internal netif num: 1
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Memory: 256MB = 256MB total
[ 0.000000] Memory: 239476k/239476k available, 22668k reserved, 0K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xd0800000 - 0xfa800000 ( 672 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xd0000000 ( 256 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0530000 (5280 kB)
[ 0.000000] .init : 0xc0530000 - 0xc0559000 ( 164 kB)
[ 0.000000] .data : 0xc055a000 - 0xc05862e0 ( 177 kB)
[ 0.000000] .bss : 0xc0586304 - 0xc05e53b0 ( 381 kB)
[ 0.000000] NR_IRQS:256
[ 0.000000] a370_time_init
[ 0.000000] sched_clock: 32 bits at 533MHz, resolution 1ns, wraps every 8058m s
[ 3.054894] Calibrating delay loop... 795.44 BogoMIPS (lpj=3977216)
[ 3.094864] pid_max: default: 32768 minimum: 301
[ 3.094988] Security Framework initialized
[ 3.095027] AppArmor: AppArmor initialized
[ 3.095084] Mount-cache hash table entries: 512
[ 3.095419] CPU: Testing write buffer coherency: ok
[ 3.096112] devtmpfs: initialized
[ 3.100176] xor: measuring software checksum speed
[ 3.144834] arm4regs : 816.400 MB/sec
[ 3.194829] 8regs : 660.000 MB/sec
[ 3.244829] 32regs : 699.200 MB/sec
[ 3.244840] xor: using function: arm4regs (816.400 MB/sec)
[ 3.244989] NET: Registered protocol family 16
[ 3.247205] L0 cache Enabled
[ 3.247219] Speculative Prefetch Disabled
[ 3.247247] Aurora L2 Cache Enabled
[ 3.247281] Support IO coherency.
[ 3.247298] Enable DLB and DRAM write coalescing
[ 3.258979]
[ 3.258986] CPU Interface
[ 3.258993] -------------
[ 3.259000] SDRAM_CS0 ....base 00000000, size 256MB
[ 3.259016] SDRAM_CS1 ....disable
[ 3.259025] SDRAM_CS2 ....disable
[ 3.259034] SDRAM_CS3 ....disable
[ 3.259043] DEVICE_CS0 ....base f2000000, size 32MB
[ 3.259061] DEVICE_CS1 ....no such
[ 3.259082] DEVICE_CS2 ....no such
[ 3.259104] DEVICE_CS3 ....no such
[ 3.259125] PEX0_MEM ....base e0000000, size 32MB
[ 3.259140] PEX0_IO ....base f1100000, size 1MB
[ 3.259155] PEX1_MEM ....base e2000000, size 32MB
[ 3.259171] PEX1_IO ....base f1200000, size 1MB
[ 3.259186] INTER_REGS ....base f1000000, size 1MB
[ 3.259201] DMA_UART ....no such
[ 3.259222] SPI_CS0 ....base f0000000, size 16MB
[ 3.259238] SPI_CS1 ....no such
[ 3.259259] SPI_CS2 ....no such
[ 3.259280] SPI_CS3 ....no such
[ 3.259302] SPI_CS4 ....no such
[ 3.259323] SPI_CS5 ....no such
[ 3.259344] SPI_CS6 ....no such
[ 3.259365] SPI_CS7 ....no such
[ 3.259386] BOOT_ROM_CS ....no such
[ 3.259407] DEV_BOOTCS ....base f5000000, size 16MB
[ 3.259425] PMU_SCRATCHPAD ....no such
[ 3.259446] CRYPT0_ENG ....base c8010000, size 64KB
[ 3.259464]
[ 3.259467] Marvell Armada370 Board-- SYNO-DS214se-BP Soc: MV6710 A1 LE
[ 3.259486] LSP version: linux-3.2.y-2013_Q1.2p2
[ 3.259494]
[ 3.259497]
[ 3.259507] Detected Tclk 200000000, SysClk 533000000, FabricClk 533000000
[ 3.261917] Synology Armada370 DS214se GPIO Init
[ 3.263539] Marvell USB EHCI Host controller #0: c4047000
[ 3.263954] Marvell USB EHCI Host controller #1: c405de00
[ 3.264475] PCI: bus0: Fast back to back transfers enabled
[ 3.264498] mvPexLocalBusNumSet: ERR. Invalid PEX interface 1
[ 3.264508] mvPexLocalDevNumSet: ERR. Invalid PEX interface 1
[ 3.275303] bio: create slab <bio-0> at 0
[ 3.445114] raid6: int32x1 108 MB/s
[ 3.615092] raid6: int32x2 158 MB/s
[ 3.785084] raid6: int32x4 179 MB/s
[ 3.955081] raid6: int32x8 179 MB/s
[ 3.955091] raid6: using algorithm int32x4 (179 MB/s)
[ 3.955892] SCSI subsystem initialized
[ 3.957689] Switching to clocksource armada370_clocksource
[ 3.957895] AppArmor: AppArmor Filesystem Enabled
[ 3.960329] NET: Registered protocol family 2
[ 3.960453] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 3.960700] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 3.960824] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
[ 3.960921] TCP: Hash tables configured (established 8192 bind 8192)
[ 3.960933] TCP reno registered
[ 3.960946] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 3.960967] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 3.961144] NET: Registered protocol family 1
[ 3.961384] RPC: Registered named UNIX socket transport module.
[ 3.961398] RPC: Registered udp transport module.
[ 3.961407] RPC: Registered tcp transport module.
[ 3.961417] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 3.961651] Trying to unpack rootfs image as initramfs...
[ 3.975327] Freeing initrd memory: 8192K
[ 3.975694] XOR registered 4 channels
[ 3.975707] cesadev_init(c0538508)
[ 3.976732] Armada XP hwmon thermal sensor initialized.
[ 3.976861] Initializing Armada-XP CPU power management (WFI)
[ 3.977629] audit: initializing netlink socket (disabled)
[ 3.977670] type=2000 audit(0.900:1): initialized
[ 3.978017] VFS: Disk quotas dquot_6.5.2
[ 3.978060] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 3.978758] msgmni has been set to 483
[ 3.980033] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2 54)
[ 3.980051] io scheduler noop registered
[ 3.980103] io scheduler cfq registered (default)
[ 3.980424] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 3.981782] serial8250.0: ttyS0 at MMIO 0xf1012000 (irq = 41) is a 16550A
[ 4.599722] console [ttyS0] enabled
[ 4.603745] serial8250.1: ttyS1 at MMIO 0xf1012100 (irq = 42) is a 16550A
[ 4.618928] brd: module loaded
[ 4.622010] Loading iSCSI transport class v2.0-870.
[ 4.628316] sata_mv sata_mv.0: slots 32 ports 2
[ 4.634863] scsi0 : sata_mv
[ 4.638270] scsi1 : sata_mv
[ 4.641487] ata1: SATA max UDMA/133 irq 55
[ 4.645614] ata2: SATA max UDMA/133 irq 55
[ 7.977737] ata1: SATA link down (SStatus 0 SControl F300)
[ 10.970163] Delay 5 seconds to wait for disk 2 ready.
[ 16.297731] ata2: SATA link down (SStatus 0 SControl F300)
[ 16.304472] physmap platform flash device: 00800000 at f0000000
[ 16.311746] physmap-flash physmap-flash.0: map_probe failed
[ 16.320750] SPI Serial flash detected @ 0xf0000000, 8192KB (128sec x 64KB)
[ 16.327690] Searching for RedBoot partition table in SYNOMTD-0 at offset 0x7f 0000
[ 16.375024] 6 RedBoot partitions found on MTD device SYNOMTD-0
[ 16.380907] SYNOMTD flash bank 0: Using RedBoot partition definition
[ 16.387299] Creating 6 MTD partitions on "SYNOMTD-0":
[ 16.392395] 0x000000000000-0x0000000c0000 : "RedBoot"
[ 16.398676] 0x0000000c0000-0x000000390000 : "zImage"
[ 16.404727] 0x000000390000-0x0000007d0000 : "rd.gz"
[ 16.410706] 0x0000007d0000-0x0000007e0000 : "vendor"
[ 16.415799] vender Mac1 checksum error ucSum:0x00 Buf:0x00 Sum:0.
[ 16.421951] vender Mac2 checksum error ucSum:0x00 Buf:0x00 Sum:0.
[ 16.428091] vender Mac3 checksum error ucSum:0x00 Buf:0x00 Sum:0.
[ 16.434223] vender Mac4 checksum error ucSum:0xa1 Buf:0x3d Sum:161.
[ 16.440537] vender Mac5 checksum error ucSum:0x5a Buf:0x4e Sum:346.
[ 16.446843] vender Mac6 checksum error ucSum:0x31 Buf:0x2c Sum:305.
[ 16.453156] vender Mac7 checksum error ucSum:0x7c Buf:0x39 Sum:380.
[ 16.459474] serial number='13A0M8N012428'
[ 16.464401] 0x0000007e0000-0x0000007f0000 : "RedBoot Config"
[ 16.471398] 0x0000007f0000-0x000000800000 : "FIS directory"
[ 16.478284] armada-nand armada-nand.0: Initialize HAL based NFC in 8bit mode with DMA Disabled using BCH 4bit ECC
[ 16.490849] armada-nand armada-nand.0: mvNfcInit() failed. Returned 14
[ 16.497593] mv_eth_probe: port_mask=0x3, cpu_mask=0x1
[ 16.502899] o 2 Giga ports supported
[ 16.506670] o SKB recycle supported (Enabled)
[ 16.511238] o NETA acceleration mode 1
[ 16.515185] o RX Queue support: 8 Queues * 128 Descriptors
[ 16.520887] o TX Queue support: 8 Queues * 532 Descriptors
[ 16.526578] o GSO supported
[ 16.529569] o GRO supported
[ 16.532554] o Receive checksum offload supported
[ 16.537371] o Transmit checksum offload supported
[ 16.542284] o Driver ERROR statistics enabled
[ 16.546840]
[ 16.548500] o Loading network interface(s)
[ 16.552802]
[ 16.554303] o Port 0 is connected to Linux netdevice
[ 16.560009] giga p=0: mtu=1500, mac=c4027e44
[ 16.568400] o eth0, ifindex = 2, GbE port = 0
[ 16.572964] o eth0, phy chipid = 1410e90, Support WOL = 0
[ 16.578953]
[ 16.580459]
[ 16.580463] o Warning: GbE port 1 is not connected to PHY/RGMII/Switch, ski p initialization
[ 16.580473]
[ 16.592037]
[ 16.594091] i2c /dev entries driver
[ 16.598539] md: linear personality registered for level -1
[ 16.604061] md: raid0 personality registered for level 0
[ 16.609428] md: raid1 personality registered for level 1
[ 16.614771] md: raid10 personality registered for level 10
[ 16.620298] md: raid6 personality registered for level 6
[ 16.625641] md: raid5 personality registered for level 5
[ 16.630993] md: raid4 personality registered for level 4
[ 16.636755] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-d evel@redhat.com
[ 16.645401] cpuidle: using governor ladder
[ 16.649774] cpuidle: using governor menu
[ 16.653874] cancel mvsdio probe
[ 16.657345] TCP cubic registered
[ 16.660620] NET: Registered protocol family 17
[ 16.665130] Registering the dns_resolver key type
[ 16.670011] VFP support v0.3: implementor 56 architecture 2 part 20 variant 9 rev 6
[ 16.678413] registered taskstats version 1
[ 16.683791] md: Waiting for all devices to be available before autodetect
[ 16.690661] md: If you don't use raid, use raid=noautodetect
[ 16.697103] md: Autodetecting RAID arrays.
[ 16.701255] md: Scanned 0 and added 0 devices.
[ 16.705724] md: autorun ...
[ 16.708544] md: ... autorun DONE.
[ 16.712200] EXT3-fs (md0): error: unable to read superblock
[ 16.717950] EXT2-fs (md0): error: unable to read superblock
[ 16.723650] EXT4-fs (md0): unable to read superblock
[ 16.728680] List of all partitions:
[ 16.732206] 1f00 768 mtdblock0 (driver?)
[ 16.737303] 1f01 2880 mtdblock1 (driver?)
[ 16.742412] 1f02 4352 mtdblock2 (driver?)
[ 16.747510] 1f03 64 mtdblock3 (driver?)
[ 16.752616] 1f04 64 mtdblock4 (driver?)
[ 16.757721] 1f05 64 mtdblock5 (driver?)
[ 16.762813] No filesystem could mount root, tried: ext3 ext2 ext4
[ 16.769087] Kernel panic - not syncing: VFS: Unable to mount root fs on unkno wn-block(9,0)
[ 16.777399] Backtrace:
[ 16.779907] [<c0011c68>] (dump_backtrace+0x0/0x10c) from [<c03fba1c>] (dump_s tack+0x18/0x1c)
[ 16.788405] r7:c877ffa0 r6:c403600f r5:c0551610 r4:c0587410
[ 16.794153] [<c03fba04>] (dump_stack+0x0/0x1c) from [<c03fbc94>] (panic+0x70/ 0x18c)
[ 16.801876] [<c03fbc24>] (panic+0x0/0x18c) from [<c0530e70>] (change_floppy+0 x0/0xec)
[ 16.809760] r3:c4027f38 r2:00000020 r1:c4027f38 r0:c04b09cc
[ 16.815499] r7:c877ffa0
[ 16.818075] [<c0530b20>] (mount_block_root+0x0/0x350) from [<c0530fc4>] (moun t_root+0x68/0x6c)
[ 16.826746] [<c0530f5c>] (mount_root+0x0/0x6c) from [<c0531164>] (prepare_nam espace+0x19c/0x1e0)
[ 16.835590] r5:c0551610 r4:c0586460
[ 16.839227] [<c0530fc8>] (prepare_namespace+0x0/0x1e0) from [<c05309bc>] (ker nel_init+0x1b4/0x1bc)
[ 16.848247] r6:c0586400 r5:c05515ec r4:00000008
[ 16.852937] [<c0530808>] (kernel_init+0x0/0x1bc) from [<c004c638>] (do_exit+0 x0/0x648)
[ 16.860908] r7:00000013
