Hallo Matthieu!
May 11 20:56:59 syslogd started: BusyBox v1.16.1
May 11 20:57:00 kernel: [ 38.660000] md: md2: set sda5 to auto_remap [0]
May 11 20:57:01 kernel: [ 39.180000] md: md3: set sdb5 to auto_remap [0]
May 11 20:57:02 spacetool: spacetool.c:2081 [Info] Old vg path: [/dev/vg1], New
vg path: [/dev/vg1], UUID: [Pq5uzG-hsq4-40Km-Xn29-JC4Q-GJ4S-PNRvo1]
May 11 20:57:02 spacetool: spacetool.c:2081 [Info] Old vg path: [/dev/vg2], New
vg path: [/dev/vg2], UUID: [2Y6NF7-ZVYs-qkrO-60FZ-LQ14-be6X-cGpQQG]
May 11 20:57:02 spacetool: spacetool.c:2084 [Info] Activate all VG
May 11 20:57:12 scemd: scemd.c:125 fan_type=3, raid_type=1, led_type=1, thermal_
type=2, fanctrl_type=1, auto_poweron_type=1, dual_power_type=1, usbcopy_type=1,
fan_number=1, ebox_type=1, pis_type=1, rtc_type=2
May 11 20:57:12 scemd: modules/fan_speed_adjust_common.c:163 Type: INTERNAL Fan
Mode: LOW
May 11 20:57:13 scemd: modules/raid_sys_volume_check.c:163 MD0 active disks 2, d
esigned disks 2
May 11 20:57:13 scemd: modules/raid_sys_volume_check.c:163 MD1 active disks 2, d
esigned disks 2
May 11 20:57:13 scemd: modules/disk_hibernation.c:429 Force hibernation enable,
idle minutes 15
May 11 20:57:22 kernel: [ 60.390000] Got empty serial number. Generate serial
number from product.
May 11 20:57:24 syno_hdd_util: Model:[ST31000528AS], Firmware:[CC38], S/N:[9VP5D
XV4] in [/dev/sdb] is not ssd
WW2] in [/dev/sda] is not ssd
May 11 20:57:25 synousbdisk: RCClean succeeded
May 11 20:57:25 synosata: synosata.c:174 failed to enum all external sata device
s
May 11 20:57:26 ddnsd: main(ddnsd.c:2790): not enable DDNS, shutdown daemon
May 11 20:57:27 hotplugd: ACTION:add.
May 11 20:57:27 hotplugd: DEVNAME:lp0.
May 11 20:57:27 hotplugd: DEVICE:/proc/bus/usb/001/003.
May 11 20:57:27 hotplugd: DEVGUID:A3J1610730.
May 11 20:57:27 hotplugd: SYNO_PMP_EVENT:.
May 11 20:57:27 hotplugd: external_disk_port_check.c:86 expected sdx or /dev/sdx
, not lp0
May 11 20:57:27 synoprint: printer_enable_ext.c:292 printer driver infomation cl
eared.
May 11 20:57:27 synoprint: printer_support_post_script.c:88 lp0 support commands
: CMD
JL,PCL,PCLXL [0]
May 11 20:57:45 syno_bkp_data_update: Fail to get share information (NetBackup)
May 11 20:57:45 syno_bkp_data_update: syno_bkp_data_update.c: main(234) - Fail t
o update netbakup data format.
May 11 20:57:46 kernel: [ 84.190000] usbip_common_mod: module is from the stag
ing directory, the quality is unknown, you have been warned.
May 11 20:57:46 kernel: [ 84.270000] usbip: module is from the staging directo
May 11 20:57:46 sshd[5451]: error: Bind to port 22 on :: failed: Address already
in use.
May 11 20:57:46 sshd[5451]: error: Bind to port 22 on 0.0.0.0 failed: Address al
ready in use.
May 11 20:57:46 sshd[5451]: fatal: Cannot bind any address.
May 11 20:57:48 synorcd: hw_raytac.c (222) failed to open /dev/usb/hiddev5 (No s
uch device).
May 11 20:59:21 scemd: scemd.c:379 stop manutild.
May 11 21:08:22 syno_hibernate_debug_tool: (115): Start Hibernation Debug with s
econd [10]
May 11 21:12:16 syno_hibernate_debug_tool: (154): End Hibernation Debug
May 11 21:12:16 syno_hibernate_debug_tool: open snyobios error
May 11 21:24:23 kernel: [ 1680.940000] process `sysctl' is using deprecated sysc
tl (syscall) net.ipv6.neigh.default.retrans_time; Use net.ipv6.neigh.default.ret
rans_time_ms instead.
May 11 21:39:30 syno_hibernate_debug_tool: (115): Start Hibernation Debug with s
econd [10]
May 11 21:39:30 kernel: [ 2588.150000] [/etc/passwd] opened by pid 6185 [u
-ash
), comm
ash)]
