Mit putty kenne ich mich aus aber die Platte hängt ja gerade mittels SATA-USB-Adapter am PC und wird gesichert. Ich habe mal die Systempartition gemountet (in Windows sagt man wohl besser als Laufwerk eingehängt) und die log-Datei aufgestöbert. Hier der letzte Boot-Eintrag:
Aug 23 18:37:08 syslogd started: BusyBox v1.16.1
Aug 23 18:37:08 kernel: Linux version 2.4.22-uc0 (root@build4) (gcc version 3.3.4) #2263 Thu Mar 13 02:19:14 CST 2014
Aug 23 18:37:08 kernel: Synology Hardware Version: DS108jv20
Aug 23 18:37:08 kernel: On node 0 totalpages: 8192
Aug 23 18:37:08 kernel: zone(0): 8192 pages.
Aug 23 18:37:08 kernel: zone(1): 0 pages.
Aug 23 18:37:08 kernel: zone(2): 0 pages.
Aug 23 18:37:08 kernel: Kernel command line: console=ttyS0,115200 root=/dev/hda1 rw ip=off initrd=0x00800000,16M hda=bswap syno_hw_version=DS108jv20
Aug 23 18:37:08 kernel: OpenPIC Version 1.2 (1 CPUs and 138 IRQ sources) at fc040000
Aug 23 18:37:08 kernel: Decrementer frequency = 99.493810 MHz
Aug 23 18:37:08 kernel: Warning: real time clock seems stuck!
Aug 23 18:37:08 kernel: Calibrating delay loop... 132.30 BogoMIPS
Aug 23 18:37:08 kernel: Page-cache hash table entries: 8192 (order: 3, 32768 bytes)
Aug 23 18:37:08 kernel: POSIX conformance testing by UNIFIX
Aug 23 18:37:08 kernel: sandpoint_pci.c(sandpoint_map_irq)(71) idsel = 0, pin = 1, irq = 0
Aug 23 18:37:08 kernel: sandpoint_pci.c(sandpoint_map_irq)(71) idsel = 13, pin = 1, irq = 16
Aug 23 18:37:08 kernel: sandpoint_pci.c(sandpoint_map_irq)(71) idsel = 14, pin = 1, irq = 17
Aug 23 18:37:08 kernel: sandpoint_pci.c(sandpoint_map_irq)(71) idsel = 15, pin = 1, irq = 18
Aug 23 18:37:08 kernel: Initializing RT netlink socket
Aug 23 18:37:08 kernel: Starting kswapd
Aug 23 18:37:08 kernel: kinoded started
Aug 23 18:37:08 kernel: pty: 256 Unix98 ptys configured
Aug 23 18:37:08 kernel: RAMDISK driver initialized: 16 RAM disks of 16384K size 1024 blocksize
Aug 23 18:37:08 kernel: physmap.c:421(init_physmap): Unknown flash type, using ppcboot settings.
Aug 23 18:37:08 kernel: master->size = 200000, erasesize = 10000
Aug 23 18:37:08 kernel: Mac0 00:11:32:03:d6:05
Aug 23 18:37:08 kernel: vender Mac1 checksum error ucSum:0x00 Buf:0x00 Sum:0.
Aug 23 18:37:08 kernel: Vender partition MacNum:1 retlen:64
Aug 23 18:37:08 kernel: Serial Number: 86E7N01164
Aug 23 18:37:08 kernel: ide0: reset phy, status=0x00000113, siimage_reset
Aug 23 18:37:08 kernel: hda: SAMSUNG HD103UJ, ATA DISK drive
Aug 23 18:37:08 kernel: blk: queue c022aeb0, I/O limit 4095Mb (mask 0xffffffff)
Aug 23 18:37:08 kernel: ide1: reset phy, status=0x00000000, siimage_reset
Aug 23 18:37:08 kernel: ide1: reset phy dead, status=0x00000000
Aug 23 18:37:08 kernel: siimage_reset: no drive on ide1.
Aug 23 18:37:08 kernel: ide0 at 0xc3000e80-0xc3000e87,0xc3000e8a on irq 16
Aug 23 18:37:08 kernel: ide1 at 0xc3000ec0-0xc3000ec7,0xc3000eca on irq 16
Aug 23 18:37:08 kernel: ide2: DISABLED, NO IRQ
Aug 23 18:37:08 kernel: ide3: DISABLED, NO IRQ
Aug 23 18:37:08 kernel: ide4: DISABLED, NO IRQ
Aug 23 18:37:08 kernel: ide5: DISABLED, NO IRQ
Aug 23 18:37:08 kernel: ide6: DISABLED, NO IRQ
Aug 23 18:37:08 kernel: ide7: DISABLED, NO IRQ
Aug 23 18:37:08 kernel: hda: attached ide-disk driver.
Aug 23 18:37:08 kernel: hda: host protected area => 1
Aug 23 18:37:08 kernel: VFS: Mounted root (ext2 filesystem).
Aug 23 18:37:08 kernel: i2c-ppc.c(mpc_i2c_init)(240) i2c_base = fc003000
Aug 23 18:37:08 kernel: correction with 0x0f
Aug 23 18:37:08 kernel: synobios: unload
Aug 23 18:37:08 kernel: EXT3-fs warning: maximal mount count reached, running e2fsck is recommended
Aug 23 18:37:08 kernel: VFS: Mounted root (ext3 filesystem).
Aug 23 18:37:08 kernel: sk98lin: Network Device Driver v8.41.2.3
Aug 23 18:37:08 kernel: (C)Copyright 1999-2006 Marvell(R).
Aug 23 18:37:08 kernel: eth0: Yukon Gigabit Ethernet 10/100/1000Base-T Adapter
Aug 23 18:37:08 kernel: PrefPort:A RlmtMode:Check Link State
Aug 23 18:37:08 spacetool: spacetool.c:290 Failed to tune RAID stripe cache size[0x2000 file_get_key_value.c:108]
Aug 23 18:37:09 s00_synocheckfstab: system_blk_dev_readahead_set.c:35 Failed to set '/dev/hda3''s readahead to 4096d
Aug 23 18:37:09 s00_synocheckfstab: volume_readahead_allset.c:32 Failed to set RA on [/dev/hda3]
Aug 23 18:37:10 kernel: eth0: network connection up using port A
Aug 23 18:37:10 kernel: speed: 100
Aug 23 18:37:10 kernel: autonegotiation: yes
Aug 23 18:37:10 kernel: duplex mode: full
Aug 23 18:37:10 kernel: flowctrl: symmetric
Aug 23 18:37:10 kernel: irq moderation: disabled
Aug 23 18:37:10 kernel: scatter-gather: enabled
Aug 23 18:37:10 kernel: tx-checksum: enabled
Aug 23 18:37:10 kernel: rx-checksum: enabled
Aug 23 18:37:11 kernel: EXT3-fs warning: maximal mount count reached, running e2fsck is recommended
Aug 23 18:37:17 scemd: scemd.c:131 fan_type=5, raid_type=2, led_type=2, thermal_type=2, diskled_ctrl_type=2, auto_poweron_type=1, dual_power_type=1, usbcopy_type=1, fan_number=1, eunit_pwron_type=0, pis_type=0, rtc_type=1
Aug 23 18:37:18 scemd: modules/disk_hibernation.c:1743 Force hibernation enable, idle minutes 20
Aug 23 18:37:18 scemd: modules/disk_hibernation.c:1760 Eunit Deep sleep timer 0
Aug 23 18:37:18 synoprint: printer_enable_ext.c:488 delete printer failed: no bus id
Aug 23 18:37:27 kernel: PCI: 00:0e.1 PCI cache line size set incorrectly (0 bytes) by BIOS/FW.
Aug 23 18:37:27 kernel: PCI: 00:0e.1 PCI cache line size corrected to 32.
Aug 23 18:37:27 kernel: USB_DEVICE: This is hub. No need to call_policy_interface.
insmod: init_module: usb-uhci: No such device
insmod: can't insert '/lib/modules/usb-uhci.o': Operation not permitted
Aug 23 18:37:28 syno_hdd_util: Model:[SAMSUNG HD103UJ], Firmware:[1AA01112], S/N:[S13PJ1BQ611561] in [/dev/hda] is not ssd
Aug 23 18:37:45 synousbdisk: RCClean succeeded
Aug 23 18:37:45 synosata: synosata.c:150 failed to enum all external sata devices
Aug 23 18:37:47 ddnsd: main(ddnsd.c:2983): not enable DDNS, shutdown daemon
Aug 23 18:37:47 heartbeatd: heartbeatd.c:164 DDNS does not enable, skip starting
Aug 23 18:37:47 ntpdate: Sync with time server 129.70.132.34 offset -9.262003 sec.
Aug 23 18:37:50 cupsd[1884]: [listen.c:184] Unable to open listen socket for address :::631 - Address family not supported by protocol.
Aug 23 18:38:01 sm-notify[2118]: Failed to open /var/lib/nfs/sm.bak: No such file or directory
Aug 23 18:39:17 scemd: scemd.c:337 stop manutild.
Aug 24 00:00:02 ntpdate: Sync with time server 148.251.90.84 offset 0.215517 sec.
Aug 24 01:10:03 scemd: scemd: power button pressed, ret = 0
Aug 24 01:10:03 scemd: SCEMD: Shutdown the system.
Aug 24 01:10:03 scemd: scemd.c:264 receive SIGTERM
Aug 24 01:10:17 root: /usr/syno/etc/rc.d/S98findhostd.sh stop findhostd
Aug 24 01:10:26 kernel: nfsd: last server has exited
Aug 24 01:10:26 kernel: nfsd: unexporting all filesystems
rmmod: can't unload 'nfsd': Device or resource busy
Aug 24 01:10:26 rsyncd[2133]: rsync error: received SIGINT, SIGTERM, or SIGHUP (code 20) at rsync.c(581) [Receiver=3.0.8]
Aug 24 01:10:33 ntpdate: Sync with time server 46.165.212.205 offset 2.133055 sec.
Aug 24 01:10:38 synorelayd[1655]: synorelayd.cpp:916 get signal, logout
Aug 24 01:10:38 synorelayd[1655]: synorelayd.cpp:1160 stoped
Aug 24 01:10:40 kernel: fs_close_all_files: force to close file c04391a0
Aug 24 01:10:40 kernel: fs_close_all_files: force to close file c08eaf60
Aug 24 01:10:40 kernel: fs_close_all_files: force to close file c0394420
Aug 24 01:10:40 kernel: fs_close_all_files: force to close file c0394220
Aug 24 01:10:40 kernel: sys_umount: force unmount success
Aug 24 01:10:41 kernel: correction with 0x0f
Aug 24 01:10:42 syslogd exiting
Es wird die Ausführung von e2fsck angeraten...wird der Prozess denn nicht automatisch nach "x" Bootvorgängen gestartet??? Sonst irgendwas auffälliges zu sehen???
H_H
