DDNS Updater DDNS Updater UI not loading
neikt
23. Nov. 2013
I have tried installing this package many times in the past without success but now I've decided to post this so as to see what I am doing wrong.
As per screenshots attached all packages required have been installed and running normally but when I select to run the DDNS Updater UI, a window with the code comes up (3rd screenshot) DSM version is 4.3.3810 Update 1 on DS-1010+. I had exactly the same results on previous DSM versions. I would appreciate any help on this. Thanks in advance!
Clean browsercache or reboot your DS, it seems there are some old cache contents.
Thank you for your reply.
The DiskStation has rebooted numerous times today due to firmware upgrades and once more just before posting this reply.
The browser data has also been cleaned and tried to load DDNS UI from two MacMini's.
Unfortunately the same windows pops up with the php code... No UI still.
Then there is a problem with Init_3rdparty. Init_3rdparty should adapt the system apachen so php files can be processed, but this will not not be performed on your ds.
Execute PHPInfo from startmenu and check the output.
Login via telnet or ssh as root with password from admin and restart the system apache with the following cmd:
/usr/syno/etc/rc.d/97apache-sys.sh restart
Please post the output.
QTIP thank you for your support!
Indeed PHP info returns "Sorry, the page you are looking for is not found" as per screenshot attached.
I restarted S97apache-sys.sh (I guess the "S" was missing from your command) but still PHP Info returns the same page.
Should I uninstall Init_3rdparty and DDNS updater and install again?
The thing is that I did uninstall and reinstall but without luck.
Thanks again!
So I did the following:
1. Uninstalled Init_3rdparty, Init_3rdpartyhelp, DDNS Updater.
2. Restarted Synology.
3. Install Init_3rdparty and Init_3rdpartyhelp.
4. Restarted Synology.
5. Executed PHPInfo from Start Menu -> Output is the same: "Sorry, the page you are looking for is not found".
At this point I am not installing DDNS Updater as I guess it wont work due to the PHPInfo error.
Any suggestions are welcome. Thank you.
Can you restart the apache without mc, i would like to see the output from apache and post it here.
You need Init_3rdpartyhelp only in DSM older than 4.x, so you can deinstall it.
I did restarted it using the command line as well.
There was no output on terminal screen after running the command. It returned immediately to the command prompt. I am not sure if I need to run another command in order to see the output of apache. If so then I would appreciate a little help on this. Thanks!
please post the output of
tail -n 20 /usr/syno/apache/conf/httpd.conf-sys
*edit*
install ipkg packages nmap and netstat, then post output of
nmap -sT -O localhost
and
netstat -anp | grep 5002
Output for tail -n 20 /usr/syno/apache/conf/httpd.conf-sys
<IfModule rewrite_module>
#for demo site
Include conf/extra/*demo-site.conf
# the request param will not be matched in the rule
# [QSA,L] is to append new query to original query
RewriteEngine On
RewriteRule ^/viewer/(.*)/(.*)/(.*)/(.*) /usr/syno/synoman/webfm/webUI/file_download.cgi?dlink=$1&_sid=$2&SynoToken=$3&ip=false&api=SYNO.FileStation.Download&version=1&method=download&mode=open&stdhtml=true [QSA,L]
RewriteRule ^/fbsharing/(.*) /usr/syno/synoman/webfm/webUI/file_download.cgi?key=$1&api=SYNO.FileStation.Download&version=1&method=download&mode=download&stdhtml=true [QSA,L]
RewriteRule ^/fbdownload/(.*) /usr/syno/synoman/webfm/webUI/file_download.cgi?api=SYNO.FileStation.Download&version=1&method=download&mode=download&stdhtml=true [QSA,L]
# wfmdownload rule is for old version compatibility
RewriteRule ^/wfmdownload/(.*) /usr/syno/synoman/webfm/webUI/file_download.cgi?api=SYNO.FileStation.Download&version=1&method=download&mode=download&stdhtml=true [QSA,L]
RewriteRule ^/dar/(.*) /usr/syno/synoman/webman/modules/SystemInfoApp/DataAnalysis.cgi?path=$1 [QSA,L]
</IfModule>
<IfDefine FrameOptions>
Include conf/extra/httpd-frameOptions.conf-sys
</IfDefine>
Output for netstat -anp | grep 5002
tcp 0 0 ::%134822437:5002 ::%134897295:* LISTEN 9104/httpd
Output of nmap -sT -O localhost
Starting Nmap 5.35DC1 ( http://nmap.org ) at 2013-11-24 18:11 EET
Nmap scan report for localhost (127.0.0.1)
Host is up (0.0013s latency).
Not shown: 979 closed ports
PORT STATE SERVICE
22/tcp open ssh
23/tcp open telnet
80/tcp open http
111/tcp open rpcbind
139/tcp open netbios-ssn
161/tcp open snmp
443/tcp open https
445/tcp open microsoft-ds
515/tcp open printer
548/tcp open afp
631/tcp open ipp
2049/tcp open nfs
3493/tcp open unknown
5002/tcp open rfe
5432/tcp open postgresql
6002/tcp open X11:2
7002/tcp open afs3-prserver
8002/tcp open teradataordbms
8082/tcp open blackice-alerts
9090/tcp open zeus-admin
9200/tcp open wap-wsp
Device type: WAP
Running (JUST GUESSING) : Linux 2.4.X (85%)
Aggressive OS guesses: DD-WRT v24 SP2 (Linux 2.4.36) (85%)
No exact OS matches for host (test conditions non-ideal).
Network Distance: 0 hops
OS detection performed. Please report any incorrect results at http://nmap.org/submit/ .
Nmap done: 1 IP address (1 host up) scanned in 7.21 seconds
The config is missing the Init_3rdparty part. Stop Init_3rdparty and start it again. If you get a error on start of Init_3rdparty then do it again, it should than be happen without error otherwise restart ds an try again.
Repeat the command tail -n 20 /usr/syno/apache/conf/httpd.conf-sys and post output.
I wonder why Init_3rdparty don't modify your config. Is there a httpd.conf-sys.bak in the /usr/syno/apache/conf/ folder?
On my DS the restart of apache return the following output:
/usr/syno/etc/rc.d/S97apache-sys.sh restart
/usr/syno/etc/rc.d/S97apache-sys.sh: system httpd stopped
serverID: 005531326
state: connected
Start System Apache Server .....  -DSSL -f /usr/syno/apache/conf/httpd.conf-sys
/usr/syno/etc/rc.d/S97apache-sys.sh: system httpd started
serverID: 005531326
state: connected
I stopped and started the service.
There was no error in starting the service but the output of PHPInfo is the same.
Output of tail -n 20 /usr/syno/apache/conf/httpd.conf-sys
#for demo site
RewriteEngine On
</IfModule>
</IfDefine>
The output of S97apache-sys.sh restart is indeed interesting.
I drilled down to /usr/syno/etc/rc.d to see if the file is in there. It is!
However running "S97apache-sys.sh restart" returns a very weird error. See screenshot below.
Thank you for your continuous support.
use ./S97apache-sys.sh restart and post output.
For some unknown reason, the changes by Init_3rdparty are not written in the apache config. I must investigate more @home, i'll get back.
DiskStation_II> ./S97apache-sys.sh restart
./S97apache-sys.sh: system httpd stopped
./S97apache-sys.sh: system httpd started
I test it on my Test DS over and over again, in no situation I got the same behavior as you.
I can think of the following reasons:
- Either the Apache has an error at startup, but does not show it and restores the original state automatically. In this case you would get a DSM notification.
- It could also be another application that cancel the changes. (rather unlikely but possible)
- If the commands in the scripts have prefixed with no absolute paths and there are differences between Synology and /opt commands (eg grep).
Can you post me which apps you have installed.
Have you installed ipkg and some tools like grep?
The command which grep tells you what you have in use
We now test whether the script is running successfully in a user environment.
  • stop Init_3rdparty via package center
  • log via telnet or ssh as root with password from admin into your ds
  • exec the following command:
    /var/packages/Init_3rdparty/scripts/start-stop-status start
    Please also post any messages
    and post output
If there is the following code at the end of the output, then the script works in user environment.
#step1
# Integration of Init_3rdparty
 Listen 5002
LoadModule rewrite_module modules/mod_rewrite.so
LoadModule php5_module /lib/libphp5.so
AddType application/x-httpd-php .php
RewriteEngine On
RewriteCond %{SERVER_PORT} =5002
RewriteRule ^/$ http://%{SERVER_NAME}:5000/webman/3rdparty/Init_3rdparty/index.php [R]
Include /usr/syno/synoman/webman/3rdparty/Init_3rdparty/php.conf
#step1
You can now restart the sys-apache with
If the script is running in the user environment, then it is up to 99% on the paths to the commands or the commands themselves.
Here is the output of the commands:
DiskStation_II> which grep
/bin/grep
DiskStation_II>
Then I stopped Init_3rdparty and run:
DiskStation_II> /var/packages/Init_3rdparty/scripts/start-stop-status start
DiskStation_II>
No output from this command.
Then
DiskStation_II> tail -n 20 /usr/syno/apache/conf/httpd.conf-sys
#for demo site
RewriteEngine On
</IfModule>
</IfDefine>
DiskStation_II>
I don't see the required code at the end of the file.
Restarted apache
DiskStation_II> /usr/syno/etc/rc.d/S97apache-sys.sh restart
DiskStation_II>
Thanks again!!
very strange, ok
can you show me a screenshot of the Init_3rdparty log (copy & paste don't work there), go to package center - Installed - click on package Init 3rdparty and then click on View Log
now we execute the 2 necessary commands from the start-stop-status script by hand
  • exec the following commands line by line and pay attention on displayed warning or error messages:
    test -f /usr/syno/apache/conf/httpd.conf-sys.bak || cp /usr/syno/apache/conf/httpd.conf-sys /usr/syno/apache/conf/httpd.conf-sys.bak
    info: the above line create a backup of httpd.conf-sys if not exists
    grep "Listen 5002" /usr/syno/apache/conf/httpd.conf-sys.bak >/dev/null || (cat /usr/syno/synoman/webman/3rdparty/Init_3rdparty/step1.conf >>/usr/syno/apache/conf/httpd.conf-sys && echo "step1.conf added" >>/var/packages/Init_3rdparty/log)
    info: the above line append the contents of file "/usr/syno/synoman/webman/3rdparty/Init_3rdparty/step1.conf httpd.conf-sys" at the end of file "/usr/syno/apache/conf/httpd.conf-sys" if not exists
    info: the above line show you the last 20 rows of file /usr/syno/apache/conf/httpd.conf-sys
  • inspect the Init_3rdparty log in package center
Dear QTip, here are the results.
I assume that these 3 command should be run with Init_3rdparty stopped via Package Centered.
1. test -f /usr/syno/apache/conf/httpd.conf-sys.bak || cp /usr/syno/apache/conf/httpd.conf-sys /usr/syno/apache/conf/httpd.conf-sys.bak
No error or output.
2. grep "Listen 5002" /usr/syno/apache/conf/httpd.conf-sys.bak >/dev/null || (cat /usr/syno/synoman/webman/3rdparty/Init_3rdparty/step1.conf >>/usr/syno/apache/conf/httpd.conf-sys && echo "step1.conf added" >>/var/packages/Init_3rdparty/log)
No error or output.
3. tail -n 20 /usr/syno/apache/conf/httpd.conf-sys
#for demo site
RewriteEngine On
</IfModule>
</IfDefine>
The first screenshot shows the Init_3rdparty log before stopping the service and running the commands.
The second screenshot shows the log after stopping the service, running the 3 commands and then starting back the service. i.e. the commands were run between 18:02 and 18:10.
